Posted: Wed Feb 25, 2009 8:42 pm
For starters, there's no less than four times as many traces to place and route. That means increased board-related expenses, and really, THAT ultimately is what determines product price.
- soldermask (and what kind)
legend (and whether it's on one side or both)
controlled impedances
burried capacitance
blind and/or burried vias
secondary operations (like milling a slot, or drilling a hole after the others are thru-plated)
gold plating on contacts
bare-board testing at the board house
The number of traces does not affect the cost directly. If you need more layers to get it all in, or use super-narrow trace and space (like .002"!), then the price increases, but OTOH, these may result in decreased board size for a given complexity too.
4. You don't need to reload all 32-bits of an address bus. What are the odds that you will even use half of that address space?
Remember, the original 68000 was limited to 16MB, and the 68008 to 1MB. Lots of useful systems were built with both, each with significantly less than their complete memory capacity installed.
since you have the load the buggers each time.
By all accounts, WDC has only one significant customer, Winbond. And, by significant, I mean, if Winbond stopped using the 65xx lineup tomorrow, WDC would find themselves desperately seeking new clientele to keep cash flow, or risk burning cash reserves.
Overall, if you're looking for anything resembling performance, you'll want either a discrete component CPU (using actual TTL parts) or an FPGA solution.
However, you might want to consider building a stack-architecture CPU if you go this route. I think you'll find Phil Koopman's text on the subject, "Stack Computers: The New Wave" (http://www.ece.cmu.edu/~koopman/stack_c ... index.html) most interesting.
(Edited 6/25/12 to add link to math tables web pages)
