Page 2 of 3
Re: what is a good parts list for a beginner to buy at mouse
Posted: Mon Sep 14, 2015 7:21 pm
by beholder
Thanks Garth!
Yeah, C2 & C3! My bad. I'd figure they were left out, but wanted to make sure.
I guess I got everything lined up. Parts should arrive by the end of the week.
Can't wait to play with the 65c02!
By the way, Thanks for the 6502 primer. It's impressively dense and very well documented.
I wonder how long did it take to finish it all. I'm glad you took the time to write that down :)
I've been looking around for books on building 6502 computers.
Most of what I found were books on assembly programming only.
Was there ever a book on building 6502 computers from scratch out there?
Thanks
Posted: Mon Sep 14, 2015 10:51 pm
Thanks. I wrote most of it in 2003, then pulled out of mothballs and updated and added photos and published in 2012 when I finally had a website. It has had countless little updates since then. As much as I wanted to do it, if I had known how much work it was going to be, I might not have done it. I was not (and still am not) aware of any such other resource, in print or online.
This is the most popular part of the website, although surprisingly, the next-most popular, in spite of getting no forum discussion or emails, is the section on 16-bit scaled-integer math (note that I did not say "fixed-point" which is a limited subset of scaled-integer) and the large look-up tables that become like a math co-processor. I'm about to make another major feature public with 19 chapters which I have been working on since the spring of 2013 as I got time (which means sometimes it sat dormant for months). Everything takes so much more work than I expect it to, even after I've been through the cycle several times. Even the article on assembly language's relevance, which I thought I could punch out quickly, turned out to be anything but quick.
Posted: Tue Sep 15, 2015 4:56 am
Good technical writing is not a trivial exercise, even for the experienced. Over the years, I have written a number of full-blown technical manuals, running in a few cases to several hundred pages. It is a time-consuming process, due to the need to make sure every jot and tittle is in place. Writing technical matter can also become tedious when the intended audience has only a modicum of knowledge of the topic, as a good deal of parenthetical explanation is often necessary to avoid losing the reader.
Posted: Thu Sep 17, 2015 9:31 pm
by beholder
Hi guys.
Let me give you some updates on my 6502 adventure :twisted:
Last night I got my 65c02 and other parts from Mouser.
Today I got to make a quick "free run" test on my 65c02 and it worked :)
I did a freerun using my arduino found here: from https://coronax.wordpress.com/2012/11/1 ... n-circles/
Looking at the serial port I could see the 65c02 going through its address bus.
Now, for some reason I had to change the baud rate from 115200 to 9600 to work.
Not sure why, but at 115200 it doesn't read :(
I also noticed the address were hoping back here and there, instead of changing linearly.
Anyone had a similar problem by any chance?
I'll upload a video to show my setup.
Next setp, get some simple code into my eeprom so I can setup the 6502 potpourri :)
Thank!
Posted: Thu Sep 17, 2015 10:30 pm
by Dr Jefyll
I can't comment on the baud rate issue, since that would be an Arduino thing. But as for the addresses hopping back, by any chance do they hop back to $EAEA? :roll: I suspect your 'c02 is executing an NMI, IRQ or RESet. Those are the only things that would override the $EA (NOP) that you are continually forcing on the data bus. They would try to do three writes to stack and then there'd be a jump to $EAEA.
(Actually the writes amount to bus contention, since your hardwired $EA is forced even during writes. This could briefly upset the power supply, resulting in a jump somewhere other than $EAEA. If you wire the EA using eight 10K resistors instead of eight pieces of wire then the excess current drain will be avoided. That won't fix the reset problem, if any, but it'll render the symptoms more predictable!)
In your blog you mention that NMI and IRQ are taken care of, so maybe your Reset circuit is the source of some glitches. If it's not a reset issue, then maybe there's a power supply problem. Your setup is so simple there's really not a lot that can go wrong!
BTW, you also say, "The software on the Arduino side is trivial. It runs a loop where it toggles the clock output on and off, and then reads the values of the 8 address lines I hooked up. If the value has changed, it writes out the hexadecimal value on its serial port." I hope that in the case of an unchanged value the information isn't ignored entirely -- that whatever's on the receiving end knows enough to fill in the blank. Just checking!
Posted: Thu Sep 17, 2015 10:48 pm
by beholder
Hi Jefyll.
Thanks for the feedback!
By the way, I didn't write the blog. I just used his example to test my 6502.
Coronax did all the hard work, I just copied his example :D
I was working on it and then it started working just fine. Not sure what caused the hops... maybe power or some bad connection on my breadboard.
I did removed a capacitor from the reset circuit. Read that on a comment on his blog. Maybe that did it.
I made a quick video showing the setup:
https://www.youtube.com/watch?v=YmNbVczc618
Will now look into getting some code on my my eeprom.
Posted: Fri Sep 18, 2015 9:12 am
Just a quick note: it's always best to start a new thread when taking off in a new direction - the thread title remains as a good guide to the thread contents, and there's a new thread with a new and appropriate title for the new discussion.
Posted: Fri Sep 18, 2015 10:26 pm
by beholder
Hi BigEd.
Sure, will start a new tread with my 6502 progress to keep this one related to what to buy as a beginner.
Getting back to equipment buying questions :D
I found this eeprom programmer on amazon for a decent price:
http://www.amazon.com/Signstek-Universa ... 2661618011
Was wondering if its worthy? Anyone have tried this one?
seems like it programs 28cxx
Thanks
Posted: Sat Sep 19, 2015 12:59 am
beholder wrote:
Hi BigEd.
Thanks
It's gotten good reviews. Let that be your guide.
Posted: Sat Sep 19, 2015 11:37 am
by cbscpe
Would be interesting to know if it really burns GALs as well. As programmer I use a Genius G540 which sells for the same price and it does all my EEPROMs and GALs
Posted: Sat Sep 19, 2015 11:58 am
by lenzjo
I had no luck with the GAL22V10D with this programmer
Posted: Sat Sep 19, 2015 5:55 pm
by banedon
Only if you threaten it with a hammer! ;)
@beholder
With regard to the serial speed of the arduino... did you change it in the arduino sketch and in the terminal program on your PC as well? For instance, I use PuTTY to communicate with my projects and that has options to set the serial speed, number of data bits, stop bit, and hand shaking. All must match.
Posted: Sat Sep 19, 2015 11:22 pm
by beholder
Hi Banedon.
I figured out why it wasn't working on 115200, the serial window has a dropdown option box where you choose which rate.
Didn't know I had to set the arduino project and the serial window :oops:
I got both the free run and tight loop examples working, from this website:
http://mysite.du.edu/~jcalvert/tech/6504.htm
I hooked up LEDs on all 16 pins of the address bus to check what was happening.
As expected from the tight loop example, the address are always jumping at $00, $01 and $02.
Works perfect and I guess the reset works as well.
Now... I got this funny thing happening when I reset my 65c02. The address bus always starts at FFFF(all leds light up), then it will spit out some random address for 4 clocks (low-high) then it goes to $FFFC, then $FFFD (which from what I understand is the reset vector), then it starts the tight loop.
Any explanation why I get these random values at reset? Could a reset circuit cause this? Im using Garth's reset circuit form his potpourri example with the 74HC138. I wonder if I made a mistake :roll:
I'm using my arduino to provide the clock. At the beginning of my loop I set the output pin to LOW then to HIGH. Then I read the address bus pins to see what's happening with the 6502.
Here's a quick copy of what my serial is capturing form the 6502. This right after a reset:
The hex is from address bus pins A0-A7. I can see the full address from the LEDs
The first is always FFFF, then 4 random values, than FFFC and FFFD, than the loop starts.
Doesn't matter if I change the clock speed to very fast or very slow, same results.
########## RESET ##########
- clock low: 1
- clock high: 2
- clock low: 3
ff
- clock high: 4
- clock low: 5
03
- clock high: 6
- clock low: 7
f0
- clock high: 8
- clock low: 9
ef
- clock high: 10
- clock low: 11
ee
- clock high: 12
- clock low: 13
fc
- clock high: 14
- clock low: 15
fd
- clock high: 16
- clock low: 17
00
- clock high: 18
- clock low: 19
01
- clock high: 20
- clock low: 21
02
- clock high: 22
- clock low: 23
00
- clock high: 24
- clock low: 25
01
- clock high: 26
- clock low: 27
02
- clock high: 28
- clock low: 29
00
- clock high: 30
- clock low: 31
01
- clock high: 32
- clock low: 33
02
- clock high: 34
- clock low: 35
00
- clock high: 36
- clock low: 37
01
- clock high: 38
- clock low: 39
02
- clock high: 40
- clock low: 41
00
Posted: Sun Sep 20, 2015 2:25 am
I did not show a '138 there, so I don't know where you're bringing it in. However, the WDC data sheet shows the reset sequence doing two clock cycles of internal operations, followed by pushing things on the stack, before fetching the reset vector. That's normal.
Posted: Sun Sep 20, 2015 3:39 am
by beholder
Hi Garth.
Sorry, I meant 74HC132 :oops:
I always get these 7400 ics wrong :D
Then how does the 6502 knows when to start reading an address after reset?
Will it just read the data bus when it gets to FFFC and FFFD?
Or can it read these "weird" values?
Thanks
