Page 2 of 15
Re: Breaking 6502 apart
Posted: Fri Jun 29, 2012 6:44 am
by org
That analog **** makes my research more complicated
Posted: Fri Jun 29, 2012 6:52 am
I think you can treat it all as digital, in the sense that a transistor is a switch. But it is bidirectional... And you can't divide up the circuit purely into neat logic gates. There are some interesting combinations.
By the way, the dynamic latches are the exact reason why a single stepping circuit must be careful about whether it stops with the clock high or low. One case will be fine, the other will have the leaking storage and will not be reliable.
Posted: Fri Jun 29, 2012 6:56 am
by org
Thanks Ed, things become more clear to me.. )
50 kHz makes those 2 ms discharge rate )
At 500 kHz halfclock will last only 2us, its 1000 times shorter than discharge period )
So in order to recognize such capacitors I just need to pay attention on long polysilicon wires ?
Posted: Fri Jun 29, 2012 7:07 am
by org
Oh, I know.... When I see mosfets connected in parralel next time, I will add capacitor in schematics =)
Edit: like that :
Image no longer available: http://ogamespec.com/imgstore/whc4fed54d25dd47.jpg
Posted: Fri Jun 29, 2012 7:46 am
Well, you won't always have two transistors - in fact, usually you'll only have one. You'll see these nodes in the timing shift register in the first picture you posted - at top right there's a master-slave flip-flop made of two dynamic latches. More or less.
But you probably only want to annotate a capacitor when the latch is single and there's no recirculation.
Posted: Mon Jul 02, 2012 8:08 am
by org
Wrote small script which helps to understand which instructions are affected by decoder.
http://ogamespec.com/6502/decoder.htm
Type IR-line into input fiels and press "Decode". Script will highlight affected opcodes.
Example : XXX110X1
Posted: Mon Jul 02, 2012 8:30 am
Neat! It wasn't working for me at first, but I realised I was hitting 'Enter' rather than clicking on the button.
Posted: Mon Jul 02, 2012 7:23 pm
by org
Posted: Tue Jul 03, 2012 10:06 am
by org
Todays speccy : SYNC
Color :
Transistor level :
Logic:
SYNC = sync (driven by internal signal through amplifiers)
Posted: Tue Jul 03, 2012 2:18 pm
by org
Found error in data latch (missing vias).
Updated transistor level schematics :
Posted: Tue Jul 03, 2012 5:42 pm
by org
I completed reversing of data bus logic
PHI1:
if (DL_ADL) ADL = DL;
if (DL_ADH) ADH = DL;
if (DL_DB) DB = DL;
DOR = DB;
PHI2:
if (RW == 0) DATA = DOR;
DL = DATA;
ADL = ADH = DB = 0xFF;
Posted: Wed Jul 04, 2012 2:32 pm
by org
Started random logic
Simple explanation :
Posted: Thu Jul 05, 2012 8:43 pm
by org
Todays speccy : Registers X, Y, S
Color (bit 0):
Transistor level:
Logic:
PHI1:
if ( Y/SB ) SB = Y;
if ( SB/Y ) Y = SB;
if ( X/SB ) SB = X;
if ( SB/X ) X = SB;
if ( S/ADL) ADL = S;
if ( S/SB ) SB = S;
if ( SB/S ) S = SB;
if ( S/S ) S = S;
PHI2:
SB = 0xFF;
Posted: Fri Jul 06, 2012 11:26 am
by org
Todays speccy : Predecode Register
Posted: Fri Jul 06, 2012 11:56 am
Instantly recognisable! You notice how the first transistors from the databus are huge? I think that's to make the inverter's logic threshold a bit lower, which it needs to be because the databus is at TTL levels. Fortunately, it makes no difference to a logic sim. A big pulldown is a more eager one, so the output flips at a lower input voltage than it otherwise would.
You see the same thing in the next gate, after phi2, because the pass transistor transmits a degraded logic 1. The ClearIR inputs are normal sized by comparison. (As discussed previously, those PDn nodes are storage nodes.)
