Page 2 of 2
Re: Old school 3-D Vector Gaphics on new system
Posted: Fri Apr 04, 2014 10:30 am
by ElEctric_EyE
Posted: Fri Apr 04, 2014 11:08 am
Me too - I'm following, but don't find myself with much to say. It's good to see the development of a project, including the ups and downs.
Posted: Wed Apr 09, 2014 9:55 am
by ElEctric_EyE
The software has really changed alot. I have a few macros now.
side_map1: side of a square from LUT1.
square_map1:use side_map1 to draw 4 lines using the LUT1 circle coordinates.
side_map2: side of a square from LUT2.
square_map2:use side_map2 to draw 4 lines using the LUT2 circle coordinates.
cube_map12: use square_map1 & square_map2 to draw 2 squares and 4 interconnecting lines.
side_map1         .MACRO                   ;1st SQUARE OF CUBE FROM SINEWAVE MAP 1
                  LDY START
                  LDA scratchx1,Y
                  STA lx0
                  LDA scratchy1,Y
                  STA ly0
                  LDY STOP
                  LDA scratchx1,Y
                  STA lx1
                  LDA scratchy1,Y
                  STA ly1
                  .ENDM
square_map1       .MACRO
                  LDA OFFSET
                  STA START
                  LDA #256
                  CLC
                  ADC OFFSET
                  STA STOP
                  side_map1
                  LDA #256
                  CLC
                  ADC OFFSET
                  STA START
                  LDA #512
                  CLC
                  ADC OFFSET
                  STA STOP
                  side_map1
                  LDA #512
                  CLC
                  ADC OFFSET
                  STA START
                  LDA #768
                  CLC
                  ADC OFFSET
                  STA STOP
                  side_map1
                  LDA #768
                  CLC
                  ADC OFFSET
                  STA START
                  LDA OFFSET
                  STA STOP
                  side_map1
                  .ENDM
side_map2         .MACRO                   ;2nd SQUARE OF CUBE FROM SINEWAVE MAP 1
                  LDY START
                  LDA scratchx2,Y
                  STA lx0
                  LDA scratchy2,Y
                  STA ly0
                  LDY STOP
                  LDA scratchx2,Y
                  STA lx1
                  LDA scratchy2,Y
                  STA ly1
                  .ENDM
                                                              ;2nd SQUARE OF CUBE
square_map2       .MACRO
                  LDA OFFSET
                  STA START
                  LDA #256
                  CLC
                  ADC OFFSET
                  STA STOP
                  side_map2
                  LDA #256
                  CLC
                  ADC OFFSET
                  STA START
                  LDA #512
                  CLC
                  ADC OFFSET
                  STA STOP
                  side_map2
                  LDA #512
                  CLC
                  ADC OFFSET
                  STA START
                  LDA #768
                  CLC
                  ADC OFFSET
                  STA STOP
                  side_map2
                  LDA #768
                  CLC
                  ADC OFFSET
                  STA START
                  LDA OFFSET
                  STA STOP
                  side_map2
                  .ENDM
cube_map12        .MACRO                      ;MAP A CUBE
                  square_map1                 ;SQUARE1
                  square_map2                 ;SQUARE2
                  LDY OFFSET                 ;DIAGONAL INTERCONNECTS
                  LDA scratchx1,Y
                  STA lx0
                  LDA scratchy1,Y
                  STA ly0
                  LDA scratchx2,Y
                  STA lx1
                  LDA scratchy2,Y
                  STA ly1
                  LDA #256
                  CLC
                  ADC OFFSET
                  TAY
                  LDA scratchx1,Y
                  STA lx0
                  LDA scratchy1,Y
                  STA ly0
                  LDA scratchx2,Y
                  STA lx1
                  LDA scratchy2,Y
                  STA ly1
                  LDA #512
                  CLC
                  ADC OFFSET
                  TAY
                  LDA scratchx1,Y
                  STA lx0
                  LDA scratchy1,Y
                  STA ly0
                  LDA scratchx2,Y
                  STA lx1
                  LDA scratchy2,Y
                  STA ly1
                  LDA #768
                  CLC
                  ADC OFFSET
                  TAY
                  LDA scratchx1,Y
                  STA lx0
                  LDA scratchy1,Y
                  STA ly0
                  LDA scratchx2,Y
                  STA lx1
                  LDA scratchy2,Y
                  STA ly1
                  .ENDM
VIDEO
This pic below is before rotation:
Posted: Wed Apr 09, 2014 9:58 am
by ElEctric_EyE
I had an issue to resolve before full rotation in the video above. In that video, it is only 1/4 rotation. It is based on the value 'OFFSET' from 0-255. Higher values resulted in (0,0) coordinates because it was going out of range in the LUT, which is only an 10-bit, 1024 range. SO I modified it...
                  LDY START
                  LDA scratchx1,Y
                  STA lx0
                  LDA scratchy1,Y
                  STA ly0
                  LDY STOP
                  LDA scratchx1,Y
                  STA lx1
                  LDA scratchy1,Y
                  STA ly1
                  .ENDM
square_map1       .MACRO
                  LDA OFFSET
                  STA START
                  LDA #256
                  CLC
                  ADC OFFSET
                  AND #%0000011111111111        ;mask off unneeded bits to accommodate 10-bit LUT max value
                  STA STOP
                  side_map1
                  LDA #256
                  CLC
                  ADC OFFSET
                  AND #%0000001111111111
                  STA START
                  LDA #512
                  CLC
                  ADC OFFSET
                  STA STOP
                  side_map1
                  LDA #512
                  CLC
                  ADC OFFSET
                  STA START
                  LDA #768
                  CLC
                  ADC OFFSET
                  STA STOP
                  side_map1
                  LDA #768
                  CLC
                  ADC OFFSET
                  STA START
                  LDA OFFSET
                  STA STOP
                  side_map1
                  .ENDM
                  LDY START
                  LDA scratchx2,Y
                  STA lx0
                  LDA scratchy2,Y
                  STA ly0
                  LDY STOP
                  LDA scratchx2,Y
                  STA lx1
                  LDA scratchy2,Y
                  STA ly1
                  .ENDM
                                                              ;2nd SQUARE OF CUBE
square_map2       .MACRO
                  LDA OFFSET
                  STA START
                  LDA #256
                  CLC
                  ADC OFFSET
                  STA STOP
                  side_map2
                  LDA #256
                  CLC
                  ADC OFFSET
                  STA START
                  LDA #512
                  CLC
                  ADC OFFSET
                  STA STOP
                  side_map2
                  LDA #512
                  CLC
                  ADC OFFSET
                  STA START
                  LDA #768
                  CLC
                  ADC OFFSET
                  STA STOP
                  side_map2
                  LDA #768
                  CLC
                  ADC OFFSET
                  STA START
                  LDA OFFSET
                  STA STOP
                  side_map2
                  .ENDM
                  LDA scratchx1,Y
                  STA lx0
                  LDA scratchy1,Y
                  STA ly0
                  LDA scratchx2,Y
                  STA lx1
                  LDA scratchy2,Y
                  STA ly1
                  LDA #256
                  CLC
                  ADC OFFSET
                  TAY
                  LDA scratchx1,Y
                  STA lx0
                  LDA scratchy1,Y
                  STA ly0
                  LDA scratchx2,Y
                  STA lx1
                  LDA scratchy2,Y
                  STA ly1
                  LDA #512
                  CLC
                  ADC OFFSET
                  TAY
                  LDA scratchx1,Y
                  STA lx0
                  LDA scratchy1,Y
                  STA ly0
                  LDA scratchx2,Y
                  STA lx1
                  LDA scratchy2,Y
                  STA ly1
                  LDA #768
                  CLC
                  ADC OFFSET
                  TAY
                  LDA scratchx1,Y
                  STA lx0
                  LDA scratchy1,Y
                  STA ly0
                  LDA scratchx2,Y
                  STA lx1
                  LDA scratchy2,Y
                  STA ly1
                  .ENDM
I made a modification to the above macro's, it's is almost 100% I had to mask off unneeded bits for the LUTs, also I added more to the delay for the video($FFFF instead of $03FF)... I just posted a new video, slowed down.
This is the main control loop now (not previously posted), :
rcube             LDX #0
triplot           LDA #%0000011111100000        ;green pixels
                  STA color
                  STX OFFSET
                  BCF1C $FFFE              ;Branch if Control Flag 1 is Clear (0), CF1 is VSYNC input, so branch to itself and wait until vsync = 1, a non display period
                  cube_map12
                  LDY #$03FF
GH                DEY
                  BNE GH
                  LDA #%0000000000000000      ;black pixels. clear previous plot
                  STA color
                  BCF1C $FFFE
                  cube_map12
                  INX
                  CPX #1023                   ;cycle through the LUTs
                  BNE triplot
triplot2          LDA #%0000011111100000        ;green pixels
                  STA color
                  STX OFFSET
                  cube_map12
                  LDY #$03FF
GH2               DEY
                  BNE GH2
                  STA color
                  BCF1C $FFFE
                  cube_map12
                  DEX
                  BNE triplot2
                  JMP rcube
ANOTHER VIDEO Still an error. Gotta figure it out, then on to 2 planes. EDIT:BAH! The first AND mask in the square_map1 macro is wrong, 1 too many 1's . The replace function must have skipped over the very first one when I was editing. :roll:
Posted: Wed Apr 09, 2014 7:50 pm
by ElEctric_EyE
This video shows correct motion. I changed the delay value to speed it up also. Now on to the Z plane! :D
