Arlet, yes you are right it's patterns not loops.
What i say is that LFSR is based on maths and there is no pattern. For my LFSR 32, the output is 2^32 different patterns. The maths says that and the real world too :
With my LFSR 32, the same pattern is only after 2^32 bits :Quote:
Found '10001111001001101010111011010011' at index 0 !
Found '10001111001001101010111011010011' at index FFFFFFFF !
With your PRNG :Quote:
Found '00000000100010101010100001110011' at index 0 !
Found '00000000100010101010100001110011' at index 4422DC31 !
Found '00000000100010101010100001110011' at index 47B2741C !
Found '00000000100010101010100001110011' at index 90215B01 !
Found '00000000100010101010100001110011' at index A1E6E039 !
Found '00000000100010101010100001110011' at index DA608D58 !
But you said your PRNG produces 2^32 bytes (4GB) then it's (2^32)*8 bits = 32 Giga-bits :
and with 32 Giga-bits here are the patterns with your PRNG :
Found '00000000100010101010100001110011' at index 1DDC91D77 !
Found '00000000100010101010100001110011' at index 41FFA3A69 !
Found '00000000100010101010100001110011' at index 4F774146B !
Found '00000000100010101010100001110011' at index 57C03DB9D !
Found '00000000100010101010100001110011' at index 5AFA0662E !
Found '00000000100010101010100001110011' at index 5BF3AE07E !
Found '00000000100010101010100001110011' at index 6CDF53905 !
The PRNG are building blocks. If they do not meet certain specifications, anything that can be produced on them afterwards may have big problems.
Chacha20 is based on strong maths for building blocks so you can't compare a final encryption system as chacha20 with a building block like your PRNG.
And the other problem is that rng_test don't detect patterns in your PRNG.
From what I understand is that you say that the repetition of patterns in a PRNG is not important. I do not think so. Because if we have patterns then there is linear relationships not foreseen in the algorithm and if we used this PRNG as building block to create an encryption system, then linear cryptanalysis could break it easily.
