It is currently Mon Sep 23, 2024 4:36 am
PostPosted: Sun Nov 20, 2022 12:26 am
The compiler gods have added the llvm-mos C compiler to the Compiler Explorer at godbolt.org.
This means that you can experiment with llvm-mos 6502 codegen without installing anything locally.
Here's an example of llvm-mos running a compile-time calculation in C:
https://godbolt.org/z/5xer5nYsE
And here's an example of code running on an emulated NES (click on the popup in the lower right corner to watch the emulation run):
https://godbolt.org/z/MxaoKvEfs
More info about llvm-mos is available at https://www.llvm-mos.org.
PostPosted: Mon Nov 21, 2022 5:11 am
Oh wow, that's awesome! And that's going to make my life so much easier :D
Thanks for pointing it out
