8bitPogle, it caught my attention when, near the beginning of your post, you said, "when I just wired up a little test (with no ICs) , the voltage out was pushing 7v." I assume you were expecting 5 volts (or close).
Be aware that, although most power supplies will maintain their rated output voltage even when no load is present, there are some for which this isn't true.
They require a certain minimum load (ie, that a certain amount of current, listed in the specifications, be drawn). If you fail to draw at least this minimum amount they can lose regulation and output more than the expected output voltage. It sounds as if this may've happened to you.
Your best option, IMO, is to simply stop using that power supply!
Otherwise, I suggest you find out what minimum load it requires and permanently attach a suitably sized resistor as a dummy load which will draw (and waste) that specified minimum amount. (Let us know if you need help determining the resistance and wattage of the resistor.)
I can't help wondering if this minimum load issue has affected some of the other observations mentioned later in your post!
Hi Jeff
Thanks for that - interesting point that I wasn't aware of.
I'm not really sure what output voltage I was expecting, but the 5v and 3v supplies are sort of in parallel, so I assumed it was something to do with that and the diodes preventing the supplies trying to 'level out'.
I have attached a small picture of the battery circuit.
Re minimum load, I suppose I could connect the old Sonos bridge that the supply was designed for and see what it's drawing and work it out from there?
I have used that supply for quite a few breadboard computers, but I get what you say about using it for small experiments...more stuff to learn
