Re: Comparisons and contrasts
Posted: Tue Jan 11, 2022 6:41 pm
Wow, 30% smaller code is very impressive!
jr C,$-1
jp C,38h
jr C,$-1
jr C,$-1
ld hl,(S1) ;don't care about h, contains garbage.
ld a,l
rla
sbc a,a ;=> a-a-0 or a-a-1 ie. 0 or 0xff.
ld h,a ;hl now sign extended.
ld de,258
or a ;clears carry.
sbc hl,de ;hl=258-S1
ld (dest),hl ;saved
ldd #258
pshs d
ldb s1
sex
sub d,S++
std dest
; dest=const-S1
lda #<const
sec
sbc S1
sta dest
lda #>const
sbc #0
sta dest+1
bit S1
bpl label
inc dest+1 ; adjust for S1<0
label:
lda S1 ; signed 8-bit displacement
eor #$7f
tay
lda const-$7f,y ; access target (const-S1)
. 00191 ; Input:
. 00192 ; The absolute value of the number to convert is stored
. 00193 ; starting at OutBuf+2 in little-endian form
. 00194 ; A = number of bytes in the number
. 00195 ; Dabble is the label of last byte of the buffer
. 00196 ; OutBuf+0 = 0 if number is negative, other if negative
. 00197 ;
. 00198 ; Output:
. 00199 ; A:X contains the address of the resultant string
. 00200 ;
. 00201 ; Uses:
. 00202 ; Byt0 = number of bytes to convert
. 00203 ; Byt1 = number of packed BCD bytes in result
. 00204 ; Byt2 = bits of number being shifted
.206E 00225 Format:
.206E 85 12 [3] 00226 sta Byt0 ; Remember number of bytes to convert
.2070 AA [2] 00227 tax ; Use it as index into the number
. 00228
.2071 A9 00 [2] 00229 lda #0 ; Start with no bytes of BCD digits
.2073 85 13 [3] 00230 sta Byt1
. 00231
.2075 F8 [2] 00232 sed ; Switch to decimal mode
. 00233
.2076 00234 SkipLeadingZero:
.2076 B5 19 [4] 00235 lda OutBuf+1,X ; Get next highest byte of the number
.2078 D0 07 (2081) [2/3] 00236 bne NotLeadingZero
. 00237
.207A CA [2] 00238 dex ; Skip a leading zero
. 00239
.207B D0 F9 (2076) [2/3] 00240 bne SkipLeadingZero ; Check the next one if more
. 00241
.207D F0 2F (20AE) [2/3] 00242 beq BCD2ASCII ; All bytes are zero
. 00243
.207F 00244 ByteLoop:
.207F B5 19 [4] 00245 lda OutBuf+1,X ; Get next highest byte of the number
. 00246
.2081 00247 NotLeadingZero:
.2081 85 14 [3] 00248 sta Byt2 ; Set it for shifting
. 00249
.2083 86 12 [3] 00250 stx Byt0 ; Remember the address of the last one shifted
. 00251
.2085 38 [2] 00252 sec ; Shift in extra bit for eight trips through loop
. 00253
.2086 B0 12 (209A) [2/3] 00254 bcs EnterBitLoop ; Always branches
. 00255
.2088 00256 BitLoop:
.2088 A2 2D [2] 00257 ldx #Dabble ; Point to the BCD digits
. 00258
.208A A4 13 [3] 00259 ldy Byt1 ; Load count of number of digit bytes
.208C F0 0A (2098) [2/3] 00260 beq SkipDigitLoop ; Skip loop if none
. 00261
.208E 00262 DigitLoop:
.208E B5 00 [4] 00263 lda 0,X ; Double pair of BCD digits with carry
.2090 75 00 [4] 00264 adc 0,X
.2092 95 00 [4] 00265 sta 0,X
. 00266
.2094 CA [2] 00267 dex ; Point to next pair of BCD digits
. 00268
.2095 00269 IntoDigitLoop:
.2095 88 [2] 00270 dey ; More BCD digits?
.2096 D0 F6 (208E) [2/3] 00271 bne DigitLoop ; Yes
. 00272
.2098 00273 SkipDigitLoop:
.2098 B0 0B (20A5) [2/3] 00274 bcs Extend ; Carry out of accumulated digits?
. 00275
.209A 00276 EnterBitLoop:
.209A 26 14 [5] 00277 rol Byt2 ; Transfer upper bit to carry flag
.209C D0 EA (2088) [2/3] 00278 bne BitLoop ; Repeat if more
. 00279
.209E A6 12 [3] 00280 ldx Byt0 ; Point back to the number to convert
. 00281
.20A0 CA [2] 00282 dex ; Any more bytes of the number to convert?
.20A1 D0 DC (207F) [2/3] 00283 bne ByteLoop ; Repeat if more
. 00284
.20A3 F0 09 (20AE) [2/3] 00285 beq BCD2ASCII ; Always branches to unpacking stage
. 00286
.20A5 00287 Extend:
.20A5 E6 13 [5] 00288 inc Byt1 ; Add a new byte to the result
.20A7 A9 01 [2] 00289 lda #1
.20A9 95 00 [4] 00290 sta 0,X
. 00291
.20AB 18 [2] 00292 clc
.20AC 90 EC (209A) [2/3] 00293 bcc EnterBitLoop ; Always branches
. 00294
.20AE 00295 BCD2ASCII:
.20AE D8 [2] 00296 cld ; Return to binary mode
. 00297
.20AF A5 13 [3] 00298 lda Byt1 ; Any converted digits?
.20B1 F0 42 (20F5) [2/3] 00299 beq NoDigits ; No
. 00300
.20B3 38 [2] 00301 sec
.20B4 A9 2E [2] 00302 lda #Dabble+1 ; Point to most significant BCD pair
.20B6 E5 13 [3] 00303 sbc Byt1
.20B8 A8 [2] 00304 tay
. 00305
.20B9 A2 1A [2] 00306 ldx #<OutBuf+2 ; Point to result buffer
. 00307
.20BB B9 0000 [4/5] 00308 lda 0,Y ; Get most significant BCD pair
. 00309
.20BE 29 F0 [2] 00310 and #$F0 ; Is the upper one zero?
.20C0 F0 0E (20D0) [2/3] 00311 beq UpperZero
.20C2 D0 03 (20C7) [2/3] 00312 bne ConvertBoth
. 00313
.20C4 00314 ASCIILoop:
.20C4 B9 0000 [4/5] 00315 lda 0,Y ; Get next most significant BCD pair
. 00316
.20C7 00317 ConvertBoth:
.20C7 4A [2] 00318 lsr A ; Convert upper one to ASCII
.20C8 4A [2] 00319 lsr A
.20C9 4A [2] 00320 lsr A
.20CA 4A [2] 00321 lsr A
.20CB 09 30 [2] 00322 ora #'0'
.20CD 95 00 [4] 00323 sta 0,X
.20CF E8 [2] 00324 inx
. 00325
.20D0 00326 UpperZero:
.20D0 B9 0000 [4/5] 00327 lda 0,Y
.20D3 C8 [2] 00328 iny
.20D4 29 0F [2] 00329 and #$F ; And then the lower one
.20D6 09 30 [2] 00330 ora #'0'
.20D8 95 00 [4] 00331 sta 0,X
.20DA E8 [2] 00332 inx
. 00333
.20DB C6 13 [5] 00334 dec Byt1 ; More digits?
.20DD D0 E5 (20C4) [2/3] 00335 bne ASCIILoop ; Yes
. 00336
.20DF 8A [2] 00337 txa ; Store string length
.20E0 38 [2] 00338 sec
.20E1 E9 1A [2] 00339 sbc #OutBuf+2
. 00340
.20E3 A6 18 [3] 00341 ldx OutBuf ; Is the number negative?
.20E5 F0 14 (20FB) [2/3] 00342 beq NumberNotNegative
. 00343
.20E7 18 [2] 00344 clc ; Increment and store length
.20E8 69 01 [2] 00345 adc #1
.20EA 85 18 [3] 00346 sta OutBuf
. 00347
.20EC A9 2D [2] 00348 lda #'-' ; Prepend minus sign
.20EE 85 19 [3] 00349 sta OutBuf+1
. 00350
.20F0 A9 00 [2] 00351 lda #>OutBuf
.20F2 A2 18 [2] 00352 ldx #<OutBuf
. 00353
.20F4 60 [6] 00354 rts
. 00355
.20F5 00356 NoDigits:
.20F5 A9 30 [2] 00357 lda #'0' ; Emit single '0'
.20F7 85 1A [3] 00358 sta OutBuf+2
. 00359
.20F9 A9 01 [2] 00360 lda #1 ; String length one
. 00361
.20FB 00362 NumberNotNegative:
.20FB 85 19 [3] 00363 sta OutBuf+1
. 00364
.20FD A9 00 [2] 00365 lda #>OutBuf+1
.20FF A2 19 [2] 00366 ldx #<OutBuf+1
. 00367
.2101 60 [6] 00368 rts
00001 ; Converting $FFFFFFFF
00002 ; old $2BC9 11209 cycles for call FormatLongword
00003 ; new $0A72 2674 cycles
00004 ;
00005 ; Converting $00000001
00006 ; old $2A96 10902 cycles for call FormatLongword
00007 ; new $015B 347 cycles
00008 ;
00009 ; Converting $00000000
00010 ; old $2A98 10904 cycles for call FormatLongword
00011 ; new $0075 117 cycles
. 00486 * Input:
. 00487 * The absolute value of the number to convert is stored
. 00488 * starting at OutBuf+2 in little-endian form
. 00489 * A = number of bytes in the number
. 00490 * Dabble is the label of last byte of the buffer
. 00491 * OutBuf+0 = 0 if number is negative, other if negative
. 00492 *
. 00493 * Output:
. 00494 * X contains the address of the resultant string
. 00495 *
. 00496 * Uses:
. 00497 * Byt0 = number of bytes to convert
. 00498 * Byt1 = number of packed BCD bytes in result
. 00499 * Byt2 = bits of number being shifted
. 00500 * Ptr0
. 00501 * Ptr1
.01F5 00522 Format
.01F5 97 10 [4] 00523 staa Byt0 ; Remember number of bytes to convert
. 00524
.01F7 8B 17 [2] 00525 adda #<OutBuf+1 ; Point to most significant byte of number
.01F9 97 0B [4] 00526 staa Ptr0+1
.01FB 86 00 [2] 00527 ldaa #>OutBuf+1
.01FD 89 00 [2] 00528 adca #0
.01FF 97 0A [4] 00529 staa Ptr0
.0201 DE 0A [4] 00530 ldx Ptr0
. 00531
.0203 7F 0011 [6] 00532 clr Byt1 ; Start with no bytes of BCD digits
. 00533
.0206 00534 SkipLeadingZero
.0206 E6 00 [5] 00535 ldab ,X ; Get next highest byte of the number
.0208 26 0D (0217) [4] 00536 bne NotLeadingZero
. 00537
.020A 09 [4] 00538 dex ; Skip a leading zero
. 00539
.020B 7A 0010 [6] 00540 dec Byt0
.020E 26 F6 (0206) [4] 00541 bne SkipLeadingZero ; Check the next one if more
. 00542
.0210 20 32 (0244) [4] 00543 bra BCD2ASCII ; All bytes are zero
. 00544
.0212 00545 ByteLoop
.0212 DE 0A [4] 00546 ldx Ptr0 ; Point back to the number to convert
.0214 09 [4] 00547 dex ; Point to next highest byte
. 00548
.0215 E6 00 [5] 00549 ldab ,X ; Get next highest byte of the number
. 00550
.0217 00551 NotLeadingZero
.0217 D7 12 [4] 00552 stab Byt2 ; Set it for shifting
. 00553
.0219 DF 0A [5] 00554 stx Ptr0 ; Remember the address of the last one shifted
. 00555
.021B 0D [2] 00556 sec ; Shift in extra bit for eight trips through loop
. 00557
.021C 20 1C (023A) [4] 00558 bra EnterBitLoop
. 00559
.021E 00560 BitLoop
.021E CE 002B [3] 00561 ldx #Dabble ; Point to the BCD digits
. 00562
.0221 D6 11 [3] 00563 ldab Byt1 ; Load count of number of digit bytes
.0223 27 0B (0230) [4] 00564 beq SkipDigitLoop ; Skip loop if none
. 00565
.0225 00566 DigitLoop
.0225 A6 00 [5] 00567 ldaa ,X ; Double pair of BCD digits with carry
.0227 A9 00 [5] 00568 adca ,X
.0229 19 [2] 00569 daa
.022A A7 00 [6] 00570 staa ,X
. 00571
.022C 09 [4] 00572 dex ; Point to next pair of BCD digits
. 00573
.022D 00574 IntoDigitLoop
.022D 5A [2] 00575 decb ; More BCD digits?
.022E 26 F5 (0225) [4] 00576 bne DigitLoop ; Yes
. 00577
.0230 00578 SkipDigitLoop
.0230 24 08 (023A) [4] 00579 bcc EnterBitLoop ; Carry out of accumulated digits?
. 00580
.0232 7C 0011 [6] 00581 inc Byt1 ; Add a new byte to the result
.0235 86 01 [2] 00582 ldaa #1
.0237 A7 00 [6] 00583 staa ,X
. 00584
.0239 0C [2] 00585 clc
. 00586
.023A 00587 EnterBitLoop
.023A 79 0012 [6] 00588 rol Byt2 ; Transfer upper bit to carry flag
.023D 26 DF (021E) [4] 00589 bne BitLoop ; Repeat if more
. 00590
.023F 7A 0010 [6] 00591 dec Byt0 ; Any more bytes of the number to convert?
.0242 26 CE (0212) [4] 00592 bne ByteLoop ; Repeat if more
. 00593
.0244 00594 BCD2ASCII
.0244 96 11 [3] 00595 ldaa Byt1 ; Any converted digits?
.0246 27 57 (029F) [4] 00596 beq NoDigits ; No
. 00597
.0248 86 2C [2] 00598 ldaa #<Dabble+1 ; Point to most significant BCD pair
.024A 90 11 [3] 00599 suba Byt1
.024C 97 0B [4] 00600 staa Ptr0+1
.024E 86 00 [2] 00601 ldaa #>Dabble+1
.0250 82 00 [2] 00602 sbca #0
.0252 97 0A [4] 00603 staa Ptr0
. 00604
.0254 CE 0018 [3] 00605 ldx #OutBuf+2 ; Point to result buffer
.0257 DF 0C [5] 00606 stx Ptr1
. 00607
.0259 DE 0A [4] 00608 ldx Ptr0 ; Get most significant BCD pair
.025B A6 00 [5] 00609 ldaa ,X
.025D 08 [4] 00610 inx
.025E DF 0A [5] 00611 stx Ptr0
.0260 DE 0C [4] 00612 ldx Ptr1
. 00613
.0262 16 [2] 00614 tab ; Clone it
. 00615
.0263 85 F0 [2] 00616 bita #$F0 ; Is the upper one zero?
.0265 27 17 (027E) [4] 00617 beq ConvertLowerOnly
.0267 20 0C (0275) [4] 00618 bra ConvertBoth
. 00619
.0269 00620 ASCIILoop
.0269 DF 0C [5] 00621 stx Ptr1
.026B DE 0A [4] 00622 ldx Ptr0 ; Get next most significant BCD pair
.026D A6 00 [5] 00623 ldaa ,X
.026F 08 [4] 00624 inx
.0270 DF 0A [5] 00625 stx Ptr0
.0272 DE 0C [4] 00626 ldx Ptr1
. 00627
.0274 16 [2] 00628 tab ; Clone it
. 00629
.0275 00630 ConvertBoth
.0275 44 [2] 00631 lsra ; Convert upper one to ASCII
.0276 44 [2] 00632 lsra
.0277 44 [2] 00633 lsra
.0278 44 [2] 00634 lsra
.0279 8A 30 [2] 00635 oraa #'0'
.027B A7 00 [6] 00636 staa ,X
.027D 08 [4] 00637 inx
. 00638
.027E 00639 ConvertLowerOnly
.027E C4 0F [2] 00640 andb #$F ; And then the lower one
.0280 CA 30 [2] 00641 orab #'0'
.0282 E7 00 [6] 00642 stab ,X
.0284 08 [4] 00643 inx
. 00644
.0285 7A 0011 [6] 00645 dec Byt1 ; More BCD pairs?
.0288 26 DF (0269) [4] 00646 bne ASCIILoop
. 00647
.028A DF 0C [5] 00648 stx Ptr1 ; Determine string length
.028C 96 0D [3] 00649 ldaa Ptr1+1
.028E 80 18 [2] 00650 suba #<OutBuf+2
. 00651
.0290 D6 16 [3] 00652 ldab OutBuf ; Is the number negative?
.0292 27 11 (02A5) [4] 00653 beq NumberNotNegative
. 00654
.0294 4C [2] 00655 inca ; Increment and store length byte
.0295 97 16 [4] 00656 staa OutBuf
. 00657
.0297 C6 2D [2] 00658 ldab #'-' ; Prepend minus sign
.0299 D7 17 [4] 00659 stab OutBuf+1
. 00660
.029B CE 0016 [3] 00661 ldx #OutBuf ; Point to the result
. 00662
.029E 39 [5] 00663 rts
. 00664
.029F 00665 NoDigits
.029F 86 30 [2] 00666 ldaa #'0' ; Emit single '0'
.02A1 97 18 [4] 00667 staa OutBuf+2
. 00668
.02A3 86 01 [2] 00669 ldaa #1 ; String length one
. 00670
.02A5 00671 NumberNotNegative
.02A5 97 17 [4] 00672 staa OutBuf+1
. 00673
.02A7 CE 0017 [3] 00674 ldx #OutBuf+1
. 00675
.02AA 39 [5] 00676 rts
00001 * Converting $FFFFFFFF
00002 * old $38F0 14576 cycles for call FormatLongword
00003 * new $0FED 4077 cycles
00004 *
00005 * Converting $00000001
00006 * old $37B3 14259 cycles for call FormatLongword
00007 * new $01F2 498 cycles
00008 *
00009 * Converting $00000000
00010 * old $37B0 14256 cycles for call FormatLongword
00011 * new $00B9 185 cycles
. 00127 ; Input:
. 00128 ; The absolute value of the number to convert is stored
. 00129 ; starting at OutBuf+2 in little-endian form
. 00130 ; A = number of bytes in the number
. 00131 ; B = 0 if number is positive, other if negative
. 00132 ; Dabble is the label of last byte of the buffer
. 00133 ;
. 00134 ; Output:
. 00135 ; HL contains the address of the resultant string
.0173 00156 Format:
.0173 4F [5] 00157 mov C,A ; Remember number of bytes to convert
.0174 5F [5] 00158 mov E,A
. 00159
.0175 78 [5] 00160 mov A,B ; Remember negativity
.0176 32 0333 [13] 00161 sta OutBuf
. 00162
.0179 AF [4] 00163 xra A ; Start with no bytes of BCD digits
.017A 47 [5] 00164 mov B,A
. 00165
.017B 21 0334 [10] 00166 lxi H,OutBuf+1 ; Point DE to most significant byte of number
.017E 57 [5] 00167 mov D,A
.017F 19 [10] 00168 dad D
.0180 EB [4] 00169 xchg
. 00170
.0181 00171 SkipLeadingZero:
.0181 1A [7] 00172 ldax D ; Get next highest byte of the number
.0182 B7 [4] 00173 ora A
.0183 C2 018F [10] 00174 jnz NotLeadingZero
. 00175
.0186 1B [5] 00176 dcx D ; Skip a leading zero
. 00177
.0187 0D [5] 00178 dcr C
.0188 C2 0181 [10] 00179 jnz SkipLeadingZero ; Check the next one if more
. 00180
.018B C3 01BC [10] 00181 jmp BIN2ASCII ; All bytes are zero
. 00182
.018E 00183 ByteLoop:
.018E 1A [7] 00184 ldax D ; Get next highest byte of the number
. 00185
.018F 00186 NotLeadingZero:
.018F 1B [5] 00187 dcx D ; Point to next lower byte
. 00188
.0190 D5 [11] 00189 push D ; Stash pointer to next byte
. 00190
.0191 5F [5] 00191 mov E,A ; Set it for shifting
. 00192
.0192 37 [4] 00193 stc ; Shift in extra bit for eight times thru loop
. 00194
.0193 C3 01AF [10] 00195 jmp EnterBitLoop
. 00196
.0196 00197 BitLoop:
.0196 21 0348 [10] 00198 lxi H,Dabble ; Point to the BCD digits
. 00199
.0199 04 [5] 00200 inr B ; Check count of number of digit bytes
.019A 05 [5] 00201 dcr B ; Test for zero but preserve carry flag
.019B CA 01A8 [10] 00202 jz SkipDigitLoop ; Skip loop if none
. 00203
.019E 50 [5] 00204 mov D,B
. 00205
.019F 00206 DigitLoop:
.019F 7E [7] 00207 mov A,M ; Double pair of BCD digits with carry
.01A0 8E [7] 00208 adc M
.01A1 27 [4] 00209 daa
.01A2 77 [7] 00210 mov M,A
. 00211
.01A3 2B [5] 00212 dcx H ; Point to next pair of BCD digits
. 00213
.01A4 00214 IntoDigitLoop:
.01A4 15 [5] 00215 dcr D ; More BCD digits?
.01A5 C2 019F [10] 00216 jnz DigitLoop ; Yes
. 00217
.01A8 00218 SkipDigitLoop:
.01A8 D2 01AF [10] 00219 jnc EnterBitLoop ; Carry out of accumulated digits?
. 00220
.01AB 04 [5] 00221 inr B ; Add new byte to the result
.01AC 36 01 [10] 00222 mvi M,1
. 00223
.01AE B7 [4] 00224 ora A ; Clear carry flag
. 00225
.01AF 00226 EnterBitLoop:
.01AF 7B [5] 00227 mov A,E
.01B0 17 [4] 00228 ral ; Transfer upper bit to carry flag
.01B1 5F [5] 00229 mov E,A
. 00230
.01B2 1C [5] 00231 inr E
.01B3 1D [5] 00232 dcr E
.01B4 C2 0196 [10] 00233 jnz BitLoop ; Repeat if more
. 00234
.01B7 D1 [10] 00235 pop D ; Recover pointer to next byte
. 00236
.01B8 0D [5] 00237 dcr C ; Any more bytes of the number to convert?
.01B9 C2 018E [10] 00238 jnz ByteLoop ; Repeat if more
. 00239
.01BC 00240 BIN2ASCII:
.01BC 21 0335 [10] 00241 lxi H,OutBuf+2 ; Point to result buffer
. 00242
.01BF 78 [5] 00243 mov A,B ; Any converted digits?
.01C0 B7 [4] 00244 ora A
.01C1 CA 01F4 [10] 00245 jz NoDigits ; No
. 00246
.01C4 11 0349 [10] 00247 lxi D,Dabble+1 ; Point to most significant BCD pair
.01C7 7B [5] 00248 mov A,E
.01C8 90 [4] 00249 sub B
.01C9 5F [5] 00250 mov E,A
.01CA 7A [5] 00251 mov A,D
.01CB DE 00 [7] 00252 sbi 0
.01CD 57 [5] 00253 mov D,A
. 00254
.01CE 1A [7] 00255 ldax D ; Get most significant BCD pair
. 00256
.01CF E6 F0 [7] 00257 ani 0F0h ; Is the upper one zero?
.01D1 CA 01DF [10] 00258 jz ConvertLowerOnly
. 00259
.01D4 00260 ASCIILoop:
.01D4 1A [7] 00261 ldax D ; Get next most significant BCD pair
.01D5 0F [4] 00262 rrc ; Convert upper one to ASCII
.01D6 0F [4] 00263 rrc
.01D7 0F [4] 00264 rrc
.01D8 0F [4] 00265 rrc
.01D9 E6 0F [7] 00266 ani 0Fh
.01DB F6 30 [7] 00267 ori '0'
.01DD 77 [7] 00268 mov M,A
.01DE 23 [5] 00269 inx H
. 00270
.01DF 00271 ConvertLowerOnly:
.01DF 1A [7] 00272 ldax D ; And then the lower one
.01E0 13 [5] 00273 inx D
.01E1 E6 0F [7] 00274 ani 0Fh
.01E3 F6 30 [7] 00275 ori '0'
.01E5 77 [7] 00276 mov M,A
.01E6 23 [5] 00277 inx H
. 00278
.01E7 05 [5] 00279 dcr B
.01E8 C2 01D4 [10] 00280 jnz ASCIILoop
. 00281
.01EB 7D [5] 00282 mov A,L ; Store string length
.01EC DE 35 [7] 00283 sbi OutBuf+2 and 0FFh
.01EE 32 0334 [13] 00284 sta OutBuf+1
. 00285
.01F1 C3 01F9 [10] 00286 jmp FinishFormat
. 00287
.01F4 00288 NoDigits:
.01F4 36 30 [10] 00289 mvi M,'0' ; Emit single '0'
. 00290
.01F6 2B [5] 00291 dcx H ; String length one
.01F7 36 01 [10] 00292 mvi M,1
. 00293
.01F9 00294 FinishFormat:
.01F9 21 0334 [10] 00295 lxi H,OutBuf+1 ; Point to the result
. 00296
.01FC 3A 0333 [13] 00297 lda OutBuf ; Was number negative?
.01FF B7 [4] 00298 ora A
.0200 CA 0209 [10] 00299 jz NumberNotNegative ; No
. 00300
.0203 7E [7] 00301 mov A,M ; Get and increment length byte
.0204 3C [5] 00302 inr A
. 00303
.0205 36 2D [10] 00304 mvi M,'-' ; Prepend minus sign
. 00305
.0207 2B [5] 00306 dcx H ; Point to the new result
. 00307
.0208 77 [7] 00308 mov M,A ; Store new length
. 00309
.0209 00310 NumberNotNegative:
.0209 C9 [10] 00311 ret
00002 ; old $7F53 32595 cycles for call FormatLongword
00003 ; new $2359 9049 cycles
00004 ; new $1F18 7960 cycles
00005 ;
00006 ; Converting $00000001
00007 ; old $7CEE 31982 cycles for call FormatLongword
00008 ; new $055A 1370 cycles
00009 ; new $04C5 1221 cycles
00010 ;
00011 ; Converting $00000000
00012 ; old $7D05 32005 cycles for call FormatLongword
00013 ; new $01E0 480 cycles
00014 ; new $01A2 418 cycles
ld a,l
rla
ld de,258
or a ;clears carry.
ld (dest),hl ;saved
ldd #258
pshs d
ldb s1
sex
sub d,S++
std dest
ldb s1
sex
pshs d
ldd #258
sub d,S++
std dest
00001 * 378834 ($5C7D2) cycles
00002 * 300821 ($49715) cycles after inlining subroutines
00003
0000 005F 00004 Free fdb Heap
0002 0000 00005 Root fdb 0
0004 0000 00006 New fdb 0
0006 0000 0000 00007 Total fdb 0,0
000A 0BB7 00008 I fdb 2999
00009
00010 *
00011 * Allocate a node
00012 *
000C 00013 Alloc
000C D6 01 [3] 00014 ldab Free+1 ; Allocate a node
000E D7 05 [4] 00015 stab New+1 ; Return it in New
00016
0010 CB 04 [2] 00017 addb #4 ; Point to free memory
0012 D7 01 [4] 00018 stab Free+1
0014 D6 00 [3] 00019 ldab Free
0016 D7 04 [4] 00020 stab New
0018 C9 00 [2] 00021 adcb #0
001A D7 00 [4] 00022 stab Free
00023
001C 39 [5] 00024 rts
00025
00026 *
00027 * Prepend a node to the list
00028 *
001D 00029 Prepend
001D 8D ED (000C) [8] 00030 bsr Alloc ; Allocate a new node
00031
001F DE 04 [4] 00032 ldx New ; Point to the new node
00033
0021 D6 02 [3] 00034 ldab Root ; Point next of new node to Root
0023 E7 00 [6] 00035 stab ,X
0025 D6 03 [3] 00036 ldab Root+1
0027 E7 01 [6] 00037 stab 1,X
00038
0029 A7 03 [6] 00039 staa 3,X ; Store value in node
002B D6 0A [3] 00040 ldab I
002D E7 02 [6] 00041 stab 2,X
00042
002F DF 02 [5] 00043 stx Root ; This is now the first node
00044
0031 39 [5] 00045 rts
00046
00047 *
00048 * Traverse the list and sum the values
00049 *
0032 00050 Sum
0032 DE 02 [4] 00051 ldx Root
0034 4F [2] 00052 clra
0035 5F [2] 00053 clrb
00054
0036 00055 SumLoop
0036 EB 03 [5] 00056 addb 3,X ; Add value of node to sum
0038 A9 02 [5] 00057 adca 2,X
003A 24 08 (0044) [4] 00058 bcc NoCarry
00059
003C 7C 0007 [6] 00060 inc Total+1
00061
003F 26 03 (0044) [4] 00062 bne NoCarry
00063
0041 7C 0006 [6] 00064 inc Total
00065
0044 00066 NoCarry
0044 EE 00 [6] 00067 ldx ,X ; Point to the next node
0046 26 EE (0036) [4] 00068 bne SumLoop ; Until end of list
00069
0048 97 08 [4] 00070 staa Total+2
004A D7 09 [4] 00071 stab Total+3
00072
004C 39 [5] 00073 rts
00074
00075 *
00076 *
00077 *
004D 00078 Main
004D 96 0B [3] 00079 ldaa I+1 ; Get low byte of node value
00080
004F 20 01 (0052) [4] 00081 bra IntoLoop
00082
0051 00083 Loop
0051 4A [2] 00084 deca
00085
0052 00086 IntoLoop
0052 8D C9 (001D) [8] 00087 bsr Prepend
00088
0054 4D [2] 00089 tsta ; Low byte of count zero?
0055 26 FA (0051) [4] 00090 bne Loop ; No, no borrow
00091
0057 7A 000A [6] 00092 dec I ; Borrow from upper byte
005A 2A F5 (0051) [4] 00093 bpl Loop ; Done if it goes negative
00094
005C 8D D4 (0032) [8] 00095 bsr Sum ; Traverse the list and add them up
00096
005E 3F [12] 00097 swi
00098
005F 00099 Heap
00100
004D 00101 end Main
00001 ; 519567 ($7ED8F) cycles
00002 ; 447558 ($6D446) after inlining subroutines
00003
0000 026F 00004 Free fdb Heap
00009
0200 00010 org $200
00011
00012 ;
00013 ; Allocate a node
00014 ;
0200 00015 Alloc:
0200 A5 00 [3] 00016 lda Free ; Allocate a node
0202 85 04 [3] 00017 sta New ; Return it in New
00018
0204 18 [2] 00019 clc ; Point to free memory
0205 69 04 [2] 00020 adc #4
0207 85 00 [3] 00021 sta Free
0209 A5 01 [3] 00022 lda Free+1
020B 85 05 [3] 00023 sta New+1
020D 69 00 [2] 00024 adc #0
020F 85 01 [3] 00025 sta Free+1
00026
0211 60 [6] 00027 rts
00028
00029 ;
00030 ; Prepend a node to the list
00031 ;
0212 00032 Prepend:
0212 20 0200 [6] 00033 jsr Alloc ; Allocate a new node
00034
0215 A0 00 [2] 00035 ldy #0 ; Point to the new node
00036
0217 A5 02 [3] 00037 lda Root ; Point next of new node to Root
0219 91 04 [6] 00038 sta (New),Y
021B C8 [2] 00039 iny
021C A5 03 [3] 00040 lda Root+1
021E 91 04 [6] 00041 sta (New),Y
0220 C8 [2] 00042 iny
00043
0221 A5 0A [3] 00044 lda I ; Store value in node
0223 91 04 [6] 00045 sta (New),Y
0225 C8 [2] 00046 iny
0226 A5 0B [3] 00047 lda I+1
0228 91 04 [6] 00048 sta (New),Y
00049
022A A5 04 [3] 00050 lda New ; This is now the first node
022C 85 02 [3] 00051 sta Root
022E A5 05 [3] 00052 lda New+1
0230 85 03 [3] 00053 sta Root+1
00054
0232 60 [6] 00055 rts
00056
00057 ;
00058 ; Traverse the list and sum the values
00059 ;
0233 00060 NoCarry:
0233 A0 00 [2] 00061 ldy #0 ; Point to the next node
0235 B1 02 [5/6] 00062 lda (Root),Y
0237 AA [2] 00063 tax
0238 C8 [2] 00064 iny
0239 B1 02 [5/6] 00065 lda (Root),Y
023B 85 03 [3] 00066 sta Root+1
023D 86 02 [3] 00067 stx Root
00068
023F 05 02 [3] 00069 ora Root
0241 F0 1A (025D) [2/3] 00070 beq Summed ; Until end of list
00071
0243 00072 Sum:
0243 18 [2] 00073 clc ; Add value of node to sum
0244 A0 02 [2] 00074 ldy #2
0246 A5 06 [3] 00075 lda Total
0248 71 02 [5/6] 00076 adc (Root),Y
024A 85 06 [3] 00077 sta Total
024C C8 [2] 00078 iny
024D A5 07 [3] 00079 lda Total+1
024F 71 02 [5/6] 00080 adc (Root),Y
0251 85 07 [3] 00081 sta Total+1
0253 90 DE (0233) [2/3] 00082 bcc NoCarry
00083
0255 E6 08 [5] 00084 inc Total+2
00085
0257 D0 DA (0233) [2/3] 00086 bne NoCarry
00087
0259 E6 09 [5] 00088 inc Total+3
00089
025B D0 D6 (0233) [2/3] 00090 bne NoCarry ; Always branches
00091
025D 00092 Summed:
025D 60 [6] 00093 rts
00094
00095 ;
00096 ;
00097 ;
025E 00098 NoBorrow:
025E C6 0A [5] 00099 dec I
00100
0260 00101 Main:
0260 20 0212 [6] 00102 jsr Prepend
00103
0263 A5 0A [3] 00104 lda I ; Low byte of count zero?
0265 D0 F7 (025E) [2/3] 00105 bne NoBorrow ; No, no borrow
00106
0267 C6 0B [5] 00107 dec I+1 ; Borrow from upper byte
0269 10 F3 (025E) [2/3] 00108 bpl NoBorrow ; Done if it goes negative
00109
026B 20 0243 [6] 00110 jsr Sum ; Traverse the list and add them up
00111
026E 00 [7] 00112 brk
00113
026F 00114 Heap:
00115
0260 00116 end Main
00001 ; 991228 (0F1FFCh) cycles
00002 ; 829201 (0CA711h) cycles after inlining subroutines
00003
0100 00004 org 100h
00005
00006 ;
00007 ; Allocate a node
00008 ;
0100 00009 Alloc:
0100 2A 0163 [16] 00010 lhld Free ; Allocate a node
00011
0103 11 0004 [10] 00012 lxi D,4 ; Point to free memory
0106 EB [4] 00013 xchg ; Keep New in DE
0107 19 [10] 00014 dad D
0108 22 0163 [16] 00015 shld Free
00016
010B EB [4] 00017 xchg ; Return New in HL
00018
010C C9 [10] 00019 ret
00020
00021 ;
00022 ; Prepend a node to the list
00023 ;
010D 00024 Prepend:
010D CD 0100 [17] 00025 call Alloc ; Allocate a new node
00026
0110 3A 0165 [13] 00027 lda Root ; Point next of new node to Root
0113 77 [7] 00028 mov M,A
0114 3A 0166 [13] 00029 lda Root+1
0117 22 0165 [16] 00030 shld Root ; This is the new first node
011A 23 [5] 00031 inx H
011B 77 [7] 00032 mov M,A ; Finish pointer to previous Root
011C 23 [5] 00033 inx H
00034
011D 71 [7] 00035 mov M,C ; Store value in node
011E 23 [5] 00036 inx H
011F 70 [7] 00037 mov M,B
00038
0120 C9 [10] 00039 ret
00040
00041 ;
00042 ; Traverse the list and sum the values
00043 ;
0121 00044 Sum:
0121 2A 0165 [16] 00045 lhld Root
0124 11 0000 [10] 00046 lxi D,0
00047
0127 00048 SumLoop:
0127 23 [5] 00049 inx H ; Add value of node to sum
0128 23 [5] 00050 inx H
0129 4E [7] 00051 mov C,M
012A 23 [5] 00052 inx H
012B 46 [7] 00053 mov B,M
012C EB [4] 00054 xchg
012D 09 [10] 00055 dad B
012E EB [4] 00056 xchg
012F D2 013B [10] 00057 jnc NoCarry
00058
0132 E5 [11] 00059 push H ; Carry to high word
0133 2A 016B [16] 00060 lhld Total+2
0136 23 [5] 00061 inx H
0137 22 016B [16] 00062 shld Total+2
013A E1 [10] 00063 pop H
00064
013B 00065 NoCarry:
013B 2B [5] 00066 dcx H ; Point to the next node
013C 2B [5] 00067 dcx H
013D 7E [7] 00068 mov A,M
013E 2B [5] 00069 dcx H
013F 6E [7] 00070 mov L,M
0140 67 [5] 00071 mov H,A
00072
0141 B5 [4] 00073 ora L ; Until end of list
0142 C2 0127 [10] 00074 jnz SumLoop
00075
0145 EB [4] 00076 xchg
0146 22 0169 [16] 00077 shld Total
00078
0149 C9 [10] 00079 ret
00080
00081 ;
00082 ;
00083 ;
014A 00084 Main:
014A 2A 016D [16] 00085 lhld I ; Get count
014D 4D [5] 00086 mov C,L
014E 44 [5] 00087 mov B,H
00088
014F C3 0153 [10] 00089 jmp IntoLoop
00090
0152 00091 NoBorrow:
0152 0D [5] 00092 dcr C
00093
0153 00094 IntoLoop:
0153 CD 010D [17] 00095 call Prepend
00096
0156 0D [5] 00097 dcr C ; Low byte of count zero?
0157 0C [5] 00098 inr C
0158 C2 0152 [10] 00099 jnz NoBorrow ; No, no borrow
00100
015B 05 [5] 00101 dcr B ; Borrow from upper byte
015C F2 0152 [10] 00102 jp NoBorrow ; Done if it goes negative
00103
015F CD 0121 [17] 00104 call Sum ; Traverse the list and add them up
00105
0162 76 [7] 00106 hlt
00107
0163 016F 00108 Free dw Heap
0165 0000 00109 Root dw 0
0167 0000 00110 New dw 0
0169 0000 0000 00111 Total dw 0,0
016D 0BB7 00112 I dw 2999
00113
016F 00114 Heap
00115
014A 00116 end Main
00001 * 363754 ($58CEA) cycles original 6800 source code
00002 * 243378 ($3B6B2) cycles
00003 * 171350 ($29D56) cycles after inlining subroutines
00004
0000 0044 00005 Free fdb Heap
0002 0000 00006 Root fdb 0
0004 0000 00007 New fdb 0
0006 0000 0000 00008 Total fdb 0,0
000A 0BB7 00009 I fdb 2999
00010
00011 *
00012 * Allocate a node
00013 *
000C 00014 Alloc
000C 30 C4 [4] 00015 leax ,U ; Allocate a node
00016
000E 33 44 [5] 00017 leau 4,U ; Point to free memory
00018
0010 39 [5] 00019 rts
00020
00021 *
00022 * Prepend a node to the list
00023 *
0011 00024 Prepend
0011 8D F9 (000C) [7] 00025 bsr Alloc ; Allocate a new node
00026
0013 DC 02 [5] 00027 ldd Root ; Point next of new node to Root
0015 ED 84 [5] 00028 std ,X
00029
0017 10AF 02 [7] 00030 sty 2,X ; Store value in node
00031
001A 9F 02 [5] 00032 stx Root ; This is now the first node
00033
001C 39 [5] 00034 rts
00035
00036 *
00037 * Traverse the list and sum the values
00038 *
001D 00039 Sum
001D 9E 02 [5] 00040 ldx Root
001F CC 0000 [3] 00041 ldd #0 ; Clear total
0022 1F 03 [6] 00042 tfr D,U
00043
0024 00044 SumLoop
0024 E3 02 [7] 00045 addd 2,X ; Add value of node to sum
0026 24 02 (002A) [3] 00046 bcc NoCarry
00047
0028 33 41 [5] 00048 leau 1,U
00049
002A 00050 NoCarry
002A AE 84 [5] 00051 ldx ,X ; Point to the next node
002C 26 F6 (0024) [3] 00052 bne SumLoop ; Until end of list
00053
002E DD 08 [5] 00054 std Total+2
0030 DF 06 [5] 00055 stu Total
00056
0032 39 [5] 00057 rts
00058
00059 *
00060 *
00061 *
0033 00062 Main
0033 109E 0A [6] 00063 ldy I ; Get node value
0036 CE 0044 [3] 00064 ldu #Heap ; Point to free memory
00065
0039 00066 Loop
0039 8D D6 (0011) [7] 00067 bsr Prepend
00068
003B 31 3F [5] 00069 leay -1,Y
00070
003D 26 FA (0039) [3] 00071 bne Loop
00072
003F 8D D0 (0011) [7] 00073 bsr Prepend ; And once for 0 just to make it fair
00074
0041 8D DA (001D) [7] 00075 bsr Sum ; Traverse the list and add them up
00076
0043 3F [19] 00077 swi
00078
0044 00079 Heap
00080
0033 00081 end Main
