It is currently Sat Nov 23, 2024 11:02 am
PostPosted: Tue Jan 31, 2023 6:01 pm
Any ideas for use of Flash memories as reliable storage for 6502 small systems ?
Not as system ROM but as mapped devices.
No complex file system requests, just read, copy, write, erase, in pages of blocks, with 512, 1k or 4k bytes.
Just to preserve informations.
I tried to search the list but many links are lost.
PostPosted: Tue Jan 31, 2023 6:07 pm
Honestly if that's what you want, you're probably best off using an SD card, because the complexity of wear-levelling is transparently handled for you by the SD Card's internal controller. You can use an SD card as a raw block storage if you want, you don't have to have a file system on it. Though they can be a bit fiddly to set up and will be slower to access than a Flash...
If the SD card doesn't work for you, I would recommend an FRAM. It basically has the same properties as RAM, including write speed and (almost) infinite write cycle life so you don't need to worry about wear levelling, but it is non-volatile like Flash is. The only real downside is its quite expensive per unit of memory - if you need lots of storage an FRAM probably isn't the answer...
Therefore, if you really need to use some kind of EEPROM/Flash, and you want it to be 'reliable' in the long-term allowing for arbitrary overwriting: you'll need to implement a wear levelling scheme of some kind. There are filesystems (YAFFS is one that springs to mind, but there are others) which do this inherently as part of their design - you could look at how they do it for inspiration, even if your actual implementation is simpler.
PostPosted: Tue Jan 31, 2023 6:56 pm
Alarm Siren wrote:
There are filesystems (ReiserFS and YAFFS are the two that spring to mind, but there are others) which do this inherently as part of their design - you could look at how they do it for inspiration, even if your actual implementation is simpler.
Hmm...I seem to recall that ReiserFS was not recommended for use on solid state storage devices. Also, ReiserFS is no longer supported by NameSys (I couldn’t even find a reference to it on the NameSys website) and is scheduled to be deleted from the Linux kernel base.
At one time, I used ResierFS on my Linux boxes. Eventually, I switched everything to ext3, which ended up to be a better-performing filesystem.
PostPosted: Tue Jan 31, 2023 7:11 pm
Quite right, I had misremembered, thank you for pointing it out. I cannot remember the correct name of the other one so I've just removed mention of it from my post entirely.
PostPosted: Tue Jan 31, 2023 7:38 pm
agsb, how much storage space do you want?  Up to 128KB, you might like the 8-pin 24xx I²C serial EEPROMs.  For larger amounts like 8MB (I haven't looked at how high they go now), and pages/sectors/etc., the 8-pin 26VFxxx SPI flash memories are nice.  On the front page of my site, I offer tiny modules conforming to the I2C-6 and SPI-10 connector "standards" we devised on this forum.  I'm not pushing this as a business, only making available to others the things I've made for myself.
PostPosted: Tue Jan 31, 2023 8:38 pm
Another suitable storage is CF disk. CF is parallel interface, so it can also serve as a boot ROM with a minimal amount of logic. You don’t need a file system to access CF, it is just bunch of addressable 512-byte sectors with automatic wear leveling function built in. With gigabyte CF readily available, you don’t need to be efficient about file storage—no big deal if every file is 64KB. If you put the operating system on the CF disk, you can change your mind with different OS for every new CF disk.
PostPosted: Wed Feb 01, 2023 10:15 am
There is an ATmega device which runs FORTH which uses small (8-pin) SPI Flash chips for storage and while I was interested in the basic unit for a while, I've not looked for a long time, however I didn't see any issues with the SPI Flash device and I did consider it for my own use in my Ruby project, but opted for SD cards (although I'm really not sure why, now!) SD has a very similar SPI interface although a slightly more complex command-set.
I do use the internal flash in the ATmega in my Ruby system too - (4KB on the MCU I'm using) but it does have limited writes (1000s not millions, and this has been tested by others) but for occasional use it's been fine for me.
But once you can read/write (say) 512 byte blocks then you can do anything. FAT, etc.
PostPosted: Wed Feb 01, 2023 6:38 pm
FRAM is fun to use and dead simple to implement (though you have to watch out that some chips can't be used if the ~CS line is permanently low) but it turned out that it's zillion year life - I think they quote in the 10^9 hours - is reduced to about nine days at 150C. Which is where I was designing a file system to run... Flash lasted much longer. I needed to run for at least a fortnight and couldn't guarantee it with FRAM.
The nice thing about oil drilling machines is that there's so much money sloshing about (I was quoted rentals for the robot of half a million bucks a week) that it's quite feasible to throw the electronics away after one run and extracting the data. It's a truly horrible environment for anything: electronics that had to work from -60C to +150C minimum, vibrations of 10,000g, and heavy handed riggers stomping around the place and jumping on things.
PostPosted: Wed Feb 01, 2023 7:01 pm
Hi Perhaps have a look at this page and see if that would be of some help. viewtopic.php?f=6&t=7473
