Re: A 65Org32 variant - combining opcode and operand
Posted: Sun Jan 05, 2014 7:20 am
If the operand is always sign-extended and right-shifted, we can retain addresses as 32-bit, keep the registers as 32-bit, and access the first 16Mwords of memory directly.
So, we gain density, and we lose the ability to deal directly with a full range of 32-bit constants or addresses. If you need a full 32-bit constant, you may need to construct it in the accumulator. If you need a full 32-bit address, you'll need to put in memory and use an indirect addressing mode.
some single-byte operations like PHA, TXA, INX, XAB, ROLA will still have 24 bits unused, which could lend itself to an extended register set - or indeed to express extended shifts, in the case of the 4 shift operations.
PHA could push an immediate value, but so could PHX and PHY. Perhaps better: an opcode with four bits: one for each of A, X and Y and one for the "immediate" value contained in the same "byte". Although this would also possibly lead to an instruction with a variable execution time which, although likely less time overall than separate instructions, might not be desirable. Unless it was possible to definitively say "3 cycles per bit set in the opcode", maybe or "1 cycle plus 2 cycles per bit set". Or something.
Same for PLA, although "pull immediate value" doesn't make much sense. The order of pulling and pushing registers would have to be specified by the hardware. Should an assembler also enforce it, or should something like:
PSH A,X
and
PSH X,A
ASL, LSR, ROL and ROR: of course the number of places to shift should be coded in the operand portion. I believe the 65org16 already does this.
Relative branches would have a plus or minus 8M range. Make sure there's a BSR instruction and a lot of relocation problems go away.
A "push effective address" or "load effective address" instruction could use a 24-bit relative address to find the absolute location of any code or data within plus or minus 8M as well. You were planning on stack-indirect addressing modes, weren't you?
