Looking at the datasheets, pin assignments of DIP AS6C1008 are the same as pin assignments of SOJ CY7C109. Pin 1 is NC, pins 13-15, pins 17-21 are data, chip enable active low is 22, chip enable active high is 30, output enable is 24 and write enable is 29. VCC is 32 and GND is 16. I don't see any differences?
Greetings,
What I was meaning is that if we put a surface mount device on an adapter and have a straight through pinout, it is going to be an interesting outcome.
DIP pinouts between them are okay. The surface mount pinouts differ between DIP and SOJ32 or SOI or others.
The VCC and VSS pins change, along with the signals. How is it the adapter you made straight pin for pin works and not blowing up the SMD IC's?
The datasheet states for the .... oh crud, now I see it, the SOJ has the same pinout, it's the TSOP which has a different layout... no matter. Now I see it! Doh!
Your comment made me look again. Many times I looked at the datasheet and wondered then poof! Just cause a picture looks like a DIP or PDIP or some other, SOJ may be there, too.
Received the PCB's today. I think they will work well. I've only aligned the device by rolling my fingers, it's not soldered. Making sure it all is aligned. I think it will be a good device around my lab.
- William
