I would also second BDD's suggestion on using programmable logic, as it will simplify the overall design, eliminate 2 or more chips and give you a much more flexible solution that can be easily changed.
I would like to see this amazing quantum glue logic that can be implemented with *
zero or fewer* chips! Your kung fu must indeed be powerful. Maybe we can sell the chips generated by the "or fewer" version and make a profit. (Or maybe that's where all those sketchy Ali Express logic ICs already come from!)
You could go further and merge ZP and page 1, by making it so if A9...A15 are all 0's, A8 gets ignored and also replaced with a 0, so $100-$1FF becomes a duplicate of 00-$FF, making the hardware stack addressable in page 0 also, opening up ZP addressing modes for it. Then you could, for example, use TSX, ADC(5,X) to add the contents of an address pointed to by a byte pair in a stack frame passed to the currently executing subroutine. There would be no hard boundary between ZP and page 1; so for example if your I/O takes 00-$3F, and you know that your hardware stack needs will be adequately met with $30 bytes (addresses $1D0 to $1FF, now same as $D0 to $FF), it would leave you with $90 bytes of normal usable ZP space, ie, more than half a page.
I will have to think about this for a while to really get a grasp of how to do it, but I think it sounds amazingly cool.
Can you explain your intention regarding the A7...A14 to the right of the B inputs of the '688.
Each Q input is pulled low through resistors, by default. You can use a jumper to short it either to VCC (to move the window around in address space), or to the corresponding P input address line so that P=Q will always be true for that line, effectively shrinking the width of the comparator. The notion is that you can double the size of the window each time you de-activate the next low-order bit.
I suppose you might be able to do interesting things by removing random upper address lines from the mix, but I can't visualize what would happen; I think it would start mirroring the window, wouldn't it?
Edit:
Note however that the '521 is the same thing as the '688 and is available in faster variations.
BTW, I did read that in the Primer, and I looked for them when I went "comparator shopping." HC and AHC don't seem to exist on Mouser / Digikey, and AC is listed as "obsolete, non stocked" on Digikey. I see now they have them in F and ALS. I am uncertain about mixing logic families.
