Comparisons and contrasts
barrym95838
Re: Comparisons and contrasts
Post by barrym95838 »
Wow, 30% smaller code is very impressive!
I don't think that's typical without careful source changes to take advantage of the more flexible addressing modes. The U and Y registers carried significant binary baggage on the 6809/6309, but the 68HC12 treats D, S, X and Y all as first class citizens, providing a very tidy 16-bit environment. There wasn't any room for U in that encoding, so it went buh-bye. Not a worrisome loss in most cases, IMO, since the U register seems to have been fading from view for years.
litwr
Post by litwr »
This article confirms my results which show that the 6803 is faster than the 6809.
Our benchmark tests prove that using an 8-bit Motorola 6803 microprocessor, the MC-10 performs arithmetic computations in Basic 10% faster than the Color Computer without sacrificing accuracy.
So the cheapest Tandy computer is faster than more expensive one!
This sounds almost unrealistic because the 6809 has a very good code density. Indeed it may be true but it is very difficult to prove.
BillG
Post by BillG »
The U register is only disadvantaged in the CMPU instruction on the 6809. Motorola surmised that the stack pointer is not directly manipulated as much as a numeric quantity so it gave the U register the single-byte forms of instructions while penalizing the S register.
While the S and Y registers are penalized with respect to loading/storing/comparing on the 6809, there is no penalty using them for addressing.
Other than implementing FORTH, there is little need for a second stack, so I do not miss that benefit of the U register. What I do miss is having a third general purpose 16-bit register.
Where the 6801/6803/68HC11/68HC12 gains over the 6809 are:
* Single byte forms of INX/DEX/INY/DEY
* Single byte forms of push and pull of A/B/P
* One or two-byte forms of TAB/TBA/ABA/SBA/CBA instead of sequences involving the stack
As for the 30% number, from the 68HC12 manual https://www.nxp.com/docs/en/data-sheet/HCS12COREUG.pdf
The relative size for code for 68HC11 vs. code for HCS12 has also been tested by rewriting several small programs from scratch. In these cases, the HCS12 code is typically about 30% smaller. These savings are mostly due to improved indexed addressing. A C program compiled for the HCS12 is about 30% smaller than the same program compiled for the 68HC11. The saving are largely due to improved indexing.
BillG
Post by BillG »
This post gave me an idea out of left field: viewtopic.php?p=90284#p90284
By coding a conditional branch to *-1, something useful can be done if the $FF opcode cooperates.
Unfortunately, only the Z80 qualifies.
by coding
    jr      C,$-1
a reset 38h is done if the carry flag is set.
This is a savings of one byte per use and three cycles when the branch is not taken compared to
    jp      C,38h
Relative conditional branches are available for C, NC, Z, NZ.
litwr
Post by litwr »
I have added Mandelbrot results for the 8080 and 68008. It seems the 68008 is very slow. IMHO Clive Sinclair should have chosen the 8088 for his QL and later replaced it with the NEC V20. It is sad that the 68516 was not available that time. The results also show that the proper Z80 code is much faster than the 8080 code.
Sarah Walker's PCem is cycle accurate, apparently.
https://retrocomputing.stackexchange.co ... 6-emulator
I have checked this emulator more carefully and found out that it emulates the prefetch queue. So it is really a great emulator. Though, IMHO, it is anyway slightly faster (about 5%) for the PC 5150 than real hardware.
BillG wrote:
    jr      C,$-1
Such tricks are also possible for the 6502 branches it gives us the NMOS 6502 undocumented INCSBC abs,X instruction. :)
Some processors (the PDP-11, ARM) allow us to use PC as an ordinary register. It is quite a challenge to write something like CMPB PC,R0 and make program slightly faster and smaller. :)
BillG
Post by BillG »
The 68008 is heavily penalized because the smallest instruction is two bytes in length, meaning two, four or more fetch cycles per instruction.
A 5% error would make it a good, not great emulator.
Does it offer adjustments such as adding a wait state for video memory access?
litwr wrote:
BillG wrote:
    jr      C,$-1
That would tie you to a fraction of 65xx systems.
jr C,$-1 is significant because it makes error checking cheaper. Structured Exception Handling (SEH) had promised to solve that problem, but that has not proved out in practice.
litwr
Post by litwr »
No, but IMHO it is great because there is no better old IBM PC family hardware emulator. The only alternative I know is PCE but it seems it is deserted 10 years ago. Of course, PCEM is not perfect. For example, Norton Sysinfo reports that the emulated PC 5160 uses the NEC V20. :) But it is generally more accurate than PCE.
Snial
Post by Snial »
Calculating dest = constant - signed byte? Z80:
  ld hl,(S1) ;don't care about h, contains garbage.
  ld a,l
  rla
  sbc a,a ;=> a-a-0 or a-a-1 ie. 0 or 0xff.
  ld h,a ;hl now sign extended.
  ld de,258
  or a ;clears carry.
  sbc hl,de ;hl=258-S1
  ld (dest),hl ;saved
So, z80 is quite straight forward, 16b. 6809.
  ldd #258
  pshs d
  ldb s1
  sex
  sub d,S++
  std dest
14 bytes, again very straight-forward.
I'm far more experienced on the Z80 than the 6502 and I have enough familiarity with the 6809 to happily code on it. The big difference between how I think when I'm coding the Z80 vs 6502 vs 6809 is as follows.
The Z80 is best thought of as a hybrid 8-bit / 16-bit CPU. So, you have quite a lot of tools (instructions) available to do things conveniently and you flip between using the 8-bit tools and the 16-bit tools. The important thing though is to arrange the tools on your workbench (registers) so they don't get in each others' way. And this is done by maintaining a priority of preferences for the 8-bit vs 16-bit tools. For the 8-bit world you need 'a' the most; then all the other regs are a cache of your most useful temps, with 'b' as the lowest priority since that's used for 'djnz' loops.
For the 16-bit world you need 'hl' the most, then 'de' (because you can swap hl and de easily); then bc, which you also need for 16-bit loops.
Because the 16-bit world sits side-by-side with the 8-bit world, you tend to want to use regs in the opposite priority order to the 16-bit regs (so they don't clash). Then, in other priority order: use the stack as a simple LIFO (which will be easier if you factor your code), use alternate regs if you can decompose the problem into 2 to 4 independent sub-problems; finally, use IX and IY if you have to deal with some infrequent, but randomly accessed data structures (since they're really inefficient).
The 6502 is kinda like the other way around. The tools (instruction set) are less convenient, but you have efficient access to a small worktop (A, X, Y) and good, comprehensive access to a larger bench top (zero-page). Also, the 6502 is more like high-altitude programming vs Z80 jungle type programming: clear and austere vs messy, but plentiful. On the 6502 you have a much bigger set of temps; much easier access to random data via indexed and indirect modes; more challenges when it comes to 16-bit operations and again, I would prioritise X and Y for loop access. This means that problems get restructured accordingly.
I find the best way to think about the 6809 is as a nearly 16-bit, high-level language oriented CPU and you're the compiler. So, you have a straight-forward stack model and the stack is your friend. In addition, you have 3 index registers for some combination of data structures, pointers and loop counters. So, it's easy to code on a 6809, but the code is only going to be moderately optimised. Unlike the 6502 and Z80 where effort scales quite well with optimisation, a 6809 requires disproportionate effort for moderate optimisation, so it's far less likely to be worth it.
Anyway - that's just my personal take :-)
barrym95838
Thank you for sharing, Snial. I have sincere respect for those who can write good code for the (z)8xxx (the HL style) and 6xxx (the ,X ,Y style) by shifting a gear in their brain. My brain doesn't have that gear, and (z)8xxx code inevitably winds up giving me a headache if I study it too long. I would try to re-code your example for the 65xx (definitely using the 6809 code as the source), but I have to get to work. Maybe tonight ...
[Edit: ... or during a break in the action at work.
6502:
; dest=const-S1
    lda #<const
    sec
    sbc S1
    sta dest
    lda #>const
    sbc #0
    sta dest+1
    bit S1
    bpl label
    inc dest+1      ; adjust for S1<0
label:
19 bytes.
If you don't need to save the effective address for later, you can let the 6502 calculate it on-the-fly:
    lda S1           ; signed 8-bit displacement
    eor #$7f
    tay
    lda const-$7f,y  ; access target (const-S1)
8 bytes.
(I think you're calculating S1-const instead of const-S1, but I've been wrong before ...)
BillG
Post by BillG »
Some time ago, I posted implementations of binary to decimal conversion using the Double Dabble algorithm for several microprocessors:
https://talk.dallasmakerspace.org/t/pro ... /18852/323
https://en.wikipedia.org/wiki/Double_dabble
Rudla posted code to convert a binary number to packed BCD:
viewtopic.php?f=2&t=6579
I recognized that his code bore a definite resemblance to Double Dabble, but it was clearly not the same. Studying his implementation allowed me to step back and see the forest from the trees of the details of the Double Dabble algorithm. Improvements from a straight interpretation of Double Dabble include:
* all of that testing of and adding to individual BCD digits is merely a way to perform a "decimal adjustment" when the hardware does not directly support it. Hardware supporting decimal adjustment can combine the shifting and fiddling by adding to itself (doubling) with the decimal arithmetic mode built into the 6502 or a DAA decimal adjust instruction following the addition on other processors.
* shifting only one byte of the number being converted at a time instead of shifting the entire number. The savings become much more significant for larger numbers.
* growing the result as digits are added instead of needlessly shifting an ocean of zeroes in a large pre-cleared buffer.
I improveed on Rudla's implementation by starting with no bytes of result instead of one byte containing zero, saving up to seven shifts of the byte. I also did a minor tweak improving the innermost loop.
Using what I learned, I rewrote my conversion code from scratch, making it faster and simpler in the process.
My design is based on maximum reuse of memory and is intended to produce a printable character string instead of just a packed BCD number. Because the maximum number to be converted is eight bytes, the buffer is placed in the zero-page for maximum efficiency. The number to be converted is copied to the low end of the output buffer with the least-significant byte at the lowest address. The converted BCD digits grow downward from the end of the buffer and do not overlap the number until after its bytes are already consumed by the shifting. Because the largest number to be converted is 64 bits, it was reasonable to place the buffer in the zero page.
While I will not claim that these are the fastest routines to convert 32 and 64 bit integers to ASCII decimal strings, I am confident they are among the best.
Someone posted code to do decimal conversion to this forum including the time to convert $FFFFFFFF, but I cannot find it now to compare.
The 6502 version:
.                         00191 ; Input:
.                         00192 ;       The absolute value of the number to convert is stored
.                         00193 ;         starting at OutBuf+2 in little-endian form
.                         00194 ;       A = number of bytes in the number
.                         00195 ;       Dabble is the label of last byte of the buffer
.                         00196 ;       OutBuf+0 = 0 if number is negative, other if negative
.                         00197 ;
.                         00198 ; Output:
.                         00199 ;       A:X contains the address of the resultant string
.                         00200 ;
.                         00201 ; Uses:
.                         00202 ;       Byt0 = number of bytes to convert
.                         00203 ;       Byt1 = number of packed BCD bytes in result
.                         00204 ;       Byt2 = bits of number being shifted
.206E                     00225 Format:
.206E 85 12           [3] 00226          sta    Byt0      ; Remember number of bytes to convert
.2070 AA              [2] 00227          tax              ; Use it as index into the number
.                         00228
.2071 A9 00           [2] 00229          lda    #0        ; Start with no bytes of BCD digits
.2073 85 13           [3] 00230          sta    Byt1
.                         00231
.2075 F8              [2] 00232          sed              ; Switch to decimal mode
.                         00233
.2076                     00234 SkipLeadingZero:
.2076 B5 19           [4] 00235          lda    OutBuf+1,X  ; Get next highest byte of the number
.2078 D0 07 (2081)  [2/3] 00236          bne    NotLeadingZero
.                         00237
.207A CA              [2] 00238          dex              ; Skip a leading zero
.                         00239
.207B D0 F9 (2076)  [2/3] 00240          bne    SkipLeadingZero ; Check the next one if more
.                         00241
.207D F0 2F (20AE)  [2/3] 00242          beq    BCD2ASCII ; All bytes are zero
.                         00243
.207F                     00244 ByteLoop:
.207F B5 19           [4] 00245          lda    OutBuf+1,X  ; Get next highest byte of the number
.                         00246
.2081                     00247 NotLeadingZero:
.2081 85 14           [3] 00248          sta    Byt2      ; Set it for shifting
.                         00249
.2083 86 12           [3] 00250          stx    Byt0      ; Remember the address of the last one shifted
.                         00251
.2085 38              [2] 00252          sec              ; Shift in extra bit for eight trips through loop
.                         00253
.2086 B0 12 (209A)  [2/3] 00254          bcs    EnterBitLoop ; Always branches
.                         00255
.2088                     00256 BitLoop:
.2088 A2 2D           [2] 00257          ldx    #Dabble   ; Point to the BCD digits
.                         00258
.208A A4 13           [3] 00259          ldy    Byt1      ; Load count of number of digit bytes
.208C F0 0A (2098)  [2/3] 00260          beq    SkipDigitLoop ; Skip loop if none
.                         00261
.208E                     00262 DigitLoop:
.208E B5 00           [4] 00263          lda    0,X       ; Double pair of BCD digits with carry
.2090 75 00           [4] 00264          adc    0,X
.2092 95 00           [4] 00265          sta    0,X
.                         00266
.2094 CA              [2] 00267          dex              ; Point to next pair of BCD digits
.                         00268
.2095                     00269 IntoDigitLoop:
.2095 88              [2] 00270          dey              ; More BCD digits?
.2096 D0 F6 (208E)  [2/3] 00271          bne    DigitLoop ; Yes
.                         00272
.2098                     00273 SkipDigitLoop:
.2098 B0 0B (20A5)  [2/3] 00274          bcs    Extend    ; Carry out of accumulated digits?
.                         00275
.209A                     00276 EnterBitLoop:
.209A 26 14           [5] 00277          rol    Byt2      ; Transfer upper bit to carry flag
.209C D0 EA (2088)  [2/3] 00278          bne    BitLoop   ; Repeat if more
.                         00279
.209E A6 12           [3] 00280          ldx    Byt0      ; Point back to the number to convert
.                         00281
.20A0 CA              [2] 00282          dex              ; Any more bytes of the number to convert?
.20A1 D0 DC (207F)  [2/3] 00283          bne    ByteLoop  ; Repeat if more
.                         00284
.20A3 F0 09 (20AE)  [2/3] 00285          beq    BCD2ASCII ; Always branches to unpacking stage
.                         00286
.20A5                     00287 Extend:
.20A5 E6 13           [5] 00288          inc    Byt1      ; Add a new byte to the result
.20A7 A9 01           [2] 00289          lda    #1
.20A9 95 00           [4] 00290          sta    0,X
.                         00291
.20AB 18              [2] 00292          clc
.20AC 90 EC (209A)  [2/3] 00293          bcc    EnterBitLoop ; Always branches
.                         00294
.20AE                     00295 BCD2ASCII:
.20AE D8              [2] 00296          cld              ; Return to binary mode
.                         00297
.20AF A5 13           [3] 00298          lda    Byt1      ; Any converted digits?
.20B1 F0 42 (20F5)  [2/3] 00299          beq    NoDigits  ; No
.                         00300
.20B3 38              [2] 00301          sec
.20B4 A9 2E           [2] 00302          lda    #Dabble+1  ; Point to most significant BCD pair
.20B6 E5 13           [3] 00303          sbc    Byt1
.20B8 A8              [2] 00304          tay
.                         00305
.20B9 A2 1A           [2] 00306          ldx    #<OutBuf+2  ; Point to result buffer
.                         00307
.20BB B9 0000       [4/5] 00308          lda    0,Y       ; Get most significant BCD pair
.                         00309
.20BE 29 F0           [2] 00310          and    #$F0      ; Is the upper one zero?
.20C0 F0 0E (20D0)  [2/3] 00311          beq    UpperZero
.20C2 D0 03 (20C7)  [2/3] 00312          bne    ConvertBoth
.                         00313
.20C4                     00314 ASCIILoop:
.20C4 B9 0000       [4/5] 00315          lda    0,Y       ; Get next most significant BCD pair
.                         00316
.20C7                     00317 ConvertBoth:
.20C7 4A              [2] 00318          lsr    A         ; Convert upper one to ASCII
.20C8 4A              [2] 00319          lsr    A
.20C9 4A              [2] 00320          lsr    A
.20CA 4A              [2] 00321          lsr    A
.20CB 09 30           [2] 00322          ora    #'0'
.20CD 95 00           [4] 00323          sta    0,X
.20CF E8              [2] 00324          inx
.                         00325
.20D0                     00326 UpperZero:
.20D0 B9 0000       [4/5] 00327          lda    0,Y
.20D3 C8              [2] 00328          iny
.20D4 29 0F           [2] 00329          and    #$F       ; And then the lower one
.20D6 09 30           [2] 00330          ora    #'0'
.20D8 95 00           [4] 00331          sta    0,X
.20DA E8              [2] 00332          inx
.                         00333
.20DB C6 13           [5] 00334          dec    Byt1      ; More digits?
.20DD D0 E5 (20C4)  [2/3] 00335          bne    ASCIILoop ; Yes
.                         00336
.20DF 8A              [2] 00337          txa              ; Store string length
.20E0 38              [2] 00338          sec
.20E1 E9 1A           [2] 00339          sbc    #OutBuf+2
.                         00340
.20E3 A6 18           [3] 00341          ldx    OutBuf    ; Is the number negative?
.20E5 F0 14 (20FB)  [2/3] 00342          beq    NumberNotNegative
.                         00343
.20E7 18              [2] 00344          clc              ; Increment and store length
.20E8 69 01           [2] 00345          adc    #1
.20EA 85 18           [3] 00346          sta    OutBuf
.                         00347
.20EC A9 2D           [2] 00348          lda    #'-'      ; Prepend minus sign
.20EE 85 19           [3] 00349          sta    OutBuf+1
.                         00350
.20F0 A9 00           [2] 00351          lda    #>OutBuf
.20F2 A2 18           [2] 00352          ldx    #<OutBuf
.                         00353
.20F4 60              [6] 00354          rts
.                         00355
.20F5                     00356 NoDigits:
.20F5 A9 30           [2] 00357          lda    #'0'      ; Emit single '0'
.20F7 85 1A           [3] 00358          sta    OutBuf+2
.                         00359
.20F9 A9 01           [2] 00360          lda    #1        ; String length one
.                         00361
.20FB                     00362 NumberNotNegative:
.20FB 85 19           [3] 00363          sta    OutBuf+1
.                         00364
.20FD A9 00           [2] 00365          lda    #>OutBuf+1
.20FF A2 19           [2] 00366          ldx    #<OutBuf+1
.                         00367
.2101 60              [6] 00368          rts
The scorecard:
                          00001 ; Converting $FFFFFFFF
                          00002 ; old $2BC9 11209 cycles for call FormatLongword
                          00003 ; new $0A72 2674 cycles
                          00004 ;
                          00005 ; Converting $00000001
                          00006 ; old $2A96 10902 cycles for call FormatLongword
                          00007 ; new $015B 347 cycles
                          00008 ;
                          00009 ; Converting $00000000
                          00010 ; old $2A98 10904 cycles for call FormatLongword
                          00011 ; new $0075 117 cycles
The addressing modes and the three byte-sized registers worked well for this implementation.
The 6800 version:
.                         00486 * Input:
.                         00487 *       The absolute value of the number to convert is stored
.                         00488 *         starting at OutBuf+2 in little-endian form
.                         00489 *       A = number of bytes in the number
.                         00490 *       Dabble is the label of last byte of the buffer
.                         00491 *       OutBuf+0 = 0 if number is negative, other if negative
.                         00492 *
.                         00493 * Output:
.                         00494 *       X contains the address of the resultant string
.                         00495 *
.                         00496 * Uses:
.                         00497 *       Byt0 = number of bytes to convert
.                         00498 *       Byt1 = number of packed BCD bytes in result
.                         00499 *       Byt2 = bits of number being shifted
.                         00500 *       Ptr0
.                         00501 *       Ptr1
.01F5                     00522 Format
.01F5 97 10           [4] 00523          staa   Byt0      ; Remember number of bytes to convert
.                         00524
.01F7 8B 17           [2] 00525          adda   #<OutBuf+1 ; Point to most significant byte of number
.01F9 97 0B           [4] 00526          staa   Ptr0+1
.01FB 86 00           [2] 00527          ldaa   #>OutBuf+1
.01FD 89 00           [2] 00528          adca   #0
.01FF 97 0A           [4] 00529          staa   Ptr0
.0201 DE 0A           [4] 00530          ldx    Ptr0
.                         00531
.0203 7F 0011         [6] 00532          clr    Byt1      ; Start with no bytes of BCD digits
.                         00533
.0206                     00534 SkipLeadingZero
.0206 E6 00           [5] 00535          ldab   ,X        ; Get next highest byte of the number
.0208 26 0D (0217)    [4] 00536          bne    NotLeadingZero
.                         00537
.020A 09              [4] 00538          dex              ; Skip a leading zero
.                         00539
.020B 7A 0010         [6] 00540          dec    Byt0
.020E 26 F6 (0206)    [4] 00541          bne    SkipLeadingZero ; Check the next one if more
.                         00542
.0210 20 32 (0244)    [4] 00543          bra    BCD2ASCII ; All bytes are zero
.                         00544
.0212                     00545 ByteLoop
.0212 DE 0A           [4] 00546          ldx    Ptr0      ; Point back to the number to convert
.0214 09              [4] 00547          dex              ; Point to next highest byte
.                         00548
.0215 E6 00           [5] 00549          ldab   ,X        ; Get next highest byte of the number
.                         00550
.0217                     00551 NotLeadingZero
.0217 D7 12           [4] 00552          stab   Byt2      ; Set it for shifting
.                         00553
.0219 DF 0A           [5] 00554          stx    Ptr0      ; Remember the address of the last one shifted
.                         00555
.021B 0D              [2] 00556          sec              ; Shift in extra bit for eight trips through loop
.                         00557
.021C 20 1C (023A)    [4] 00558          bra    EnterBitLoop
.                         00559
.021E                     00560 BitLoop
.021E CE 002B         [3] 00561          ldx    #Dabble   ; Point to the BCD digits
.                         00562
.0221 D6 11           [3] 00563          ldab   Byt1      ; Load count of number of digit bytes
.0223 27 0B (0230)    [4] 00564          beq    SkipDigitLoop ; Skip loop if none
.                         00565
.0225                     00566 DigitLoop
.0225 A6 00           [5] 00567          ldaa   ,X        ; Double pair of BCD digits with carry
.0227 A9 00           [5] 00568          adca   ,X
.0229 19              [2] 00569          daa
.022A A7 00           [6] 00570          staa   ,X
.                         00571
.022C 09              [4] 00572          dex              ; Point to next pair of BCD digits
.                         00573
.022D                     00574 IntoDigitLoop
.022D 5A              [2] 00575          decb             ; More BCD digits?
.022E 26 F5 (0225)    [4] 00576          bne    DigitLoop ; Yes
.                         00577
.0230                     00578 SkipDigitLoop
.0230 24 08 (023A)    [4] 00579          bcc    EnterBitLoop ; Carry out of accumulated digits?
.                         00580
.0232 7C 0011         [6] 00581          inc    Byt1      ; Add a new byte to the result
.0235 86 01           [2] 00582          ldaa   #1
.0237 A7 00           [6] 00583          staa   ,X
.                         00584
.0239 0C              [2] 00585          clc
.                         00586
.023A                     00587 EnterBitLoop
.023A 79 0012         [6] 00588          rol    Byt2      ; Transfer upper bit to carry flag
.023D 26 DF (021E)    [4] 00589          bne    BitLoop   ; Repeat if more
.                         00590
.023F 7A 0010         [6] 00591          dec    Byt0      ; Any more bytes of the number to convert?
.0242 26 CE (0212)    [4] 00592          bne    ByteLoop  ; Repeat if more
.                         00593
.0244                     00594 BCD2ASCII
.0244 96 11           [3] 00595          ldaa   Byt1      ; Any converted digits?
.0246 27 57 (029F)    [4] 00596          beq    NoDigits  ; No
.                         00597
.0248 86 2C           [2] 00598          ldaa   #<Dabble+1 ; Point to most significant BCD pair
.024A 90 11           [3] 00599          suba   Byt1
.024C 97 0B           [4] 00600          staa   Ptr0+1
.024E 86 00           [2] 00601          ldaa   #>Dabble+1
.0250 82 00           [2] 00602          sbca   #0
.0252 97 0A           [4] 00603          staa   Ptr0
.                         00604
.0254 CE 0018         [3] 00605          ldx    #OutBuf+2 ; Point to result buffer
.0257 DF 0C           [5] 00606          stx    Ptr1
.                         00607
.0259 DE 0A           [4] 00608          ldx    Ptr0      ; Get most significant BCD pair
.025B A6 00           [5] 00609          ldaa   ,X
.025D 08              [4] 00610          inx
.025E DF 0A           [5] 00611          stx    Ptr0
.0260 DE 0C           [4] 00612          ldx    Ptr1
.                         00613
.0262 16              [2] 00614          tab              ; Clone it
.                         00615
.0263 85 F0           [2] 00616          bita   #$F0      ; Is the upper one zero?
.0265 27 17 (027E)    [4] 00617          beq    ConvertLowerOnly
.0267 20 0C (0275)    [4] 00618          bra    ConvertBoth
.                         00619
.0269                     00620 ASCIILoop
.0269 DF 0C           [5] 00621          stx    Ptr1
.026B DE 0A           [4] 00622          ldx    Ptr0      ; Get next most significant BCD pair
.026D A6 00           [5] 00623          ldaa   ,X
.026F 08              [4] 00624          inx
.0270 DF 0A           [5] 00625          stx    Ptr0
.0272 DE 0C           [4] 00626          ldx    Ptr1
.                         00627
.0274 16              [2] 00628          tab              ; Clone it
.                         00629
.0275                     00630 ConvertBoth
.0275 44              [2] 00631          lsra             ; Convert upper one to ASCII
.0276 44              [2] 00632          lsra
.0277 44              [2] 00633          lsra
.0278 44              [2] 00634          lsra
.0279 8A 30           [2] 00635          oraa   #'0'
.027B A7 00           [6] 00636          staa   ,X
.027D 08              [4] 00637          inx
.                         00638
.027E                     00639 ConvertLowerOnly
.027E C4 0F           [2] 00640          andb   #$F       ; And then the lower one
.0280 CA 30           [2] 00641          orab   #'0'
.0282 E7 00           [6] 00642          stab   ,X
.0284 08              [4] 00643          inx
.                         00644
.0285 7A 0011         [6] 00645          dec    Byt1      ; More BCD pairs?
.0288 26 DF (0269)    [4] 00646          bne    ASCIILoop
.                         00647
.028A DF 0C           [5] 00648          stx    Ptr1      ; Determine string length
.028C 96 0D           [3] 00649          ldaa   Ptr1+1
.028E 80 18           [2] 00650          suba   #<OutBuf+2
.                         00651
.0290 D6 16           [3] 00652          ldab   OutBuf    ; Is the number negative?
.0292 27 11 (02A5)    [4] 00653          beq    NumberNotNegative
.                         00654
.0294 4C              [2] 00655          inca             ; Increment and store length byte
.0295 97 16           [4] 00656          staa   OutBuf
.                         00657
.0297 C6 2D           [2] 00658          ldab   #'-'      ; Prepend minus sign
.0299 D7 17           [4] 00659          stab   OutBuf+1
.                         00660
.029B CE 0016         [3] 00661          ldx    #OutBuf   ; Point to the result
.                         00662
.029E 39              [5] 00663          rts
.                         00664
.029F                     00665 NoDigits
.029F 86 30           [2] 00666          ldaa   #'0'      ; Emit single '0'
.02A1 97 18           [4] 00667          staa   OutBuf+2
.                         00668
.02A3 86 01           [2] 00669          ldaa   #1        ; String length one
.                         00670
.02A5                     00671 NumberNotNegative
.02A5 97 17           [4] 00672          staa   OutBuf+1
.                         00673
.02A7 CE 0017         [3] 00674          ldx    #OutBuf+1
.                         00675
.02AA 39              [5] 00676          rts
The scorecard:
                          00001 * Converting $FFFFFFFF
                          00002 * old $38F0 14576 cycles for call FormatLongword
                          00003 * new $0FED 4077 cycles
                          00004 *
                          00005 * Converting $00000001
                          00006 * old $37B3 14259 cycles for call FormatLongword
                          00007 * new $01F2 498 cycles
                          00008 *
                          00009 * Converting $00000000
                          00010 * old $37B0 14256 cycles for call FormatLongword
                          00011 * new $00B9 185 cycles
The 6800 did not fare so well with only one index register and relatively slow memory access instructions.
The added capabilities of the 6809 do not appear to be much better.
The 8080 version:
.                         00127 ; Input:
.                         00128 ;       The absolute value of the number to convert is stored
.                         00129 ;         starting at OutBuf+2 in little-endian form
.                         00130 ;       A = number of bytes in the number
.                         00131 ;       B = 0 if number is positive, other if negative
.                         00132 ;       Dabble is the label of last byte of the buffer
.                         00133 ;
.                         00134 ; Output:
.                         00135 ;       HL contains the address of the resultant string
.0173                     00156 Format:
.0173 4F              [5] 00157         mov     C,A             ; Remember number of bytes to convert
.0174 5F              [5] 00158         mov     E,A
.                         00159
.0175 78              [5] 00160         mov     A,B             ; Remember negativity
.0176 32 0333        [13] 00161         sta     OutBuf
.                         00162
.0179 AF              [4] 00163         xra     A               ; Start with no bytes of BCD digits
.017A 47              [5] 00164         mov     B,A
.                         00165
.017B 21 0334        [10] 00166         lxi     H,OutBuf+1      ; Point DE to most significant byte of number
.017E 57              [5] 00167         mov     D,A
.017F 19             [10] 00168         dad     D
.0180 EB              [4] 00169         xchg
.                         00170
.0181                     00171 SkipLeadingZero:
.0181 1A              [7] 00172         ldax    D               ; Get next highest byte of the number
.0182 B7              [4] 00173         ora     A
.0183 C2 018F        [10] 00174         jnz     NotLeadingZero
.                         00175
.0186 1B              [5] 00176         dcx     D               ; Skip a leading zero
.                         00177
.0187 0D              [5] 00178         dcr     C
.0188 C2 0181        [10] 00179         jnz     SkipLeadingZero ; Check the next one if more
.                         00180
.018B C3 01BC        [10] 00181         jmp     BIN2ASCII       ; All bytes are zero
.                         00182
.018E                     00183 ByteLoop:
.018E 1A              [7] 00184         ldax    D               ; Get next highest byte of the number
.                         00185
.018F                     00186 NotLeadingZero:
.018F 1B              [5] 00187         dcx     D               ; Point to next lower byte
.                         00188
.0190 D5             [11] 00189         push    D               ; Stash pointer to next byte
.                         00190
.0191 5F              [5] 00191         mov     E,A             ; Set it for shifting
.                         00192
.0192 37              [4] 00193         stc                     ; Shift in extra bit for eight times thru loop
.                         00194
.0193 C3 01AF        [10] 00195         jmp     EnterBitLoop
.                         00196
.0196                     00197 BitLoop:
.0196 21 0348        [10] 00198         lxi     H,Dabble        ; Point to the BCD digits
.                         00199
.0199 04              [5] 00200         inr     B               ; Check count of number of digit bytes
.019A 05              [5] 00201         dcr     B               ; Test for zero but preserve carry flag
.019B CA 01A8        [10] 00202         jz      SkipDigitLoop   ; Skip loop if none
.                         00203
.019E 50              [5] 00204         mov     D,B
.                         00205
.019F                     00206 DigitLoop:
.019F 7E              [7] 00207         mov     A,M             ; Double pair of BCD digits with carry
.01A0 8E              [7] 00208         adc     M
.01A1 27              [4] 00209         daa
.01A2 77              [7] 00210         mov     M,A
.                         00211
.01A3 2B              [5] 00212         dcx     H               ; Point to next pair of BCD digits
.                         00213
.01A4                     00214 IntoDigitLoop:
.01A4 15              [5] 00215         dcr     D               ; More BCD digits?
.01A5 C2 019F        [10] 00216         jnz     DigitLoop       ; Yes
.                         00217
.01A8                     00218 SkipDigitLoop:
.01A8 D2 01AF        [10] 00219         jnc     EnterBitLoop    ; Carry out of accumulated digits?
.                         00220
.01AB 04              [5] 00221         inr     B               ; Add new byte to the result
.01AC 36 01          [10] 00222         mvi     M,1
.                         00223
.01AE B7              [4] 00224         ora     A               ; Clear carry flag
.                         00225
.01AF                     00226 EnterBitLoop:
.01AF 7B              [5] 00227         mov     A,E
.01B0 17              [4] 00228         ral                     ; Transfer upper bit to carry flag
.01B1 5F              [5] 00229         mov     E,A
.                         00230
.01B2 1C              [5] 00231         inr     E
.01B3 1D              [5] 00232         dcr     E
.01B4 C2 0196        [10] 00233         jnz     BitLoop         ; Repeat if more
.                         00234
.01B7 D1             [10] 00235         pop     D               ; Recover pointer to next byte
.                         00236
.01B8 0D              [5] 00237         dcr     C               ; Any more bytes of the number to convert?
.01B9 C2 018E        [10] 00238         jnz     ByteLoop        ; Repeat if more
.                         00239
.01BC                     00240 BIN2ASCII:
.01BC 21 0335        [10] 00241         lxi     H,OutBuf+2      ; Point to result buffer
.                         00242
.01BF 78              [5] 00243         mov     A,B             ; Any converted digits?
.01C0 B7              [4] 00244         ora     A
.01C1 CA 01F4        [10] 00245         jz      NoDigits        ; No
.                         00246
.01C4 11 0349        [10] 00247         lxi     D,Dabble+1      ; Point to most significant BCD pair
.01C7 7B              [5] 00248         mov     A,E
.01C8 90              [4] 00249         sub     B
.01C9 5F              [5] 00250         mov     E,A
.01CA 7A              [5] 00251         mov     A,D
.01CB DE 00           [7] 00252         sbi     0
.01CD 57              [5] 00253         mov     D,A
.                         00254
.01CE 1A              [7] 00255         ldax    D               ; Get most significant BCD pair
.                         00256
.01CF E6 F0           [7] 00257         ani     0F0h            ; Is the upper one zero?
.01D1 CA 01DF        [10] 00258         jz      ConvertLowerOnly
.                         00259
.01D4                     00260 ASCIILoop:
.01D4 1A              [7] 00261         ldax    D               ; Get next most significant BCD pair
.01D5 0F              [4] 00262         rrc                     ; Convert upper one to ASCII
.01D6 0F              [4] 00263         rrc
.01D7 0F              [4] 00264         rrc
.01D8 0F              [4] 00265         rrc
.01D9 E6 0F           [7] 00266         ani     0Fh
.01DB F6 30           [7] 00267         ori     '0'
.01DD 77              [7] 00268         mov     M,A
.01DE 23              [5] 00269         inx     H
.                         00270
.01DF                     00271 ConvertLowerOnly:
.01DF 1A              [7] 00272         ldax    D               ; And then the lower one
.01E0 13              [5] 00273         inx     D
.01E1 E6 0F           [7] 00274         ani     0Fh
.01E3 F6 30           [7] 00275         ori     '0'
.01E5 77              [7] 00276         mov     M,A
.01E6 23              [5] 00277         inx     H
.                         00278
.01E7 05              [5] 00279         dcr     B
.01E8 C2 01D4        [10] 00280         jnz     ASCIILoop
.                         00281
.01EB 7D              [5] 00282         mov     A,L             ; Store string length
.01EC DE 35           [7] 00283         sbi     OutBuf+2 and 0FFh
.01EE 32 0334        [13] 00284         sta     OutBuf+1
.                         00285
.01F1 C3 01F9        [10] 00286         jmp     FinishFormat
.                         00287
.01F4                     00288 NoDigits:
.01F4 36 30          [10] 00289         mvi     M,'0'           ; Emit single '0'
.                         00290
.01F6 2B              [5] 00291         dcx     H               ; String length one
.01F7 36 01          [10] 00292         mvi     M,1
.                         00293
.01F9                     00294 FinishFormat:
.01F9 21 0334        [10] 00295         lxi     H,OutBuf+1      ; Point to the result
.                         00296
.01FC 3A 0333        [13] 00297         lda     OutBuf          ; Was number negative?
.01FF B7              [4] 00298         ora     A
.0200 CA 0209        [10] 00299         jz      NumberNotNegative       ; No
.                         00300
.0203 7E              [7] 00301         mov     A,M             ; Get and increment length byte
.0204 3C              [5] 00302         inr     A
.                         00303
.0205 36 2D          [10] 00304         mvi     M,'-'           ; Prepend minus sign
.                         00305
.0207 2B              [5] 00306         dcx     H               ; Point to the new result
.                         00307
.0208 77              [7] 00308         mov     M,A             ; Store new length
.                         00309
.0209                     00310 NumberNotNegative:
.0209 C9             [10] 00311         ret
The scorecard:
                          00002 ; old $7F53 32595 cycles for call FormatLongword
                          00003 ; new $2359 9049 cycles
                          00004 ; new $1F18 7960 cycles
                          00005 ;
                          00006 ; Converting $00000001
                          00007 ; old $7CEE 31982 cycles for call FormatLongword
                          00008 ; new $055A 1370 cycles
                          00009 ; new $04C5 1221 cycles
                          00010 ;
                          00011 ; Converting $00000000
                          00012 ; old $7D05 32005 cycles for call FormatLongword
                          00013 ; new $01E0 480 cycles
                          00014 ; new $01A2 418 cycles
Two sets of new numbers are reported. One for the initial version and another for after some intense code golf managed to eliminate variables in memory.
I actually wrote the 8080 version first, then moved on to the 6800 and then the 6502. Only then did I invest the effort to optimize this one.
BillG
Post by BillG »
I see you continuing a discussion started near the bottom of the first page of this thread.
  ld a,l
  rla
  ld de,258
  or a ;clears carry.
  ld (dest),hl ;saved
The use of sbc HL,DE provides only a slight speed advantage over a bunch of atomic 8080 instructions doing the same thing but it does save on code size.
Snial wrote:
6809.
  ldd #258
  pshs d
  ldb s1
  sex
  sub d,S++
  std dest
Wait a minute. That subtracts 258 from s1...
I think you meant
  ldb s1
  sex
  pshs d
  ldd #258
  sub d,S++
  std dest
The use of the stack on the 6809 is not very fast. A temporary variable is often faster.
This brings up one of my favorite programming jokes: The Motorola 6809, where SEX is sometimes followed by STD.
That is the hidden gem of the 8080 and Z80 world. I wish they also provided HL <-> BC
Great result and thanks for the detailed explanation too.
BillG
Post by BillG »
I came across some benchmarks to compare Millfork with other compilers:
https://github.com/KarolS/millfork-benc ... aster/6502
The linked list one caught my attention. It creates a list of 3000 nodes then traverses it to add up the values.
My implementions are somewhat like the one provided in C except that I do not use his timing mechanism and the list creation loop counts down instead of up. My intent is not to compare with the compilers but between several different processors.
https://github.com/KarolS/millfork-benc ... nkedlist.c
I am slowly relenting to the prospect that a loop ending with an unconditional branch back to the top often performs better by transforming it to enter in the middle. The result looks unstructured, but it is not very different.
The first one is for the 6800. I have found that it is easiest to adopt 6800 code to other processors instead of the other way around.
The dual accumulators and 16-bit index register with displacement is especially well suited for this challenge.
Though inlining the subroutines provided a substantial improvement, I am showing the code before that final transformation for clarity.
                          00001 * 378834 ($5C7D2) cycles
                          00002 * 300821 ($49715) cycles after inlining subroutines
                          00003
 0000 005F                00004 Free     fdb    Heap
 0002 0000                00005 Root     fdb    0
 0004 0000                00006 New      fdb    0
 0006 0000 0000           00007 Total    fdb    0,0
 000A 0BB7                00008 I        fdb    2999
                          00009
                          00010 *
                          00011 * Allocate a node
                          00012 *
 000C                     00013 Alloc
 000C D6 01           [3] 00014          ldab   Free+1    ; Allocate a node
 000E D7 05           [4] 00015          stab   New+1     ; Return it in New
                          00016
 0010 CB 04           [2] 00017          addb   #4        ; Point to free memory
 0012 D7 01           [4] 00018          stab   Free+1
 0014 D6 00           [3] 00019          ldab   Free
 0016 D7 04           [4] 00020          stab   New
 0018 C9 00           [2] 00021          adcb   #0
 001A D7 00           [4] 00022          stab   Free
                          00023
 001C 39              [5] 00024          rts
                          00025
                          00026 *
                          00027 * Prepend a node to the list
                          00028 *
 001D                     00029 Prepend
 001D 8D ED (000C)    [8] 00030          bsr    Alloc     ; Allocate a new node
                          00031
 001F DE 04           [4] 00032          ldx    New       ; Point to the new node
                          00033
 0021 D6 02           [3] 00034          ldab   Root      ; Point next of new node to Root
 0023 E7 00           [6] 00035          stab   ,X
 0025 D6 03           [3] 00036          ldab   Root+1
 0027 E7 01           [6] 00037          stab   1,X
                          00038
 0029 A7 03           [6] 00039          staa   3,X       ; Store value in node
 002B D6 0A           [3] 00040          ldab   I
 002D E7 02           [6] 00041          stab   2,X
                          00042
 002F DF 02           [5] 00043          stx    Root      ; This is now the first node
                          00044
 0031 39              [5] 00045          rts
                          00046
                          00047 *
                          00048 * Traverse the list and sum the values
                          00049 *
 0032                     00050 Sum
 0032 DE 02           [4] 00051          ldx    Root
 0034 4F              [2] 00052          clra
 0035 5F              [2] 00053          clrb
                          00054
 0036                     00055 SumLoop
 0036 EB 03           [5] 00056          addb   3,X       ; Add value of node to sum
 0038 A9 02           [5] 00057          adca   2,X
 003A 24 08 (0044)    [4] 00058          bcc    NoCarry
                          00059
 003C 7C 0007         [6] 00060          inc    Total+1
                          00061
 003F 26 03 (0044)    [4] 00062          bne    NoCarry
                          00063
 0041 7C 0006         [6] 00064          inc    Total
                          00065
 0044                     00066 NoCarry
 0044 EE 00           [6] 00067          ldx    ,X        ; Point to the next node
 0046 26 EE (0036)    [4] 00068          bne    SumLoop   ; Until end of list
                          00069
 0048 97 08           [4] 00070          staa   Total+2
 004A D7 09           [4] 00071          stab   Total+3
                          00072
 004C 39              [5] 00073          rts
                          00074
                          00075 *
                          00076 *
                          00077 *
 004D                     00078 Main
 004D 96 0B           [3] 00079          ldaa   I+1       ; Get low byte of node value
                          00080
 004F 20 01 (0052)    [4] 00081          bra    IntoLoop
                          00082
 0051                     00083 Loop
 0051 4A              [2] 00084          deca
                          00085
 0052                     00086 IntoLoop
 0052 8D C9 (001D)    [8] 00087          bsr    Prepend
                          00088
 0054 4D              [2] 00089          tsta             ; Low byte of count zero?
 0055 26 FA (0051)    [4] 00090          bne    Loop      ; No, no borrow
                          00091
 0057 7A 000A         [6] 00092          dec    I         ; Borrow from upper byte
 005A 2A F5 (0051)    [4] 00093          bpl    Loop      ; Done if it goes negative
                          00094
 005C 8D D4 (0032)    [8] 00095          bsr    Sum       ; Traverse the list and add them up
                          00096
 005E 3F             [12] 00097          swi
                          00098
 005F                     00099 Heap
                          00100
 004D                     00101          end    Main
The 6502 had trouble keeping up with the others. Am I missing something?
                          00001 ; 519567 ($7ED8F) cycles
                          00002 ; 447558 ($6D446) after inlining subroutines
                          00003
 0000 026F                00004 Free     fdb    Heap
                          00009
 0200                     00010          org    $200
                          00011
                          00012 ;
                          00013 ; Allocate a node
                          00014 ;
 0200                     00015 Alloc:
 0200 A5 00           [3] 00016          lda    Free      ; Allocate a node
 0202 85 04           [3] 00017          sta    New       ; Return it in New
                          00018
 0204 18              [2] 00019          clc              ; Point to free memory
 0205 69 04           [2] 00020          adc    #4
 0207 85 00           [3] 00021          sta    Free
 0209 A5 01           [3] 00022          lda    Free+1
 020B 85 05           [3] 00023          sta    New+1
 020D 69 00           [2] 00024          adc    #0
 020F 85 01           [3] 00025          sta    Free+1
                          00026
 0211 60              [6] 00027          rts
                          00028
                          00029 ;
                          00030 ; Prepend a node to the list
                          00031 ;
 0212                     00032 Prepend:
 0212 20 0200         [6] 00033          jsr    Alloc     ; Allocate a new node
                          00034
 0215 A0 00           [2] 00035          ldy    #0        ; Point to the new node
                          00036
 0217 A5 02           [3] 00037          lda    Root      ; Point next of new node to Root
 0219 91 04           [6] 00038          sta    (New),Y
 021B C8              [2] 00039          iny
 021C A5 03           [3] 00040          lda    Root+1
 021E 91 04           [6] 00041          sta    (New),Y
 0220 C8              [2] 00042          iny
                          00043
 0221 A5 0A           [3] 00044          lda    I         ; Store value in node
 0223 91 04           [6] 00045          sta    (New),Y
 0225 C8              [2] 00046          iny
 0226 A5 0B           [3] 00047          lda    I+1
 0228 91 04           [6] 00048          sta    (New),Y
                          00049
 022A A5 04           [3] 00050          lda    New       ; This is now the first node
 022C 85 02           [3] 00051          sta    Root
 022E A5 05           [3] 00052          lda    New+1
 0230 85 03           [3] 00053          sta    Root+1
                          00054
 0232 60              [6] 00055          rts
                          00056
                          00057 ;
                          00058 ; Traverse the list and sum the values
                          00059 ;
 0233                     00060 NoCarry:
 0233 A0 00           [2] 00061          ldy    #0        ; Point to the next node
 0235 B1 02         [5/6] 00062          lda    (Root),Y
 0237 AA              [2] 00063          tax
 0238 C8              [2] 00064          iny
 0239 B1 02         [5/6] 00065          lda    (Root),Y
 023B 85 03           [3] 00066          sta    Root+1
 023D 86 02           [3] 00067          stx    Root
                          00068
 023F 05 02           [3] 00069          ora    Root
 0241 F0 1A (025D)  [2/3] 00070          beq    Summed    ; Until end of list
                          00071
 0243                     00072 Sum:
 0243 18              [2] 00073          clc              ; Add value of node to sum
 0244 A0 02           [2] 00074          ldy    #2
 0246 A5 06           [3] 00075          lda    Total
 0248 71 02         [5/6] 00076          adc    (Root),Y
 024A 85 06           [3] 00077          sta    Total
 024C C8              [2] 00078          iny
 024D A5 07           [3] 00079          lda    Total+1
 024F 71 02         [5/6] 00080          adc    (Root),Y
 0251 85 07           [3] 00081          sta    Total+1
 0253 90 DE (0233)  [2/3] 00082          bcc    NoCarry
                          00083
 0255 E6 08           [5] 00084          inc    Total+2
                          00085
 0257 D0 DA (0233)  [2/3] 00086          bne    NoCarry
                          00087
 0259 E6 09           [5] 00088          inc    Total+3
                          00089
 025B D0 D6 (0233)  [2/3] 00090          bne    NoCarry   ; Always branches
                          00091
 025D                     00092 Summed:
 025D 60              [6] 00093          rts
                          00094
                          00095 ;
                          00096 ;
                          00097 ;
 025E                     00098 NoBorrow:
 025E C6 0A           [5] 00099          dec    I
                          00100
 0260                     00101 Main:
 0260 20 0212         [6] 00102          jsr    Prepend
                          00103
 0263 A5 0A           [3] 00104          lda    I         ; Low byte of count zero?
 0265 D0 F7 (025E)  [2/3] 00105          bne    NoBorrow  ; No, no borrow
                          00106
 0267 C6 0B           [5] 00107          dec    I+1       ; Borrow from upper byte
 0269 10 F3 (025E)  [2/3] 00108          bpl    NoBorrow  ; Done if it goes negative
                          00109
 026B 20 0243         [6] 00110          jsr    Sum       ; Traverse the list and add them up
                          00111
 026E 00              [7] 00112          brk
                          00113
 026F                     00114 Heap:
                          00115
 0260                     00116          end    Main
The 8080 was difficult but benefited from abundant registers. Remember that a memory cycle of the 8080 is three machine cycles; it is one on the others, so 8080 machines usually ran at a two to three times faster clock rate.
                          00001 ; 991228 (0F1FFCh) cycles
                          00002 ; 829201 (0CA711h) cycles after inlining subroutines
                          00003
 0100                     00004         org     100h
                          00005
                          00006 ;
                          00007 ; Allocate a node
                          00008 ;
 0100                     00009 Alloc:
 0100 2A 0163        [16] 00010         lhld    Free            ; Allocate a node
                          00011
 0103 11 0004        [10] 00012         lxi     D,4             ; Point to free memory
 0106 EB              [4] 00013         xchg                    ; Keep New in DE
 0107 19             [10] 00014         dad     D
 0108 22 0163        [16] 00015         shld    Free
                          00016
 010B EB              [4] 00017         xchg                    ; Return New in HL
                          00018
 010C C9             [10] 00019         ret
                          00020
                          00021 ;
                          00022 ; Prepend a node to the list
                          00023 ;
 010D                     00024 Prepend:
 010D CD 0100        [17] 00025         call    Alloc           ; Allocate a new node
                          00026
 0110 3A 0165        [13] 00027         lda     Root            ; Point next of new node to Root
 0113 77              [7] 00028         mov     M,A
 0114 3A 0166        [13] 00029         lda     Root+1
 0117 22 0165        [16] 00030         shld    Root            ; This is the new first node
 011A 23              [5] 00031         inx     H
 011B 77              [7] 00032         mov     M,A             ; Finish pointer to previous Root
 011C 23              [5] 00033         inx     H
                          00034
 011D 71              [7] 00035         mov     M,C             ; Store value in node
 011E 23              [5] 00036         inx     H
 011F 70              [7] 00037         mov     M,B
                          00038
 0120 C9             [10] 00039         ret
                          00040
                          00041 ;
                          00042 ; Traverse the list and sum the values
                          00043 ;
 0121                     00044 Sum:
 0121 2A 0165        [16] 00045         lhld    Root
 0124 11 0000        [10] 00046         lxi     D,0
                          00047
 0127                     00048 SumLoop:
 0127 23              [5] 00049         inx     H               ; Add value of node to sum
 0128 23              [5] 00050         inx     H
 0129 4E              [7] 00051         mov     C,M
 012A 23              [5] 00052         inx     H
 012B 46              [7] 00053         mov     B,M
 012C EB              [4] 00054         xchg
 012D 09             [10] 00055         dad     B
 012E EB              [4] 00056         xchg
 012F D2 013B        [10] 00057         jnc     NoCarry
                          00058
 0132 E5             [11] 00059         push    H               ; Carry to high word
 0133 2A 016B        [16] 00060         lhld    Total+2
 0136 23              [5] 00061         inx     H
 0137 22 016B        [16] 00062         shld    Total+2
 013A E1             [10] 00063         pop     H
                          00064
 013B                     00065 NoCarry:
 013B 2B              [5] 00066         dcx     H               ; Point to the next node
 013C 2B              [5] 00067         dcx     H
 013D 7E              [7] 00068         mov     A,M
 013E 2B              [5] 00069         dcx     H
 013F 6E              [7] 00070         mov     L,M
 0140 67              [5] 00071         mov     H,A
                          00072
 0141 B5              [4] 00073         ora     L               ; Until end of list
 0142 C2 0127        [10] 00074         jnz     SumLoop
                          00075
 0145 EB              [4] 00076         xchg
 0146 22 0169        [16] 00077         shld    Total
                          00078
 0149 C9             [10] 00079         ret
                          00080
                          00081 ;
                          00082 ;
                          00083 ;
 014A                     00084 Main:
 014A 2A 016D         [16] 00085         lhld    I               ; Get count
 014D 4D              [5] 00086         mov     C,L
 014E 44              [5] 00087         mov     B,H
                          00088
 014F C3 0153        [10] 00089         jmp     IntoLoop
                          00090
 0152                     00091 NoBorrow:
 0152 0D              [5] 00092         dcr     C
                          00093
 0153                     00094 IntoLoop:
 0153 CD 010D        [17] 00095         call    Prepend
                          00096
 0156 0D              [5] 00097         dcr     C               ; Low byte of count zero?
 0157 0C              [5] 00098         inr     C
 0158 C2 0152        [10] 00099         jnz     NoBorrow        ; No, no borrow
                          00100
 015B 05              [5] 00101         dcr     B               ; Borrow from upper byte
 015C F2 0152        [10] 00102         jp      NoBorrow        ; Done if it goes negative
                          00103
 015F CD 0121        [17] 00104         call    Sum             ; Traverse the list and add them up
                          00105
 0162 76              [7] 00106         hlt
                          00107
 0163 016F                00108 Free    dw      Heap
 0165 0000                00109 Root    dw      0
 0167 0000                00110 New     dw      0
 0169 0000 0000           00111 Total   dw      0,0
 016D 0BB7                00112 I       dw      2999
                          00113
 016F                     00114 Heap
                          00115
 014A                     00116         end     Main
The 6809 ran away with this challenge. The additional registers and flexible addressing modes gave it a major advantage.
                                  00001 * 363754 ($58CEA) cycles original 6800 source code
                                  00002 * 243378 ($3B6B2) cycles
                                  00003 * 171350 ($29D56) cycles after inlining subroutines
                                  00004
 0000 0044                        00005 Free     fdb    Heap
 0002 0000                        00006 Root     fdb    0
 0004 0000                        00007 New      fdb    0
 0006 0000 0000                   00008 Total    fdb    0,0
 000A 0BB7                        00009 I        fdb    2999
                                  00010
                                  00011 *
                                  00012 * Allocate a node
                                  00013 *
 000C                             00014 Alloc
 000C 30 C4                   [4] 00015          leax   ,U        ; Allocate a node
                                  00016
 000E 33 44                   [5] 00017          leau   4,U       ; Point to free memory
                                  00018
 0010 39                      [5] 00019          rts
                                  00020
                                  00021 *
                                  00022 * Prepend a node to the list
                                  00023 *
 0011                             00024 Prepend
 0011 8D F9 (000C)            [7] 00025          bsr    Alloc     ; Allocate a new node
                                  00026
 0013 DC 02                   [5] 00027          ldd    Root      ; Point next of new node to Root
 0015 ED 84                   [5] 00028          std    ,X
                                  00029
 0017 10AF 02                 [7] 00030          sty    2,X       ; Store value in node
                                  00031
 001A 9F 02                   [5] 00032          stx    Root      ; This is now the first node
                                  00033
 001C 39                      [5] 00034          rts
                                  00035
                                  00036 *
                                  00037 * Traverse the list and sum the values
                                  00038 *
 001D                             00039 Sum
 001D 9E 02                   [5] 00040          ldx    Root
 001F CC 0000                 [3] 00041          ldd    #0        ; Clear total
 0022 1F 03                   [6] 00042          tfr    D,U
                                  00043
 0024                             00044 SumLoop
 0024 E3 02                   [7] 00045          addd   2,X       ; Add value of node to sum
 0026 24 02 (002A)            [3] 00046          bcc    NoCarry
                                  00047
 0028 33 41                   [5] 00048          leau   1,U
                                  00049
 002A                             00050 NoCarry
 002A AE 84                   [5] 00051          ldx    ,X        ; Point to the next node
 002C 26 F6 (0024)            [3] 00052          bne    SumLoop   ; Until end of list
                                  00053
 002E DD 08                   [5] 00054          std    Total+2
 0030 DF 06                   [5] 00055          stu    Total
                                  00056
 0032 39                      [5] 00057          rts
                                  00058
                                  00059 *
                                  00060 *
                                  00061 *
 0033                             00062 Main
 0033 109E 0A                 [6] 00063          ldy    I         ; Get node value
 0036 CE 0044                 [3] 00064          ldu    #Heap     ; Point to free memory
                                  00065
 0039                             00066 Loop
 0039 8D D6 (0011)            [7] 00067          bsr    Prepend
                                  00068
 003B 31 3F                   [5] 00069          leay   -1,Y
                                  00070
 003D 26 FA (0039)            [3] 00071          bne    Loop
                                  00072
 003F 8D D0 (0011)            [7] 00073          bsr    Prepend   ; And once for 0 just to make it fair
                                  00074
 0041 8D DA (001D)            [7] 00075          bsr    Sum       ; Traverse the list and add them up
                                  00076
 0043 3F                     [19] 00077          swi
                                  00078
 0044                             00079 Heap
                                  00080
 0033                             00081          end    Main
barrym95838
I do that all the time, but structured coding isn't very high on my priority list, for historic reasons.
Possibly. I don't have time to look right now, because I'm trying to catch some feral cats and get them "fixed" and released before they make more inbred feral kittens. Maybe tonight ...
They put a lot of thought into that architecture, and it shows.
I hear a shotgun works well in such situations. :D
