6502 Playground
Re: 6502 Playground
Build something which makes sense for you! It's too easy for projects to lose their way, and never happen.
Re: 6502 Playground
I am not movable about the overall design goal -'small and simple'- for this project, and am grateful for your feedback.
Re: 6502 Playground
Arlet, to answer your post in the POC2 thread (more appropriate here), yes, I envision an add-on board(s) with:
-VGA output/resistor network
-Keyboard/mouse jacks
-SD card reader
-game controller jacks of some kind
Since the FPGA is doing all the work, these would be pretty much trivial adapters.
-SD card reader
Re: 6502 Playground
Hi enso, if you could arrange for the pinout to allow either 128K or 512K SRAM, that would be a bonus. I'd be happy to buy and ship some 512K parts to you. (In the case of DIP parts, the pinouts are sufficiently compatible to allow that: AS6C4008 vs. AS6C1008)
It's a good point that 48 I/Os is enough to fit an external memory board that's 16bits wide. For 32bits, I'd probably need to borrow some of the CPU connections, or the on-board SRAM connections.
Re: 6502 Playground
This project is largely about recycling my inventory. I have XC3S200ANs, XC3S700ANs and a bunch of K6R1008V1C-JC10, 128K 10ns SRAMS...
Re: 6502 Playground
Ah, that's a fast SRAM! I'm not sure there is a package compatible one at the next density up.
- GARTHWILSON
- Forum Moderator
Re: 6502 Playground
Re: 6502 Playground
Interesting. I never realized that the pinouts work this way. GARTHWILSON, am I correct in assuming that the 36-pin land pattern will work for the 128K chip if the top and bottom rows are not used? That's a good thing to know.
- GARTHWILSON
- Forum Moderator
Re: 6502 Playground
Right. And for SRAM, you don't have to preserve the order of the data lines, or the order of the address lines either. That might help route it on a PCB with fewer layers or vias.
Garth
Garth
Re: 6502 Playground
Great. Layout accomodates 128K or 512K devices as well as 65C02 or 65C816 via a PLCC socket. I routed out 48 bits using wings layout, although I don't have 2.5V. I doubt any wings use 2.5 anyway. A straight 25-pin header on each side can be soldered in instead for breadboard use.
I have a few tests to run with my oscillators and finetune the BGA process...Almost there.
Re: 6502 Playground
Great!
Re: 6502 Playground
Close to the finish line.
6502.org wrote:
Image no longer available: http://apple2.x10.mx/board.png
Re: 6502 Playground
Small, but perfectly formed!
Re: 6502 Playground
That looks very, very interesting... I'm definitely interested in one or more of these. Not sure what I'd be using it for, but it looks like another way of getting back into the early 80's
(in some ways; in others, definitely not...)
I just bought a NewBrain computer - made about 1982 or so, and in great condition apart from a missing keycap.
Re: 6502 Playground
rwiker, thanks for your interest.
I will definitely make some extra boards. For my friends here at 6502.org I will make them available at my cost- shooting for $50 with an xc3s200an.
I am thinking of a 'shield' board that snaps on top with VGA, keyboard/mouse, an SD slot, audio out and some kind of joystick/paddle interface (probably a 555-based apple2/commodore style) to turn this into a great retromachine.
