Page 9 of 24
Posted: Fri Mar 02, 2012 1:16 pm
by ElEctric_EyE
Expanding the register file in such a way as I was doing (even though I was not aware of it) would most likely affect the top speed a little more than what I have done so far, which has only brought it down to ~95MHz from 100MHz. And changing the state machine is not something I wanted to tackle for the .b version.
I'll try using your suggestion on src_reg, dst_reg manipulation for ADC and SBC. Since there is a common carry to the 4 Accumulators, I wonder what kind of problems this will pose?
Posted: Fri Mar 02, 2012 4:29 pm
by ElEctric_EyE
Now I get it! Manipulating the dst_reg to put the result into any 1 of 4 Acc for all addressing modes of ADC/SBC/AND/ORA/EOR would be awesome. Your idea is almost exactly like what I wanted to do with the transfer with logic opcodes. Although I don't think the shift functions ASL/LSR/ROL/ROR would be too useful to do this. Those I would still like to modify the upper 4 bits of those instructions to do a 1 - 15 bit shift.
Posted: Sat Mar 03, 2012 1:35 am
by ElEctric_EyE
I'm going to take this modification one step at a time not necessarily for review, but just to show what I am doing/have done. If there is an error, please point it out.
Looking at all the addressing modes for ADC/SBC/AND/ORA/EOR opcodes for NMOS 6502, I've come up with the following (binary on the left, hex on the right):
0xxx_0001.....$01-$71
0xxx_0101.....$05-$75
0xxx_1001.....$09-$79
0xxx_1101.....$0D-$7D
0xx1_0010.....$12, $32, $52, $72
111x_0001.....$E1,$F1
111x_0101.....$E5,$F5
111x_1001.....$E9,$F9
1111_0010.....$F2
Posted: Sat Mar 03, 2012 12:22 pm
by ElEctric_EyE
To see what bits are still available on the MSB of 65Org16.b opcodes I am looking at the microcode state machine, which I am going to slightly modify first. Bits 8 and 9 of the MSB have already been used to specificy 1 of 4 Accumulators. I would like to use bits 10 & 11, as Arlet has suggested earlier, to specify which Accumulator the dst_reg will select. This is the Microcode state machine presently.
I am going to add an xx for bits [11:10] in the Microcode state machine wherever the bit patterns in my previous post match below. For ones that don't match, I will add the bit pattern to the state machine with the appropriate state.
DECODE :
casex ( IR[15:0] ) // decode all 16 bits
16'b0000_0000_0000_0000: state <= BRK0;
16'b0000_0000_0010_0000: state <= JSR0;
16'b0000_0000_0010_1100: state <= ABS0; // BIT abs
16'b0000_0000_0100_0000: state <= RTI0; //
16'b0000_0000_0100_1100: state <= JMP0;
16'b0000_0000_0110_0000: state <= RTS0;
16'b0000_0000_0110_1100: state <= JMPI0;
16'b0000_00xx_0x00_1000: state <= PUSH0;
16'b0000_00xx_0x10_1000: state <= PULL0;
16'b0000_00xx_0xx1_1000: state <= REG; // CLC, SEC, CLI, SEI
16'b0000_0000_1xx0_00x0: state <= FETCH; // IMM
16'b0000_0000_1xx0_1100: state <= ABS0; // X/Y abs
16'b0000_00xx_1xxx_1000: state <= REG; // DEY, TYA, ...
16'b0000_00xx_xxx0_0001: state <= INDX0;
16'b0000_00xx_xxx0_01xx: state <= ZP0;
16'b0000_00xx_xxx0_1001: state <= FETCH; // IMM
16'b0000_00xx_xxx0_1101: state <= ABS0; // even D column
16'b0000_00xx_xxx0_1110: state <= ABS0; // even E column
16'b0000_0000_xxx1_0000: state <= BRA0; // odd 0 column
16'b0000_00xx_xxx1_0001: state <= INDY0; // odd 1 column
16'b0000_00xx_xxx1_01xx: state <= ZPX0; // odd 4,5,6,7 columns
16'b0000_00xx_xxx1_1001: state <= ABSX0; // odd 9 column
16'b0000_00xx_xxx1_11xx: state <= ABSX0; // odd C, D, E, F columns
16'b0000_00xx_xxxx_1010: state <= REG; // <shift> A, TXA, ... NOP
16'b0000_00xx_10xx_1011: state <= REG; // TBA,TCA,TDA,TAB,TCB,TDB,TAC,TBC,TDC,TAD,TBD,TCDode]
Posted: Sat Mar 03, 2012 1:09 pm
by ElEctric_EyE
Ok, not too difficult. Only one opcode, $F2, unaccounted for. But this is a 65C02 instruction! Old habit, I am looking at the WDC datasheet for the opcode matrix...
Next in true hacker fashion (i.e. one who is just learning), I look for where else these opcodes occur after the state machine. I find a piece of code for load_reg and modify bits [11:10] for the matching opcodes (not shown).
Modified Microcode State Machine. Bits 11 & 10 will point to a dst_reg. The src_reg will also read these bits.
DECODE :
16'b0000_xxxx_xxx0_0001: state <= INDX0;
16'b0000_xxxx_xxx0_01xx: state <= ZP0;
16'b0000_xxxx_xxx0_1001: state <= FETCH; // IMM
16'b0000_xxxx_xxx0_1101: state <= ABS0; // even D column
16'b0000_xxxx_xxx1_0001: state <= INDY0; // odd 1 column
16'b0000_xxxx_xxx1_01xx: state <= ZPX0; // odd 4,5,6,7 columns
16'b0000_xxxx_xxx1_1001: state <= ABSX0; // odd 9 column
16'b0000_xxxx_xxx1_11xx: state <= ABSX0; // odd C, D, E, F columns
Posted: Sat Mar 03, 2012 6:49 pm
by ElEctric_EyE
Ok, I believe I got it working!
For opcode bits [11:10] of ADC/SBC/AND/ORA/EOR the function I have looks like this:
[11:10] FUNCTION
0: 0 original ADC/SBC/AND/ORA/EOR on 4 Acc's (as defined by bits [9:8])
0: 1 add value in operand to A Acc and store in B Acc
1: 0 add value in operand to B Acc and store in C Acc
1: 1 add value in operand to C Acc and store in D Acc
This small chunk of assembly is working in ISim:
$FFFFE0000 LDA #$07
TAB ;Transfer A Acc to B Acc
CLC
ADC #$01
TAC ;Transfer A Acc to C Acc
ADC #$01
TAD ;Transfer A Acc to D Acc
$FFFFE00B ADCAopBi ;Add op value to A Acc, store in B Acc
.BYTE $0010
LDBi ;LDB #$10
.BYTE $0010
TBA
CLC
--code trimmed here, due to waveform end--
Posted: Sat Mar 03, 2012 8:53 pm
by ElEctric_EyE
I've updated the new 65Org16.b code on
Github. The complete current Verilog listing is there as of today. It is partially tested but I believe it to be correct. If anyone sees errors please post here, I will do the same and I will continue testing and posting here...
Posted: Sun Mar 04, 2012 5:00 am
by ElEctric_EyE
Now I've been thinking, since the 'transposing stores' appear to be working using 2 bits, use 4 bits to maximize transposition. I will work on this next.
Just got done running synthesis, and the design still tops out at 94.6MHz using 2 bits!
[13:10] FUNCTION
0: 0: 0: 0 original ADC/SBC/AND/ORA/EOR on 4 Acc's (as defined by bits [9:8])
0: 0: 0: 1 add value in operand to A Acc and store in B Acc
0: 0: 1: 0 add value in operand to A Acc and store in C Acc
0: 0: 1: 1 add value in operand to A Acc and store in D Acc
0: 1: 0: 0 add value in operand to B Acc and store in A Acc
0: 1: 0: 1 add value in operand to B Acc and store in C Acc
0: 1: 1: 0 add value in operand to B Acc and store in D Acc
0: 1: 1: 1 add value in operand to C Acc and store in A Acc
1: 0: 0: 0 add value in operand to C Acc and store in B Acc
1: 0: 0: 1 add value in operand to C Acc and store in D Acc
1: 0: 1: 0 add value in operand to D Acc and store in A Acc
1: 0: 1: 1 add value in operand to D Acc and store in B Acc
1: 1: 0: 0 add value in operand to D Acc and store in C Acc
Posted: Sun Mar 04, 2012 6:46 am
by Arlet
I don't get it. Are you still using bits 9:8 for the source selection ? If so, how does that combine with the extra 2 bits 13:12 ?
Posted: Sun Mar 04, 2012 12:15 pm
by ElEctric_EyE
I actually haven't thought it all the way through yet. I just thought I could do the same thing I did with regular 12 transfer opcodes. Maybe I have an error in the code there, even though it works in Sim.
I don't see what's so different from that though: If you have 4 Accumulators you have 16 viable possibilities for src_reg to dst_reg transfers...
Posted: Sun Mar 04, 2012 12:28 pm
by Arlet
Yes, but to encode those 16 possibilities, you only need 4 bits (11:8 ).
Posted: Sun Mar 04, 2012 1:58 pm
by ElEctric_EyE
Not sure what I was thinking.
Posted: Sun Mar 04, 2012 9:34 pm
by ElEctric_EyE
Question: I have observed that a
always @(posedge clk)
if( state == DECODE && RDY )
casex( IR[15:0] )
will execute first when the opcode matches the CASEX, then immediately after,
on the next posedge clock
default: case( IR[9:8] )
2'b00: dst_reg <= SEL_A;
2'b01: dst_reg <= SEL_B;
2'b10: dst_reg <= SEL_C;
2'b11: dst_reg <= SEL_D;
endcase
default will execute?
Posted: Mon Mar 05, 2012 6:18 am
by Arlet
That shouldn't happen. The casex is only done when 'state == DECODE', and that only happens for 1 cycle.
Add 'statename' to your sim traces, and check for DECODE.
Posted: Mon Mar 05, 2012 7:26 pm
by ElEctric_EyE
I was misinterpreting what I was seeing, sorry... Too early and no coffee.
I've finished what I think will work for all the 'transposing store' opcodes. I'll have a very short amount of time tonight to do some preliminary testing. Bits [11:10] are dst_reg and [9:8] are src_reg.
