Cheers Adrian - no worries, I'm not seeking anything here, just mumbling about what I'd quite like to do if I had the energy, and was never grumpy!
(Sorry, all of this has veered a bit from the topic, but I'm finding it interesting so I'll keep going...)
Google search "foo AND bar site:forum.6502.org" (again those are my quotes) for example with search for posts containing foo and bar. The internal search, when asked to find foo AND bar would return any posts with "foo" or "and" or "bar".
Indeed, I use "site:" really very often. (I believe you don't need the AND with Google, although over time they have become increasingly fuzzy. I know some search facilities assume OR, but these days I find most of them assume AND - which to my mind is the right way to go.)
Someone mentioned the other day that the Stardot forum assumes OR - and I was surprised, as I was surprised right here and now, because in my experience both Stardot and this forum will assume AND when I search for multiple words.
(For example, "wonderful additions" presently finds only a single match, here, although once I've posted this it will probably be two matches. Whereas, "wonderful" finds 249 and "additions" finds 207.)
Maybe for some people the preference in search is set to "Search for any terms" whereas for me it's set to "Search for all terms or use query as entered". Maybe in the distant past I changed it, and that's why I'm seeing different behaviour?
I too find that stop words(*) in forum search can be a hindrance... although right now I can't seem to find any - even "the" is not too common to be a valid word. Maybe Mike tweaked the forum to be more generous?
One final tip from me on search: the forum search will allow limited wildcards, so "board*" will match both "board" and "boards".
(*) "The following words in your search query were ignored because they are too common words:"
