I received an email from Electronics Goldmine this morning advertising this microprocessor:
https://theelectronicgoldmine.com/products/G26807Two things found interesting:
* It claims to be upwards compatible with the HD6800. I looked at the data sheet and sure enough the instruction set looks like a 6800 to me. But I am not fluent in that assembly language, so I might be missing something.
* The ominous warning at the bottom! Did they use depleted uranium to make this thing? Following the link at the bottom, since they're based in California and they don't know if it contains any of the hazardous materials listed in the Prop 65 law ( can't afford to test it), they added the warning as a CYA.
Anyway I posted it here because it's a cousin of the 6502, and it is retro enough that someone might want to use it as an I/O controller while staying period accurate.
