LIV2 wrote:
Thanks again, after reading the thread on high speed digital design and I don't think I'm going to get near 10Mhz anyway.
The reason for that is that my design will use ISA style connectors for peripherals connected to the cpu bus, and as I understand it'll be too noisy to get above a few mhz, not really an issue though since I'm just doing this for fun and probably won't be able to tax the system enough to need that much speed, at least for a while.
The 32 bit PCI standard, the most commonly used in x86 machines, clocks the bus at 33 MHz, so we know those connectors are up to it. Of course, the PCI bus is not directly attached to the MPU's buses like the old VESA local bus (VLB) was, so PCI cards can't load down the MPU. You may find yourself using bus drivers to get reasonable performance and stability.
