Page 1 of 5
Re: Not your run of the mill control flow
Posted: Mon Sep 19, 2022 3:29 pm
by barrym95838
So, what other unique control methods are out there, or even the traditional ones used in unique and interesting ways?
Courtesy of "HAA" on usenet:
FOR NEXT came from cmForth as a replacement for DO LOOP. The latter
was deemed too expensive to implement on Forth chips. Implementations
vary e.g. cmForth's iterates n+1 times for reasons peculiar to Novix.
eForth creator Bill Muench provides this diagram & test to explain how
FOR NEXT works with AFT and WHILE. Use fixed-width font to view.
\ v--------<<
\ FOR ... NEXT a1 ...
\ v---------------------<< >>----------v
\ FOR ... WHILE a1 ... NEXT a2 ... ELSE a3 ... THEN ...
\ v-----------------<<
\ FOR ... AFT a1 ... THEN ... NEXT a2 ...
( test FOR-NEXT ============================================= )
: N1 ( -- ) 9 FOR R@ . NEXT ;
: N2 ( -- ) 9 FOR 5 R@ < WHILE R@ . NEXT ." X" ELSE R> DROP ." Y" THEN ;
: N3 ( -- ) 9 FOR ." X" AFT ." Y" THEN R@ . NEXT ;
Results using Bill's eForth
ok N1 9 8 7 6 5 4 3 2 1 0
ok N2 9 8 7 6 Y
ok N3 X9 Y8 Y7 Y6 Y5 Y4 Y3 Y2 Y1 Y0
Posted: Tue Sep 20, 2022 1:00 pm
by Dr Jefyll
One of the words I added to my version of FIG Forth is NIF (short for "not if"). Predictably, it compiles a primitive which behaves like 0= IF. And NUNTIL was "not until."
These are pretty trivial, of course, but seemed worthwhile given my own relative priorities re the speed/memory tradeoff.
Posted: Tue Sep 20, 2022 9:14 pm
Wow, looking at my own code, there are enough occurrences of 0= IF that I think that would pay for itself in memory, so there's no penalty for the faster execution. I think I would call it something else though unless "NIF" is already in common use, because it looks like a short form of "nifty" and definitely did not make me think "NOT IF." NOT in Forth XOR's the value with -1, rather than doing 0=.
I believe FOR...NEXT is in the newest standards, probably as a concession to reduce newcomers' resistance to Forth, but I do like DO...LOOP and friends. I have 32-bit equivalents too, at http://wilsonminesco.com/Forth/32DOLOOP.FTH .
Michael, can you give further explanation of what the flow is in FOR...WHILE a1...NEXT a2...ELSE a3...THEN...
Posted: Tue Sep 20, 2022 10:13 pm
by barrym95838
I asked the question and received that from HAA as the kindest answer, but I'm not embarrassed to admit that I still don't fully understand the answer.
Posted: Wed Sep 21, 2022 9:40 pm
by JimBoyd
Monday evening I think I figured this out and wrote FOR NEXT words. The diagrams were not much help. This better represents what my FOR NEXT words do.
\ v--------<<
\ FOR a0 ... NEXT a1 ...
\ v--------------------<< >>------------v
\ FOR a0... WHILE a1 ... NEXT a2 ... ELSE a3 ... THEN a4 ...
\ FOR a0 ... AFT a1 ... THEN a2 ... NEXT a3 ...
This is how it works in my Forth.
First a brief refresher on the control flow words >MARK >RESOLVE <MARK <RESOLVE .
>MARK leaves an address to be resolved and reserves a cell in the dictionary while >RESOLVE resolves the forward reference.
<MARK leaves a destination address for a backward branch and <RESOLVE compiles that address in the dictionary. This is from my Forth. The (minimal) compiler security is just to make sure that a <MARK is resolved by a <RESOLVE and a >MARK is resolve by a >RESOLVE .
: ?PAIRS ( N1 N2 -- )
ABORT" STRUCTURE MISMATCH" ;
: >MARK ( -- >SYS )
HERE 1 0 , ;
: >RESOLVE ( >SYS -- )
1 ?PAIRS HERE SWAP ! ;
: <MARK ( -- <SYS )
HERE 2 ;
: <RESOLVE ( <SYS -- )
2 ?PAIRS , ;
Here are the FOR NEXT words. The only new primitive is (NEXT) .
' ?BRANCH @ 8 + CONSTANT 2.IP.+!
CODE (NEXT) ( -- )
PLA TAY
0= IF
PLA
0= IF
2.IP.+! JMP
THEN
SEC 1 # SBC PHA
THEN
DEY TYA PHA
0 # LDY
' BRANCH @ JMP
END-CODE
And the high level words.
: FOR ( -- )
( N -- )
COMPILE >R <MARK ; IMMEDIATE
: NEXT ( -- )
COMPILE (NEXT)
<RESOLVE ; IMMEDIATE
: AFT ( -- )
[COMPILE] CS-DROP COMPILE BRANCH
>MARK <MARK
[COMPILE] CS-SWAP ; IMMEDIATE
The FOR and NEXT loop structure is similar to a BEGIN UNTIL loop.
AFT is the unusual one. It drops the control flow data from FOR , compiles BRANCH and adds control flow data for a forward branch and backward branch. AFT then swaps the control flow data because the forward branch gets resolved before the backward branch.
Here are the test words:
: N1 ( -- )
9
FOR
R@ .
NEXT ;
: N2 ( -- )
9
FOR
5 R@ <
WHILE
R@ .
NEXT
." X"
ELSE
R> DROP ." Y"
THEN ;
: N3 ( -- )
9
FOR
." X"
AFT
." Y"
THEN
R@ .
NEXT ;
And what got compiled:
SEE N1
N1
31296 3419 CLIT 9
31299 4656 >R
31301 4740 R@
31303 7568 .
31305 31202 (NEXT)
31307 31301
31309 2970 EXIT
15
OK
SEE N2
N2
31320 3419 CLIT 9
31323 4656 >R
31325 3419 CLIT 5
31328 4740 R@
31330 4448 <
31332 2781 ?BRANCH 31352
31336 4740 R@
31338 7568 .
31340 31202 (NEXT)
31342 31325
31344 7809 (.") X
31348 3042 BRANCH 31360
31352 4672 R>
31354 3031 DROP
31356 7809 (.") Y
31360 2970 EXIT
42
OK
SEE N3
N3
31371 3419 CLIT 9
31374 4656 >R
31376 7809 (.") X
31380 3042 BRANCH 31388
31384 7809 (.") Y
31388 4740 R@
31390 7568 .
31392 31202 (NEXT)
31394 31384
31396 2970 EXIT
27
OK
The address after (NEXT) is the branch address. My SEE doesn't recognize (NEXT) as a branching word, but that is not a problem.
The results match those provided.
N1 9 8 7 6 5 4 3 2 1 0 OK
N2 9 8 7 6 Y OK
N3 X9 Y8 Y7 Y6 Y5 Y4 Y3 Y2 Y1 Y0 OK
[Edit: Added some clarification about my SEE .]
Posted: Wed Sep 21, 2022 10:12 pm
by JimBoyd
I think I saw it called -IF but it has been a while and I can't remember where.
Posted: Thu Sep 22, 2022 1:16 am
by JimBoyd
I need to run some more tests on my FOR NEXT loops. I suspect the following will be true:
When nested, an inner FOR NEXT loop can be in any part of the outer loop as long as the control structures do not cross.
WHILE can even be used with a FOR ... AFT ... THEN ... NEXT loop. Because AFT places two sets of control flow data on the control flow stack (in my case, the data stack), WHILE cannot be used to branch past NEXT from between AFT and THEN . In other words, I don't think this will work:
FOR a0 ... AFT a1 ... WHILE a2 ... THEN a3 ... NEXT a4 ... THEN a5 ...
Multiple WHILEs can be used. Each must have a matching THEN after NEXT.
I think my Forth's compiler security of making sure each >MARK is matched with a >RESOLVE , each <MARK is matched with a <RESOLVE and a colon or CODE is matched with a semicolon or END-CODE will cause an ABORT if these conditions are not met.
Also, if any WHILE's are used to branch out of the FOR NEXT loop, the loop parameter will still be on the return stack as shown in test word N2 .
: N2 ( -- )
9
FOR
5 R@ <
WHILE
R@ .
NEXT
." X"
ELSE
R> DROP ." Y"
THEN ;
I also think this might be possible, but I need to test it:
v-------------------------------------------<<
FOR A0 ... AFT A1 ... WHILE A2 ... THEN A3... THEN A4... NEXT A5...
Posted: Thu Sep 22, 2022 4:46 am
by barrym95838
Jim, I knew you'd be the guy here to figure out how eForth's AFT works. Now all I have to do is figure out how you figured it out, then figure out a proper use for it ...
Posted: Sun Sep 25, 2022 7:05 am
IF0 or IF_0 would be pretty intuitive.
Posted: Mon Sep 26, 2022 2:35 am
by IamRob
How about "ZIF" or "ZEQIF"?
Posted: Mon Sep 26, 2022 3:32 pm
by BruceRMcF
... I think I saw it called -IF but it has been a while and I can't remember where.
-IF is the one that I saw previously, but I have to say that IF0 is the best combination of intuitive and fast to type for me.
I think -IF is most intuitive if you have a dictionary with a leading "-" for a number of words that invert the test for the underlying word. Otherwise I'd have a risk of reading it as taking the following action if the top of the stack is negative.
I would say that "I have FOR NEXT in xForth", but I haven't had an opportunity to work on it over the past year, and until I have a working CREATE / DOES> word pair, I don't think it's fair to say that I actually "have" xForth -- rather I have code that hopes to grow up into xForth on of these days.
Posted: Mon Sep 26, 2022 11:01 pm
by JimBoyd
What about 0IF ?
Also 0WHILE and 0UNTIL ?
BEGIN
2DUP @ EXECUTE
0WHILE
2+ 2+
REPEAT
BEGIN
2DUP @ EXECUTE
WHILE0
2+ 2+
REPEAT
Which do you think reads better?
I also have:
?EXIT \ pop top of stack. exit if true.
0EXIT \ pop top of stack. exit if false.
Posted: Mon Sep 26, 2022 11:49 pm
by Dr Jefyll
What about 0IF ?
To me, the leading zero seems good. Terse yet clear. Of course I liked the leading N too (example:
NIF ), and I knew well enough that it didn't mean
NOT (or "nifty"!)
But the leading 0 seems fine for
0IF and likewise for
0WHILE.
As for this...
... my own preference would be...
?0EXIT \ pop top of stack. exit if false.
... because they both conditionally execute based on TOS (which gets popped), and that's a scenario I associate with the question mark. And the 0 gets added if you wanna reverse the sense.
Posted: Tue Sep 27, 2022 12:26 am
by JimBoyd
I like it. Good thing I haven't released Fleet Forth version 2.0 yet.
Posted: Tue Sep 27, 2022 12:59 am
by JimBoyd
I definitely needed the examples for that. It looks like all duplicate spaces were deleted from the original control flow diagrams.
Here are two words using WHILE to branch from between AFT and AFT's matching THEN to between that THEN and NEXT .
Here is the first word.
: N4 ( -- )
9
FOR
." X"
AFT
." Y"
5 R@ <
WHILE
THEN
R@ .
THEN
NEXT ;
And the test run.
Here is the other.
: N6 ( -- ) 9
FOR
CR ." A0"
AFT
CR ." A1"
5 R@ <
WHILE
." A2"
THEN
." A3"
ELSE
." A4"
THEN
." A5 " R@ .
NEXT ;
And the test run.
N6
A0 A3 A5 9
A1 A2 A3 A5 8
A1 A2 A3 A5 7
A1 A2 A3 A5 6
A1 A4 A5 5
A1 A4 A5 4
A1 A4 A5 3
A1 A4 A5 2
A1 A4 A5 1
A1 A4 A5 0 OK
The word N7 has a FOR NEXT loop within another FOR NEXT loop.
: N7 ( -- ) 9
FOR
CR ." A0"
AFT
CR ." A1"
5 R@ <
WHILE
." A2 " 3 FOR ." X" AFT ." Y" THEN R@ . NEXT
THEN
." A3"
ELSE
." A4"
THEN
." A5 " R@ .
NEXT ;
And it works well.
N7
A0 A3 A5 9
A1 A2 X3 Y2 Y1 Y0 A3 A5 8
A1 A2 X3 Y2 Y1 Y0 A3 A5 7
A1 A2 X3 Y2 Y1 Y0 A3 A5 6
A1 A4 A5 5
A1 A4 A5 4
A1 A4 A5 3
A1 A4 A5 2
A1 A4 A5 1
A1 A4 A5 0 OK
Multiple occurrences of AFT in a FOR NEXT loop will not work. The first AFT drops the backward branch data from FOR and replaces it with its own and a forward branch. A second AFT would drop the forward branch data from the first AFT , leaving its backward branch data. The matching THEN will not resolve the backward branch and abort.
This will not compile on my system.
: N9 ( -- )
CR 3
FOR ." A0 "
AFT ." A1 "
AFT ." A2 "
THEN ." A3 "
THEN ." A4 "
R@ .
NEXT ;
So let's get tricky. The first AFT still has backward branch data on the control flow stack, so that is what must be resolved.
: N10
CR 3
FOR ." A0 "
AFT ." A1 "
AFT ." A2 "
THEN ." A3 "
TRUE
UNTIL ." A4 "
R@ .
NEXT ;
This is what gets compiled.
SEE N10
N10
31299 6707 CR
31301 2266 3
31303 4656 >R
31305 7809 (.") A0
31311 3042 BRANCH 0
16
OK
The forward branch from the first AFT does not get resolved resulting in a branch to address zero.
I typed
to see the rest of N10 .
EAD :DIS
31315 7809 (.") A1
31321 3042 BRANCH 31331
31325 7809 (.") A2
31331 7809 (.") A3
31337 3388 TRUE
31339 2781 ?BRANCH 31325
31343 7809 (.") A4
31349 4740 R@
31351 7568 .
31353 31202 (NEXT)
31355 31315
31357 2970 EXIT
44
OK
It is possible to tighten the compiler security so this doesn't happen. The control flow data consists of an address and a number.
One for >MARK and >RESOLVE .
Two for <MARK and <RESOLVE .
// FOR NEXT LOOP -- EXTRA SECURITY
: FOR ( -- )
( N -- )
COMPILE >R
<MARK 2+ 2+ ; IMMEDIATE
: NEXT ( -- )
COMPILE (NEXT)
2- 2- <RESOLVE ; IMMEDIATE
: AFT ( -- )
6 ?PAIRS DROP
COMPILE BRANCH >MARK
<MARK 2+ 2+
Sixteen extra bytes to make sure:
FOR is only resolved with AFT or NEXT .
AFT is only resolved with THEN and NEXT in that order.
By the way, the version of Gforth on my desktop has FOR and NEXT but not AFT . I suspect it is because this version of Gforth does not have CS-DROP , just CS-PICK and CS-ROLL in accordance with the ANSI standard.
Since this version of Gforth uses the data stack for the control flow stack, I was able to add AFT to it.
\ AFT for gforth
: AFT ( -- )
2DROP DROP
POSTPONE BRANCH >MARK
POSTPONE BEGIN DROP DO-DEST
POSTPONE BUT ; IMMEDIATE
Anyone who notices that DO-DEST and thinks this version of Gforth's FOR NEXT loops are compatible with its DO LOOP's would be correct. Gforth's DO LOOP's only have two parameters pushed to the return stack, the limit and index. Gforth's FOR pushes a zero as a limit and the number on the stack as the index. Here is an example of a mixed FOR and DO loop in Gforth. Gforth's I is an alias for R@ .
\ this is weird
: test 50 for cr i . -10 +loop ; ok
test
50
40
30
20
10
0 ok
