Glitchy Furrystuff wrote:
Just a heads up, I'm new to hardware and only a little experienced in 6502 (Thanks to the NES) So if I ask something dumb/obvious, don't be surprised.
Well, we all had to start somewhere. For me, it was when Eisenhower was president.
If you are going to scratch-build something digital, the 65xx is as good a place to start as any.
M27C256B (32K of space, right?)
-10F 1 (My only guess of what this is is it's temperature resistance)
B880S (No clue)
0034K (Not sure about this, because 32!=34)
SINGAPORE (Uh...)
... And the manufacturer is ST.
My POC unit has the same EPROM, but a -70F. BTW, the F indicates that the EPROM is UV-erasable. The 256 spec means 256 kilobits of storage. The EPROM is organized as 32Kbits x 8, meaning it has an eight bit data bus. This particular part is programmed at 12.75 volts. You can go on-line to ST's website and get the data sheet.
Now, all my parts except that EPROM (It came with my burner) was from RadioShack. My burner is called Willem I believe and was about $25-$30 and I heard it was pretty good.
I don't know anything about the Radio Shack EPROM burner, so I can't comment on that specific model. However, you never get more than what you pay for, so caveat emptor.
