It is currently Thu May 23, 2024 11:24 pm
 Post subject: WDC Tools - bugs!
PostPosted: Thu Sep 15, 2022 10:17 pm
So, some time ago, I discovered some odd problems with WDC Tools Assembler. This was back when I was working on the SIM module for DOS/65. Using the following code to load some pointers into the bottom of the stack page:
First Bug:
                ldy     #6              ;set index to 6
simset_lp       lda     sim_inttbl-1,y  ;get SIM table data
                sta     $0100-1,y       ;store into page $01 PEM area
                dey                     ;decrement index
                bne     simset_lp       ;loop until done
The above works fine, but, WDC Tools has a bug using the X register (in the above code) when the operand is: $0100-1 (it should be $00FF, but it becomes $FF), so no workie!
Second Bug:
Again, writing the SIM module.
sim_dcbtbl      .DW     dcb_a
                .DW     dcb_b
                .DW     dcb_c
                .DW     dcb_d
                .DW     dcb_e
                .DW     dcb_f
                .DW     dcb_g
                .DW     dcb_h
Initial code didn't support all 8 drives. Initial code used: .DW dcba, etc. for creating the dcb, table. When I increased the drives to h, the label "dcbh" caused an assembly error. Adding the "_" to make it "dcb_h" (fixed it.
Now I found Bug number 3, while working to port some of the DOS/65 utilities over.
In the Assembler utility, they use two page zero locations for an indirect pointer to routines. At one section in the code, they show:
        JMP     (TBLPTR)        ;go to entry point
The assembler chokes on this with an invalid addressing mode, as TBLPTR is defined in Page Zero.
My workaround for this is:
.DB $6C
.DW TBLPTR
This generates the code as 3 bytes, which works.
Ah... tooling... they all have their little gotchas. I'll be sending a note off to Bill Mensch on this, see what he thinks... who knows, would be nice to get an updated assembler!
 Post subject: Re: WDC Tools - bugs!
PostPosted: Thu Sep 15, 2022 10:57 pm
I do not think that is a bug.
If you write
                sta     $0100-1,x       ;store into page $01 PEM area
the assembler is well within its right to interpret that as
                sta     $FF,x       ;store into page $01 PEM area
Maybe you should have written that as
                sta     >$FF,x       ;store into page $01 PEM area
PostPosted: Thu Sep 15, 2022 11:02 pm
Does the assembler try to be "nice" and allow you to write hexadecimal constants "Intel" style?
If so, it should not trigger on "DCBh" because "Intel" style hexadecimal numbers must begin with a digit, that is, "0DCBh" with a leading zero.
PostPosted: Thu Sep 15, 2022 11:11 pm
If you write
Perhaps... but the assembler interprets it differently when using the Y index register. So at best, it's inconsistent, which I would lean towards it being a bug.
I would also note that the original code (I think it was written and assembled with TASM) was written that way using the X Index register, which apparently worked.
PostPosted: Thu Sep 15, 2022 11:14 pm
There is no zero page,Y addressing mode...
PostPosted: Thu Sep 15, 2022 11:19 pm
Actually, this one is very strange... if you don't use the "_" in any of them, the last two work, but the first six error out as "undefined symbol". As you add the "_" the list changes in which ones are problematic.
I just added the "_" to all of them (for consistency) and the problem went away.
PostPosted: Thu Sep 15, 2022 11:24 pm
Well, you did not originally say that.
This smells even more like failed attempted Intelism.
$DCBA, $DCBB, $DCBC, $DCBD, $DCBE and $DCBF are all valid hexadecimal numbers!
PostPosted: Thu Sep 15, 2022 11:25 pm
That's very true... but the source code is written with a 16-bit operand. When you subtract the 1 from it, the assembler changes it to an 8-bit operand. That's why I'm leaning towards it being a bug. Then again, could be works as designed.
PostPosted: Thu Sep 15, 2022 11:35 pm
Yea, it was a while ago.... I just grabbed the source and started changing it around, but forgot to change the actual labels, hence the strange results :shock:
I went back and removed the "_" from all of the labels and the error only occurs on the dcbh one. The actual error is: "Hex and Symbol are identical!" So yes, I think you're right that the assembler is interpreting the "h" at the end as a hex value. When used at the start of the line as a label, it doesn't cause a problem, until you try and use it somewhere else in the code.
;disk control blocks
; Updated to support 8 drives by default - KM
;drive a (CF 8MB)
dcb_a           .DW     4095            ;max block number
                .DW     1024            ;records per track
                .DW     0               ;number system tracks
                .DB     1               ;block size = 2048
                .DW     1023            ;max directory
                .DW     almpa           ;address of allocation map
                .DB     128             ;do not do checksums
                .DW     0               ;phony address
;drive b (CF 8MB)
dcb_b           .DW     4095            ;max block number
                .DW     almpb           ;address of allocation map
;drive c (CF 8MB)
dcb_c           .DW     4095            ;max block number
                .DW     almpc           ;address of allocation map
;drive d (CF 8MB)
dcb_d           .DW     4095            ;max block number
                .DW     almpd           ;address of allocation map
;drive e (CF 8MB)
dcb_e           .DW     4095            ;max block number
                .DW     almpe           ;address of allocation map
;drive f (CF 8MB)
dcb_f           .DW     4095            ;max block number
                .DW     almpf           ;address of allocation map
;drive g (CF 8MB)
dcb_g           .DW     4095            ;max block number
                .DW     almpg           ;address of allocation map
;drive h (CF 8MB)
dcb_h           .DW     4095            ;max block number
                .DW     almph           ;address of allocation map
PostPosted: Thu Sep 15, 2022 11:37 pm
If you write
    lda     #$100-1
would you expect it to give you an error or
    lda     #$FF
PostPosted: Fri Sep 16, 2022 12:05 am
Some years ago, I worked with the WDC package for a while. While the C compiler was okay, the assembler was annoying when writing 65C816 code. I haven’t touched it since 2015. As Bill suggests, it is likely whomever wrote the assembler thought he/she would be doing someone a favor and mixed in some Intel cruft.
BTW, STA $100-1,X would evaluate to STA $FF,X in just about any assembler. The Kowalski assembler has a way to force an address to be assembled as 16 bits, even though the address evaluates to an eight-bit value. If I write STA \2$100-1,Y, the Kowalski assembler will assemble it as STA $00FF,Y, which is legit.
PostPosted: Fri Sep 16, 2022 12:58 am
If you write
    lda     #$100-1
    lda     #$FF
That's using immediate mode, which is always going to be an 8-bit value.
Then again if you try:
 LDA #256
you get code of A9 00 (LDA #0). So it wraps around.
PostPosted: Fri Sep 16, 2022 1:19 am
There is for LDX (op code $B6) and STX (op code $96), but nothing else.
PostPosted: Fri Sep 16, 2022 7:46 am
True, but he was talking about STA, not STX.
PostPosted: Fri Sep 16, 2022 7:53 am
 LDA #256
An argument can be made that should be flagged as an error.
cron
