Page 2 of 2
Re: WDC 65c02 signal levels
Posted: Thu Jul 16, 2015 8:01 am
I'm still wondering if it's the presence of TTL inputs which will drag down outputs, and so in a design without TTL inputs, the output levels will be higher than the minimum spec - and therefore within range of a weirdo spec.
Posted: Thu Jul 16, 2015 8:30 am
by ArnoldLayne
ArnoldLayne wrote:
By checking the data lines with a scope, I see signal levels way beyond 3.5V, around 5V. So, yes, we happen to be within WDC spec after all, but not sure why, and not sure if that is always the case, with any device on the bus.
The data bus is bidirectional, so sometimes it'll be the WDC itself which drives it. That'd explain the 5V signal levels.
I checked the r/W line, too, so I know that I have seen mostly reads. Not really sure from where, though.
If you haven't already, you could try syncing the scope to reads of that NMOS device you mentioned. It's when that device is driving the bus (and the WDC is supposed to receive the data) that we might have a problem with adequate voltage levels.
I'll take that as my homework for today.
Posted: Thu Jul 16, 2015 2:14 pm
by Dr Jefyll
Sounds good. Btw, a reminder: if you're using an analog scope (not a DSO) and you're trying to scope something very specific -- in this case reads from the NMOS SRAM and from that TMS9929 -- it's very helpful to write a tiny loop that repeatedly performs the action you're trying to observe.
Posted: Sat Jul 18, 2015 7:17 am
by ArnoldLayne
Okay,
I am late with my homework.
I wrote a small program that reads the TMS9929's status register in a tight loop. What we see on the screenshot is the TMS9929's /CSR-pin (blue curve) and the D2-line (yellow curve).
As we can see, the signal level when driven by that NMOS 9929 is just slighty above 4V, so apparently WDC safe.
Using a 3.3k pullup resistor will pull up the level a bit (go figure..) but seems to pull up some noise, too.
Posted: Sat Jul 18, 2015 7:18 pm
by Dr Jefyll
OK, so in red I drew the Phase2 waveform in what I suppose to be the the correct relation, and I put the images in a two-frame animation, ie, with and without the pullup (below). It's no surprise to see that the pullup resistor has a distinct effect when Phase2 is low (for example in the first part of cycle 1, which I circled). This is entirely harmless. The 'C02 will always tri-state the data bus during Phase2 low, and ideally (but depending on its wiring) the host system will do the same. Hence there's nothing to prevent the pullup from pulling up.
The last half of cycle 2 seems strange, though. In the no-pullup frame we see the voltage drop sharply at the end (late in period 2b). Although it's slightly OT, I'm puzzled and bothered by this. It suggests something odd about the device, something odd about your wiring or the way the experiment was done, or something I'm missing or don't understand.
Just checking - you said the blue curve is the TMS9929's /CSR pin. Is that the device's chip-select input? Can you post or link to a datasheet for that chip? And did I get Phase2 in the correct relation to the other waveforms? Edit: alternative Phase2 interpretation added.
Posted: Sun Jul 19, 2015 2:37 pm
by Dr Jefyll
In version 2 of the animation above I shifted the clock, and the result seems more plausible in some ways and less so in others.
I put two arbitrary timing marks in the excerpt below, both of which seem to indicate the effect of Phase2 going high (and output drivers being enabled). But they are not separated by an integer number of cycles; there's also a roughly one-quarter-cycle phase shift. Apparently there's one output driver that responds promptly to Phase2 going high, and another which for some reason is very sluggish to do so -- at least that's one possible explanation.
Posted: Thu Jul 23, 2015 1:29 pm
by ArnoldLayne
Hi,
the heat wave in Germany gives me a break today, so I'll try to clarify some stuff I should have been more specific about earlier.
First, here is the datasheet for the TMS9929. /CSR is the chip select input for reading, there is a separate one, /CSW, for writing.
http://www.datasheetarchive.com/dlmain/ ... 445645.pdf
Second, /CSR or /CSW are generated only from the address lines and r/W, there is no PHI2 involved.
I attached another graph to show how /CSR (yellow) relates to PHI2 (blue).
Posted: Fri Dec 23, 2016 3:03 am
I wrote above,
WDC's data sheets have been rather bad over the years, fortunately on the bad side; ie, the parts perform much better than they say. The 2.4V output is to say that they can pull up at least that high with the specified load; but even there, they can pull up much, much higher. I have tested one I/O pin at a time of Rockwell's R65c22 and the WDC W65C22S outputs here (note the WDC ones having the "S" ending), and they are many times as strong as the data sheet says (and I believe the processor has the same output circuits). In my experiment, WDC's outputs were able to pull to within 0.8V of either rail with a 220-ohm resistor to the opposite rail, meaning a 19mA load, even pulling up, and give 50mA into a dead short. Rockwell's could pull down with 100mA into a dead short, but could not pull up as hard, not being symmetrical like WDC's.
At Jeff's prompting, I tested an '816 since I have a fixture set up for that, which I used in the recent half-cycling tests to figure out undocumented interrupt behavior. The data bus drivers appeared to be a little stronger than the address bus's. On the data bus, I could get valid CMOS levels (30% & 70%) at 30mA or better, both directions. For pulling down to .65V for a TTL low, I got 20mA. On the address bus, I was able to get valid CMOS logic levels at 21mA; and for pulling down to .59V, 10mA. (I was just trying different load resistors and recording the resulting voltages and calculating the currents.)
I tested only a few pins, of one IC, from one lot, and only at room temperature. I know it's not much, but it's all I'm willing to do at the moment for my project. I just wanted to confirm my suspicion, rather than do a full characterization as would be needed for a real data sheet. However, it does show that the pin drivers are a lot stronger than the WDC data sheet lets on. I should have done the same test for the W65C02S before I modified it for the '816; but I suspect they used the same pin-driver circuits for both processors.
If all loads are CMOS, our only interest in the current is to charge the capacitances, since holding a steady-state voltage does not require any current if the loads are all CMOS. Charging up a 25pF load by 4V takes 1ns @ 100mA average current over that nanosecond. For doing it in 4ns would require 25mA average over those 4ns.
The current won't be constant in practical situations though, nor will it follow the same curve you'd get in an RxC. It will be in between. The circuit can be approximated by a current-limiting mechanism plus a series resistance. On the address bus (which is not as strong as the data bus), the current at a pin when it has accomplished the first two volts of its journey from a high voltage to a low (or vice-versa) would be 43mA or a little more if the effects of inductance at the ground and Vcc connections could be reduced to negligible levels. If you had to go for a very rough number and treat it as just a resistance, the data-bus pins acted very roughly like a SPDT switch with 50Ω in series with the common terminal (ie, the output); and the address bus pins, as a SPDT switch with 60Ω in series.
