Like I said, VGA is on life support.
VGA has five years to live
- BigDumbDinosaur
Re: VGA has five years to live
kc5tja wrote:
My Dell monitors only have digital pins. In fact, none of my computers even have DVI outs anymore (only HDMI), so I can't even use them anymore without adapters (and that means reduced resolutions). No analog. Even on our TV in the living room, DVD is HDMI out, TV is HDMI in. The only analog that supports is S-Video.
Pssh you'll be saying floppy discs are dead next... WAIT!
- GARTHWILSON
- Forum Moderator
Our son convinced me to replace the huge high-res CRT monitor I was using with this Linux computer a couple of years ago with a thin one on the basis that the power savings would pay for it in a year (although I have not seen the corresponding $10/month reduction in the bill-- or any reduction at all for that matter)
- BitWise
- In Memoriam
The main advantages of TFT screens are reduced weight and less heat output. Important factors when you have skyscrapers full of thousands of desktops. In some banks I worked for the number of people on each floor was limited by the weight of their equipment. They packed more people in when they switched to TFT. The lower heat generation saves on air conditioning.
At home I doubt either advantage is that significant at home. Personally I think I'll only see my bills fall when my kids leave home.
The size issue is the important one. At the table I'm sitting at now, for example, there is only approximately 10cm between the back of the TFT monitor and the wall, I could not have used a CRT monitor, not even a small one. Definitely not the 21" CRT I used when I had an SGI Indy at home.. that one was deep, and nearly 35kg. The weight, plus the depth, nearly destroyed my back when I carried the monitor out of my home (I had it there only temporarily).
- BigDumbDinosaur
LED backlit LCD monitors do exhibit some power savings over conventional CCF LCD monitors, but we're not talking kilowatts here.
In the past, when we converted clients from CRT to LCD monitors they did see some power consumption reduction. Of course, that was swapping out 8-10 monitors at a time. The biggest such conversion we did involved replacing 52 monitors. That had a noticeable effect on power consumption, making the expense of the changeout worthwhile.
My 30" Dell flatscreen monitor consumes just about 100W of power. My 15" CRT about the same. So, perhaps the metric isn't absolute power savings, but rather power per viewable surface area.
White Flame
LCDs surpassed CRTs in pixel count since 2560x1600, so LCD it is for me.
My whole setup is hooked through a kill-a-watt, idling around 160W. Toggling the monitor (cheap Seiki 4K 39") cuts off about 70W, but I think the video card also stops sucking watts as well when the display's off.
- BigDumbDinosaur
ChuckT wrote:
This news will have an effect on microcontrollers as VGA will be less popular and current microcontrollers may not be fast enough to drive HDMI video.
Say Goodbye to VGA Graphics as Intel and AMD Partner for the Execution
http://www.technewsworld.com/story/VGA- ... 1291926599
VGA Given 5 Years to Live
http://www.technewsworld.com/story/VGA- ... 71420.html
(I fixed the link.)
(I fixed the link.)
- commodorejohn
It's been 6-1/2 years since this was posted and VGA is still going strong.
The other day I was at a thrift store and they had TWO of the largest CRT TV's I have ever seen. I thought my 32" CRT at home was large. These were gigantic. They had to be at least 42" with a 4:3 ratio (not wide screen). Of course, they were just as deep as they were tall.
And no, they were not projection TV's. These were absolutely CRT's. Even had that beautiful curve on the glass.
You don't know how bad I wanted these. But my wife would kill me and my 32" CRT (that I use for NES and other gaming) barely fits in my gaming closet. I can't imagine what those things weigh!
Anyway, I hope VGA stays around forever. I have several small VGA monitors I use at home for my TI99-4/a (that has an F18 mod) and other things. I still see new monitors with VGA connections on them. The great thing about VGA is that it is "good enough" for many of the things we do (or at least, things I do).
It's an open format....easy for micro-controllers to generate (i.e., the Propeller) and it's EASY to use and understand. In fact, it's easier to understand than NTSC.
"VGA has five years to live" - it's just the art of writing a headline.
I then read the NTSC specification and while the monochrome part is easy to understand, the color burst signal is a bit mind bending. Kudos to the engineers for being able to make NTSC backwards compatible, but I can't imagine how analog hardware implementations of it work.
- BigDumbDinosaur
The desire to stick with a standard whose strengths and weaknesses were well-understood by the time color TV became a reality perpetuated something that should have been retired. I'm amazed that NTSC has persisted all these years, given its many weaknesses, especially the lock-in to the 525 line, 30 frames per second display rate long after electronics had progressed to support much better video. PAL, of course, is best described as an adaptation of NTSC to the 50 Hz power frequency common in many parts of the world outside North America. PAL has slightly better quality than NTSC, but to some people, subtle flicker is visible due to the slower frame rate.
Fortunately, things have greatly improved, although I still prefer the picture of a CRT monitor over that of an LCD panel. I guess I'm just an out-of-touch curmudgeon.
