Home computer construction with SMT parts and PLCCs
When I typed in www.jameco.com I got a white page with a redirect link. However, about 4 seconds later, it automatically took me to their store front. From there, the links to the catalog seemed to work. Purhaps you caught them in an upgrade-gone-bad state?
- GARTHWILSON
- Forum Moderator
- GARTHWILSON
- Forum Moderator
- GARTHWILSON
- Forum Moderator
- GARTHWILSON
- Forum Moderator
Ok, got it. I cleared the Jameco cookies, and it works now. Our son said it was probably because of the fact that he recently changed my OS from Linspire (and the FireFox derivative LBrowser) to Ubuntu (even though Linspire has worked perfectly fine for years) and copied all the old data, including cookies over; then Jameco's web ap may not have known what to do with the cookie not matching the OS.
Actually, cookies have zero to do with the OS. Cookies are KEY=VALUE equations, stored by domain name in the browser's data cache area (note: they're treated differently from cachable data; however, the cache directory is typically where most browsers dump them).
It sounds to me like Jameco's web application designers have failed to consider the possibility of an expired cookie, or even a cookie with improperly formatted data (this occurs all the time when, for instance, the VALUE part of the equation changes, but the KEY doesn't).
I didn't consider the possibility of cookies here, because it's considered terrible, terrible, TERRIBLE practice to depend on cookies when touching the home page. This is relatively common practice: you can set them, query them, and act on them if they're OK, but you never depend on them. Apparently, Jameco's web designers didn't get the memo on industry best practices.
- BigDumbDinosaur
Does anyone know what's going on with Jameco? For many years, they've sent me the normal catalog updates automatically, but last week I got a thing in the mail from them saying to go to www.Jameco.com/CAT10 to order a free online catalog, so I figured they want to make sure they're only sending it to people who want it.
There's a boo-boo in the code pointing to the above, but it does auto-redirect after a short pause (this is in SeaMonkey).
So I go to that address, and it says the page cannot be found, then re-directs me to supposedly the front page I guess, which is blank now-- nothing on it.
- GARTHWILSON
- Forum Moderator
ElEctric_EyE
Re: Home computer construction with SMT parts and PLCCs
...and other manufacturers offer adapters to make SOICs and other SMT parts able to be plugged into DIP sockets. Here's one from Aries, which I've used:
- BigDumbDinosaur
ElEctric_EyE wrote:
I finished soldering this 32Kx8 SOJ last night. Not too bad.
The solder from one lead wound up sticking to an adjacent lead. I was worried about heat so close the the IC leads, so I used a solder sucker, and it fixed it up real quick.
- GARTHWILSON
- Forum Moderator
When you put the soldering iron up to one lead, the rest of the package will give cooling, and the temperature gradient will keep the die (the actual chip inside the IC) from getting very hot. You're not applying the soldering iron directly to the die. Between the leadframe and the die there are bondwires to connect, and those are usually .001" to .002" in diameter. When they specify for soldering that the temperature be held below X degrees for Y seconds, they're referring to automatic production soldering that gets the whole thing up to that temperature, applying heat even to the package itself, not just a few leads at a time.
- BigDumbDinosaur
Lead Temperature (soldering, 10s) (Note 3) .......+300°C
300°C is 572°F. As Garth pointed out, hand soldering isn't going to impose thermal loads any more severe than reflow in an oven.
