Page 2 of 2
Re: AnyCPU forum announcement
Posted: Thu Jan 24, 2013 8:57 am
by Tor
Aha, so that error posted above is probably the same as I see randomly - it's just displayed differently on Windows (or maybe IE) than in Chromium or on the Android browsers, which are what I use. When I get those I simply edit the url so that https becomes http and reload, and it works. I still haven't figured out a reliable way to provoke that problem every time, except the one that I mentioned earlier - whenever I post anything in a thread, at least when starting with the 'frames' version, it'll return to a https (SSL) link afterwards.
-Tor
Posted: Thu Jan 24, 2013 3:13 pm
by whartung
Error code 12263 is "SSL received a record that exceeded the maximum permissible length."
Seems to me that all SSL functions and redirections should be disabled on the site: it's just not right.
Typically it's used to secure passwords when logging in, and then the sites kick you over to the normal http route. But you really don't want to dump the https/SSL route.
Posted: Thu Jan 24, 2013 8:11 pm
What kind of cryptic error?
Dunno if this is the same as what BDD's been getting but I see this "unexpected message" error a lot. I notice it doesn't seem to mean much -- it's as likely to appear after a successful operation as after an unsuccessful one. :? :roll:
Same message. I was about to post that but you beat me to it. :D
Posted: Fri Jan 25, 2013 12:12 am
by Dajgoro
I made a small modification on the control panel, let me know if the problem persists.
Posted: Wed Jan 30, 2013 3:12 am
by Dajgoro
Have there been any more SSL issues since my last fix?
Posted: Wed Jan 30, 2013 3:24 am
by Dr Jefyll
I made a new post since you announced the change, and the error message I was used to seeing didn't appear. So that seems like cause for optimism :)
