It is currently Fri Nov 22, 2024 4:12 am
 Post subject: Hardware design tipps
PostPosted: Sat Jul 09, 2022 8:48 pm
I've recently seen the breakdown of the Aegon Light schematics and PCB design. While not particularly 6502-related, the author goes into great detail explaining how to design the PCB for best high speed (clock & transitions) performance. Quite a lot of handy tipps! https://youtu.be/1gVx7XcETuM
PostPosted: Fri Aug 19, 2022 9:28 am
That was an informative watch. Thanks for sharing!
BB816 Computer YouTube series
PostPosted: Sat Aug 20, 2022 9:17 pm
Unfortunately this video is not giving very good advice.
bypass capacitors:  No, you don't need three values anymore.  Industry guru Eric Bogatin skewers the three-capacitor bypass thing (you know, the 10uF, 1uF, and .1uF or similar), in the ten minutes starting at https://www.youtube.com/watch?v=y4REmZlE7Jg&t=1550s (cued up).  He says that recommendation is no longer valid with SMT parts, and shows that a 22uF SMT capacitor has much lower overall impedance even in the high frequencies than a leaded 0.1uF capacitor does.
piezoelectric element:  No, you don't need an amplifier, or even a series capacitor.  Piezoelectric elements already act as mostly a small capacitor in the range of .02µF.  At audio frequencies (which is their only application), they take negligible current.
In his schematics, he has tags joining places that are not far apart.  Please just show a wire.  Don't make us search for tags.
ground on the USB connector:  He sure messed that up!
Differential pairs is something we don't deal with much (if at all) in 65xx work; but since he mentioned it:  It is worth noting that the return current for each line in the differential pair is mostly in the ground plane, not the other line.  See https://www.youtube.com/watch?v=icRzEZF3eZo&t=1920s (cued up).  You only need to watch for a few minutes.  Then he (Eric Bogatin) segues into crosstalk between lines.  I frequently see advice to separate the lines by three times their width; but that should instead say to separate them by three times their separation to the reference plane, regardless of their width (although the multiplier will depend on how much crosstalk is acceptable).
His PESD3V3L1BA transient voltage suppressor diodes have a typical capacitance of nearly 100pF which might be a problem in some cases.  It also takes up to 8V for 1A clamping current, and by that time the ICs' onboard static-protection diodes will already be blown.  If an IC doesn't have any such input-protection diodes, the TVS will definitely be good.  Otherwise I question the value.  I think it would be better to use small Schottky diodes to power and ground.
He did get the thing about all the ground vias mostly right.  However, if he were to swap the lower signal layer and the Vcc layer, the Vcc layer's distance to the ground plane won't be much different, and all signal traces can then reference the ground plane.  They normal stack-up on 4-layer boards is this way
     ___________
     ___________
     ___________
     ___________
with .010" separation between layers 1 & 2, .040" separation between layers 2 & 3, and .010" separation between layers 3 & 4.
The following is from the bottom of the AC-performance page of the 6502 primer:
(and of course after you've watched one or more, you'll get suggestions for related videos down the right side of your screen.)
Eric Bogatin has a book out, "Bogatin’s Practical Guide to Transmission Line Design and Characterization for Signal Integrity Applications" which I'd like to get, but I can't bring myself yet to pay $100 for it!  https://www.amazon.com/Practical-Transm ... B089YYPRH8
PostPosted: Fri Nov 18, 2022 8:02 am
However, if he were to swap the lower signal layer and the Vcc layer, the Vcc layer's distance to the ground plane won't be much different, and all signal traces can then reference the ground plane.  The normal stack-up on 4-layer boards is this way
     ___________
     ___________
     ___________
     ___________
I asked DirtyPCBs what the normal stackup was for 1.2mm-thick and 1.6mm-thick boards in 4-, 6-, and 8-layer, and here's the answer I got:
4-Layer, 1.2mm (.047") stackup:
1oz copper | 0.21mm FR4 | 0.5oz copper | 0.7mm FR4 | 0.5oz copper | 0.21mm FR4 | 1oz copper
Layer spacing in inches: .0083", .028", .0083"
4-layer, 1.6mm (.062") stackup:
1oz copper | 0.21mm FR4 | 0.5oz copper | 0.107mm FR4 | 0.5oz copper | 0.21mm FR4 | 1oz copper
Layer spacing in inches: .0083", .042", .0083"
6-layer, 1.2mm (.047") stackup:
1oz copper | 0.1mm FR4 | 0.5oz copper | 0.35mm FR4 | 0.5oz copper | 0.11mm FR4 | 0.5oz copper | 0.35mm FR4 | 0.5oz copper | 0.1mm FR4 | 1oz copper
Layer spacing in inches: .0039", .0138", .0043", .0138", .0039"
6-layer, 1.6mm (.062") stackup:
1oz copper | 0.1mm FR4 | 0.5oz copper | 0.55mm FR4 | 0.5oz copper | 0.11mm FR4 | 0.5oz copper | 0.55mm FR4 | 0.5oz copper | 0.1mm FR4 | 1oz copper
Layer spacing in inches: .0039", .0217", .0043", .0217", .0039"
8-layer, 1.2mm (.047") stackup:
1oz copper | 0.1mm FR4 | 0.5oz copper | 0.2mm FR4 | 0.5oz copper | 0.11mm FR4 | 0.5oz copper | 0.2mm FR4 | 0.5oz copper | 0.11mm FR4 | 0.5oz copper | 0.2mm FR4 | 0.5oz copper | 0.1mm FR4 | 1oz copper
Layer spacing in inches: .0039", .0079", .0043", .0079", .0043", .0079", .0039"
8-layer, 1.6mm (.062") stackup:
1oz copper | 0.12mm FR4 | 0.5oz copper | 0.3mm FR4 | 0.5oz copper | 0.15mm FR4 | 0.5oz copper | 0.3mm FR4 | 0.5oz copper | 0.15mm FR4 | 0.5oz copper | 0.3mm FR4 | 0.5oz copper | 0.12mm FR4 | 1oz copper
Layer spacing in inches: .0047", .0118", .0059", .0118", .0059", .0118", .0047"
Note that the inside layers' copper thickness is only half that of the outside layers', ½oz instead of 1oz, meaning .0007" instead of .0014".
I drew this up approximately to scale, to give a better visual idea.  (I did not do the 1.2mm 8-layer.)
