Page 8 of 17
Re: Random-number generation
Posted: Fri Mar 24, 2023 1:41 pm
I think the crucial difference here is that the LFSR genuinely makes a bit at a time, and only as a matter of usage do we collect 8 for a byte or 32 for a word.
As for Arlet's, it feels to me that it is byte orientated, in which case we might expect the byte-stream to have somewhat different statistical properties from an assembled word-stream. But perhaps not!
It's interesting to me too, that Arlet's scheme is empirical, without a mathematical underpinning. But it's certainly small and cheap, and apparently passes lots of tests.
(As a terrible idea, I did wonder about omitting the LDA to save a couple of bytes, and replacing the CLC with a SEC, in the mere hope that the generator is not called with worst-case values in A - in this case, perhaps an FF. As I say, a terrible idea.)
Posted: Fri Mar 24, 2023 1:43 pm
by Alex1
No algorithm can produce truly random data, only a physical random source can do that (like counting the decay number of an atom). Then everyone uses the LFSR and even the army. And LFSR is a building block that can be used for a cryptographically secure encryption system. this is the big difference with your PRNG. On the other hand as you created it through trial and error, it was almost certain that there were problems in it.
On my side I prefer algorithms that are based on math, we are sure not to have a problem then.
Posted: Fri Mar 24, 2023 3:42 pm
by barrym95838
I'm all for rigorous "mathy" solutions when our nuclear codes are in jeopardy, but Arlet's spunky little solution seems like a great fit in so many other contexts. I admire his workmanlike spirit, and I personally look forward to further inventions from him.
Posted: Fri Mar 24, 2023 4:40 pm
by Arlet
In theory, it should be the same. If you have a generator for good random bits/bytes, you can concatenate N of them to make an equally good random word. The reverse is also true. If you have a good source for 32 bit random values, you can split them up, and create multiple shorter values.
Posted: Fri Mar 24, 2023 4:51 pm
by Arlet
The mathy nature of the LFSR is a double edged sword. It means you can construct a set of linear equations to solve the polynomial and the state, based on a small number of output samples, using the Berlekamp-Massey Algorithm. In addition, the LFSR generator does not create high quality random numbers, as it quickly fails all modern test suites.
Posted: Sat Mar 25, 2023 12:07 am
by Alex1
A single LFSR can be totally random and cryptographically secure if we add logic gates to make it nonlinear and this is only possible precisely because there is no pattern in the LFSR.
For example the US KW-7 encryption device used only 1 LFSR (39-bit LFSR) :
Posted: Sat Mar 25, 2023 4:49 am
by Arlet
That's exactly what I've done. There's a 32 bit core in seed+0..seed+3 that goes through every state exactly once, like an LFSR, followed by a nonlinear scrambling function.
Posted: Sat Mar 25, 2023 7:51 am
I think it's interesting, though, if your scheme's core has 2^32 states whereas a 32 bit LFSR has only 2^32-1. (Acorn's BBC Basic uses a 33 bit LFSR, which is of course just one bit better, and is suitable for 32 bit outputs. It should fail some tests, though, for the distance between consecutive values, compared to a true 32 bit random source.)
Posted: Sat Mar 25, 2023 9:15 am
by Arlet
Indeed, and not only is the missing state bad from a uniformity point of view, it can also be annoying in practical applications. For instance, if you want to create an effect where you toggle every pixel on the screen in random order, it is nice if there are no missing values. Also, it's easier if there are no bad seed values that you have to watch out for.
Of course, the 2nd half of my random generator messes up the uniformity a little bit, for the sake of code density. If desired, the output function can be replaced by a bijective 32->32 bit function that preserves uniformity. That would require a few more instructions.
I am currently working on a RNG optimized for the AVR processor that uses 64 bit state, and produces a 32 bit random value. My strategy is to come up with some simple ideas, test them to see which one works best, and then make multiple copies with tiny changes, like changing ADC into EOR, swapping two operations or values. Each of these copies is then evaluated and if I find an improvement, I keep that one as the new base. If reordering things doesn't result in improvements, I try adding an operation. It's a guided form of evolutionary programming. Breeding digital orchids.
Posted: Sat Mar 25, 2023 11:06 am
In this case you might want a random permutation, or you'll find yourself waiting a long time!
I do recall, back in the day, filling a Beeb's high resolution screen (20k bytes, 160k pixels) with, in effect, a bar graph of bucketed values from the random number generator. One hopes to see a broadly even growth in the single-pixel-wide bars, but not a precisely even growth. (In fact, the degree of unevenness of the growth is a measure of how good the pseudo random numbers are, as you no doubt know.)
Posted: Sat Mar 25, 2023 11:17 am
by Arlet
I remember an interesting effect I did on my Atom high res mode. On a clear screen, I drew the two diagonals across the screen, and then had a machine code loop that basically did
loop:
EOR (ptr), Y
STA (ptr), Y
INY
BNE loop
... and repeat for next pages until entire screen was done ...
When done over and over, it creates some interesting patterns.
I wonder what it would look like with ADC instead of EOR.
Posted: Sat Mar 25, 2023 12:49 pm
by Alex1
I notice that in my translation of the Arlet's algorithm, where I forgot a double carry, there are fewer patterns: 9 instead of 12.
Found '00000000100010101010100001110011' at index 0 !
Found '00000000100010101010100001110011' at index 6852B3F7 !
Found '00000000100010101010100001110011' at index BD7D473F !
Found '00000000100010101010100001110011' at index E9154CB2 !
Found '00000000100010101010100001110011' at index 217CA96FD !
Found '00000000100010101010100001110011' at index 324CC6D91 !
Found '00000000100010101010100001110011' at index 34BA75919 !
Found '00000000100010101010100001110011' at index 3C1ABA1E1 !
Found '00000000100010101010100001110011' at index 4630BEC41 !
Found '00000000100010101010100001110011' at index 7AC32606F !
Posted: Sat Mar 25, 2023 11:28 pm
by Alex1
It is not the same. As can be seen in the design of the KW7, logic gates make the output bits of the LFSR non-linear but they never modify the content of the LFSR itself, which always behaves like an LFSR. The output bits of the LFSR after passing through the logic gates only modifies the progress of the LFSR (advance one step or not advance).
In the case of your algorithm, logic gates change the internal state of the algorithm, making its behavior mathematically unpredictable.
We see this with the carry, no double carry and there is less pattern without really knowing why.
Posted: Sun Mar 26, 2023 3:47 am
by Arlet
I was only talking about the first 4 bytes of my algorithm. This part here:
CLC
LDA #$45
ADC seed+0
STA seed+0
ADC seed+1
STA seed+1
ADC seed+2
STA seed+2
ADC seed+3
STA seed+3
That part goes through every possible 32 bit state before repeating. The code that follows mixes it all up, and makes it more unpredictable, but that's exactly what it's supposed to do. Keep in mind that the goal is not to have a secure algorithm, or even a building block for it. We just want to generate some good quality random numbers so we can shuffle a deck of cards for solitaire, or determine the path of monsters in a game. A "good quality" is defined as passing statistical tests in a manner indistinguishable from true randomness.. As a substitute for true randomness, we can use a known good pseudo random sequence, such as /dev/random or a well accepted cryptographic algorithm such as Chacha-20. If you want to show that my random number generator is not behaving properly, you should run a side-by-side test comparing my method with such a known good source, and show a consistent difference. Comparing it to a plain LFSR is pointless, because it's not a accepted as known good source of randomness.
Posted: Sun Mar 26, 2023 7:12 am
(Fun fact: you'd need 226 bits to have a chance of shuffling cards into any possible order!)
Slightly OT, I found The Unreasonable Effectiveness of Quasirandom Sequences rather interesting. Short version: just keep adding 1/phi and you get a nice evenly spaced walk around many possible values. A 40 bit or 48 bit version might be interesting, and would be extremely cheap. I would expect it to fail a good test of randomness - but perhaps not too badly.
1/phi is 0.61803398875 or $9e3779b97f4a as a scaled value.
