An insight I had while talking to Sam about what to do with negative values for
ALLOT: One thing that takes getting used to about Forth is that even though there is a standard, it's very rough around the edges and certainly not complete. For instance, if you "negative allot" (release) too much memory, obviously you are going to trash something at some point. The standard (
https://forth-standard.org/standard/core/ALLOT) has nothing to say about this, and in fact, where there should be a test for this case, it says
I think there are two main reasons for this. One, there was always some resistance to the idea of standardization, and the ANSI people have kept all kinds of areas where the application gets to do what it thinks best. In other words, the standard is intentionally lose because a strict version would not be tolerated. Two, since there is no traditional lexer and parser, nobody is forced to sit down and create a complete context free grammar and whatnot for the language.
It certainly takes getting used to.
