Posted: Tue Nov 09, 2010 5:17 am
I have modified the concept layout. Here it is:
The standoffs are threaded and can be stacked. There are many different length's available to support different height requirements. They also come in brass, aluminum, or nylon.
Here is a picture of a 5/8" nylon one:
Using the ribbon cable allows for variable-height boards and is cheaper than using a backplane.
Each daughter board has a 32 byte window and a dedicated IRQ. The main board will decode the address space and provide an IRQ flag register for the 4 daughter boards along with its own IRQ for the RS-232 channels.
There will be two main boards to start with. One will have a simple 65C02, 32k RAM, 32k EEPROM, and RS-232. The other will have a 65816 supporting up to 4.5MB of RAM, and using a microcontroller to preload the RAM from either a serial flash/EEPROM or purhaps an SD card. The serial memory will be accessible via a secondary RS-232 channel.
User IO for both modules will be through the primary RS-232 channel. This will have a Pololu RS-232-to-USB bridge with drivers for Windows and Linux.
Daughter modules will include dual VIA's, dual 65SPI's, Video and keyboard IO, and sound.
I plan to get the proper spec's for these out within the month. I'm still trying to get my website updated.... wish my work didn't interfere with my play so much!
