It is currently Mon Sep 23, 2024 6:36 am
PostPosted: Sun Aug 07, 2022 9:35 pm
Why is pulling from the stack on the 65816 always one cycle slower than pushing that same register to the stack?
I tend to think of these operations as pseudo-inverses of each other. Pushing and then pulling, or pulling and then pushing, generally restores the stack to the state it was before, but only pushing and then pulling keeps the state of the register the same; pulling and then pushing a register discards its old value.
But these operations still seem quite symmetric - what is the extra cycle spent doing during a pull?
PostPosted: Sun Aug 07, 2022 10:23 pm
It's the increment of the Stack Pointer. As you know, S points to the next available location -- not to the top item. So, to pull the top item, S must be incremented before the item is read. This consumes one cycle.
(For a push, the decrement of S happens after the write has occurred... and the decrement can be overlapped with the fetch of the next opcode, making it appear to consume zero cycles.)
PostPosted: Mon Aug 08, 2022 3:18 am
That explains a bit; always wondered about that myself.
PostPosted: Sat Aug 20, 2022 6:08 am
Very fascinating. I would be interested in seeing what parts of the processor can be engaged simultaneously during a single clock cycle. Since do a lot of adjacent pulls is so slow, I'm finding it useful to create stack unwinding macros that increment the stack pointer back to where it was at the beginning of the subroutine.
PostPosted: Sun Sep 04, 2022 7:47 pm
Are you talking about exception handling in assembly language? Something like this?
   \ let a subroutine in the nesting
   \ return to this subroutine's caller
   \ if there is an error
LABEL SOMEROUTINE
   TSX
   STX ERR_RETURN
   JSR SOMEWHERE
LABEL SOMEWHERE
   JSR SOMEWHERE_ELSE
LABEL SOMEWHERE_ELSE
   BCC NOERROR
   \ oops, there was an error
   LDX ERR_RETURN
   TXS
LABEL NOERROR
   RTS
   \ The main routine.
   JSR SOMEROUTINE
PostPosted: Tue Sep 06, 2022 6:42 am
Not really - I just wanted to speed up restoring the stack pointer.
PostPosted: Tue Sep 06, 2022 7:14 am
You can use TSX and then save X somewhere, so then you can use TXS to restore the previous stack pointer.
Possibly you can even store the previous stack pointer on the stack, after having put the things you want on there.
PostPosted: Tue Sep 06, 2022 4:22 pm
Yes, but if you've changed the stack pointer how would you get back the old one that was written to the stack, a stack whose location was changed after saving the entry stack pointer?
PostPosted: Tue Sep 06, 2022 4:32 pm
I think it's fairly normal, isn't it, to have a stack frame and to push the previous value?
PostPosted: Tue Sep 06, 2022 5:19 pm
Push the previous value to where?
If I arbitrarily change the stack pointer after pushing something, I no longer have the original stack pointer to tell me where to go to pull what I pushed. The only way in which one could use the stack to store the current stack pointer before changing it would be to treat the stack as memory, not a stack. That can be readily done with the 65C816 and some stack pointer arithmetic, but isn’t nearly as simple with the 65(C)02.
PostPosted: Tue Sep 06, 2022 5:39 pm
Well, one of us is confused!
PostPosted: Tue Sep 06, 2022 8:30 pm
I don't arbitrarily change the stack pointer. I use the stack for automatic variables like in C, and I can tell at edit-time how many bytes I have allocated, so stack unwinding becomes simply incrementing the stack pointer up that many bytes.
PostPosted: Tue Sep 06, 2022 9:12 pm
Had you considered saving and restoring it with TSX and TXS?
PostPosted: Tue Sep 06, 2022 10:17 pm
Yes that is how one of my stack unwinding macros works.
PostPosted: Wed Sep 07, 2022 1:30 am
That's adequate, as long as the function expects a fixed number of elements in the stack frame, and no recursion is involved. Get either one of those into the picture and you will need a more advanced means of processing the stack.
Users browsing this forum: Google [Bot] and 22 guests
