Fast prototyping boards
ElEctric_EyE
- BigDumbDinosaur
Tor wrote:
Nightmaretony wrote:
but for various cpus, yuppers. A generic edge such as VME?
-Tor
- GARTHWILSON
- Forum Moderator
- BigDumbDinosaur
BillO wrote:
... they make most of their money by licensing IP, not selling ICs.
Incidentally, my POC unit is powered by the '816 in the PLCC package.
BillO wrote:
After the 65C02 board, others would follow, such as a 6809, Z80, 65C816, others...
The idea's no good for PLCC, of course. And there'd still be a fair amount of point-to-point wiring to be done. But at least the drudgery of connecting the 16 address and 8 data lines (and power & ground) would be taken care of.
Hmmm... Since 6502 and 65c816 pinouts are so similar, maybe those two could coexist with Z-80 in a three-way board design! (Or maybe 6809 instead of Z-80; I haven't looked into it.)
Nightmaretony
- In Memoriam
Or you can pull the trick that Jeri does of a small plug in module for each cpu.
by the way, speaking of the 02/816 pinout, finally revamped the schematic to acommodate both CPUS. my usual stop, www.nightmarepark.com/6502.php click on the pinball mind folder and check out the pdf of it. Let me know what you think there...
- BigDumbDinosaur
Nightmaretony
- In Memoriam
Is there DIP versions of ABT? One goal is ease of repair in the future so all packages are DIP based. the 245 logic is simply buffers to the outside world, in an attempt to protect the CPLD. The F series I always had issues in arcade games of running hotter and being the first to go bye bye. Speed is not so important as I don't think I will go past 4 MHz in this design in general.
- BigDumbDinosaur
Nightmaretony
- In Memoriam
EDIT: ABT lower cost and available in PDIP. thankee!
- BigDumbDinosaur
As for SO chip removal, I've found that a carefully directed hot air blast from my small heat gun (has a 1 inch diameter nozzle) will desolder SO and SOJ packages. These packages aren't as hobby-friendly as DIPs, but they do take up quite a bit less PCB real estate, and thus make it easier to make tight trace routing that enhances high frequency performance. The industry in general is moving away from DIP, so the change is inevitable.
Last edited by BigDumbDinosaur on Mon Oct 17, 2011 7:38 pm, edited 1 time in total.
Nightmaretony
- In Memoriam
I have no problems in soldering SO packages. I can regularly do 144 TQFP packages by hand at my old job. the secret is in the flux
The thing is a design goal I have in this pinball computer, I am making it for other people to be able to repair it 20 years down the road. Every part is fairly common with multiple sources, except for the Xilinx CPLD, and I use a through hole socket plus test points all around it. Worst comes to worst, someone can make a sub board with a new kind of CPLD replacement. It is still a pretty decent power system at a good price point, so it should work out well.
