It is currently Fri Sep 20, 2024 4:31 pm
PostPosted: Tue Aug 30, 2022 8:22 am
I'm currently implementing a simple timer (Jiffy Clock) for my SBC.
So I try timer 1 in free run mode and want to count interrupts but nothing happens.
I look at the /IRQ pin of the 6522 with my logic analyzer and nothing happens there either.
My initialization currently looks like this:
    sei
   lda #%01111111
     sta VIA_IER  ; disable all interrupts
   ; setting free run mode with interrupts enabled
   lda #%01000000
     sta VIA_ACR
   lda #%11000000
     sta VIA_IER  ; enable interrupt for timer 1
   ; setting the vias timer 1 in free run mode, jiffy timer, load with
   lda #<JIFFY_VIA_TIMER_LOAD
   sta VIA_T1LL
   lda #>JIFFY_VIA_TIMER_LOAD
   sta VIA_T1LH
   cli
i also tried #%11000000, so that i can see an output on the PB7 pin, PB7 works, but no signal on the IRQ Pin.
When i trigger manually the IRQ Pin the IRQ Service routine worked.
IRQ is wired as wired-OR with an 3k3 Resistor to +5V.
The 6522 is an N Type- so should be ok with wired OR.
PS.: i did not change the IC.
don't count on me, i'm engineer (Animotion)
my arduino pages: http://rcarduino.de
PostPosted: Tue Aug 30, 2022 9:03 am
Write to T1CL and T1CH. I show how to do it in the 6502 interrupts primer, a little below the middle of the page. http://wilsonminesco.com/6502interrupts/#2.1 takes you to that section, and then the code starts several paragraphs below that.
PostPosted: Tue Aug 30, 2022 11:38 am
:oops:
I've seen it, I've read it and I ignored it when programming... sry :?
Jiffy Clock is working now.
many thanks...
