Yes, the Pocket-SBC is just that... take it with you. It's not battery powered however... either USB or a separate 5V regulated supply. I always have my MacBook Pro with me, so I can attach to that and use the "Serial" app for a console and work away as I care to, including writing code and transferring via Xmodem-CRC to the Pocket-SBC.
Onboard I/O is:
NXP SC28L92 DUART - (one channel is a USB console using an FTDI chip), other channel available on connector and timer used for jiffy-clock.
Maxim DS1501 Realtime Clock - RTC and Alarm function plus NVRAM holds configuration data for selectable profiles.
Hitachi Microdrive with PATA interface - 6GB rotating hard drive... very good performance, adequate storage and low power. Working with a prototype 3.3V system now running DOS/65.
The rest is a couple momentary switches for Reset and Panic (NMI), a power switch and a few indicator LEDs for Power, USB activity and Microdrive activity.
Semiconductor shortage... yea, it's not fun! I've not been able to easily source some chips I'd like to experiment with and my new car ordered in July 2021 is still not completed, waiting for specific modules, which are waiting on chips to get completed. Who knew it could get this bad
