It is currently Sun Sep 29, 2024 3:30 am
 Post subject: 901447-18
PostPosted: Thu Jun 30, 2022 3:39 am
First post, so please excuse me if this is the wrong sub-forum.
I have a PET ROM tester board that has a 901447-18 chip on it and i could only find one single reference for that in all of the Google searchiverse.
Maybe someone here has any knowledge about this?
The tester board is the same as seen here under "Diagnostic Clip/Inside View", a rather crudely made 320370 Rev A:
http://www.6502.org/users/andre/petindex/diag/index.html
The only search result on google is this:
http://mhv.bplaced.net/cbmroms/cbmroms.php
And i just added it to here:
https://www.c64-wiki.com/wiki/MOS_Technology_Products
8) Andy
 Post subject: Re: 901447-18
PostPosted: Thu Jun 30, 2022 7:34 am
Welcome! It would be great if you could find a way - a safe way - to dump this ROM, and share the contents.
PostPosted: Thu Jun 30, 2022 3:16 pm
Thank you for the welcome.
I hope i can get it out of the socket safely, there is quite a bit of corrosion on the pins on one side.
I have a Retro Chip Tester Pro and it supports the 2316B type ROMs so i should be able to read it out.
PostPosted: Thu Jun 30, 2022 3:19 pm
Sounds good!
PostPosted: Thu Jun 30, 2022 4:52 pm
You might be able to free up those pins by putting a drop of WD-40 on each one using a cotton swab (aka Q-Tip®) and letting it “soak” for about 20 minutes. WD-40 is non-conductive and safe for this sort of thing.
PostPosted: Thu Jun 30, 2022 11:13 pm
Didn't have any WD-40 but figured my Deoxit should work similar. Let it soak for an hour and the chip came out smooth as butter.
I ran it through the RCTP several times to make sure i got the same checksum (081c7aad) and then dumped the ROM to SD.
So here it is, i haven't looked at the disassembly yet but i can see some readable text in there so i'm hopeful it worked OK.
PostPosted: Thu Jun 30, 2022 11:14 pm
Hmm, i guess i can't attach *.bin files?
PostPosted: Thu Jun 30, 2022 11:18 pm
How about a hex dump?
00000000h: A2 80 9A D8 A2 00 8A 9D 00 80 A9 20 9D 00 81 9D 00 82 9D 00 83 E8 D0 EE A2 12 BD 81 99 9D 8F 81 ; ¢€šØ¢.Š.€© ..‚.ƒèÐî¢.½™
00000020h: CA D0 F7 CA 8A 5D 00 80 F0 4C A9 FF 9D 00 80 5D 00 80 D0 22 9D 00 80 5D 00 80 D0 1A A0 0A B9 B8 ; ÊÐ÷ÊŠ].€ðL©ÿ.€].€Ð".€].€Ð. .¹¸
00000040h: 99 99 DF 81 88 D0 F7 E8 8A CE E1 81 0A 90 FA FE 00 80 E8 4C 4F 98 A0 B8 29 0F D0 01 88 8C E0 81 ; ™™ßˆÐ÷èŠÎá.úþ.€èLO˜ ¸).Ð.ˆŒà
00000060h: A0 86 8C E1 81 A0 08 B9 A7 99 99 E1 81 88 D0 F7 FE 00 80 4C 70 98 8A D0 AA A2 09 BD 9D 99 9D DF ;  †Œá .¹§™™áˆÐ÷þ.€Lp˜ŠÐª¢.½™ß
00000080h: 81 CA D0 F7 A9 00 9D 00 01 E8 D0 FA 8A 95 00 E8 D0 FA CA 8A 55 00 F0 47 A9 FF 95 00 55 00 D0 1F ; ÊÐ÷©...èÐúŠ•.èÐúÊŠU.ðG©ÿ•.U.Ð.
000000a0h: 95 00 55 00 D0 19 A0 0A B9 B8 99 99 2F 82 88 D0 F7 E8 8A CE 31 82 0A 90 FA F6 00 E8 4C B9 98 9A ; •.U.Ð. .¹¸™™/‚ˆÐ÷èŠÎ1‚.úö.èL¹˜š
000000c0h: A2 B1 E8 0A 90 FC 8E 30 82 A2 09 BD A6 99 9D 30 82 CA D0 F7 BA 95 00 9D 00 01 91 02 4C D5 98 8A ; ¢±è.üŽ0‚¢.½¦™0‚ÊÐ÷º•...‘.LÕ˜Š
000000e0h: D0 B0 A2 09 BD AF 99 9D 2F 82 CA D0 F7 A0 01 BD 00 01 F0 17 A0 0A B9 B8 99 99 7F 82 88 D0 F7 85 ; а¢.½¯™/‚ÊÐ÷ .½..ð. .¹¸™™‚ˆÐ÷…
00000100h: 00 8D FF 01 85 AA 8D 55 01 F0 F4 98 9D 00 01 C8 E8 D0 DC 98 5D 00 01 D0 A6 C8 E8 D0 F6 A0 08 B9 ; .ÿ.…ªU.ðô˜..ÈèÐܘ]..ЦÈèÐö .¹
00000120h: C2 99 99 7F 82 88 D0 F7 84 02 A9 01 85 03 A9 99 85 01 A2 07 B1 00 91 02 C8 D0 F9 E6 01 E6 03 CA ; ™™‚ˆÐ÷„.©.….©™….¢.±.‘.ÈÐùæ.æ.Ê
00000140h: D0 F2 A2 07 C6 01 C6 03 B1 02 D1 00 F0 20 A9 FF 91 02 51 02 D0 C1 91 02 51 02 D0 BB A2 0A BD 93 ; Ðò¢.Æ.Æ.±.Ñ.ð ©ÿ‘.Q.ÐÁ‘.Q.л¢.½“
00000160h: 99 9D CF 82 CA D0 F7 85 7F 8D 80 3F F0 F9 C8 D0 D7 CA D0 D0 A2 0A BD CB 99 9D D0 82 CA 10 F7 4C ; ™Ï‚ÊÐ÷…€?ðùÈÐ×ÊÐТ.½Ë™Ð‚Ê.÷L
00000180h: D6 01 04 09 01 07 0E 0F 13 14 09 03 20 33 32 30 33 35 30 05 81 B8 AD 81 B1 B1 A0 82 81 84 14 16 ; Ö........... 320350.¸­±± ‚„..
000001a0h: 20 12 01 0D 20 0F 0B 89 AD 92 81 8D A0 82 81 84 1A 2D 10 01 07 05 20 0F 0B 81 B8 AD 81 84 92 A0 ;  ... ..‰­’ ‚„.-.... ..¸­„’
000001c0h: 82 81 84 13 14 01 03 0B 20 0F 0B 12 05 0D 0F 16 05 20 03 0C 09 10 A9 06 85 09 20 85 06 A2 0B BD ; ‚„..... ........ ....©.…. ….¢.½
000001e0h: CF 82 49 80 9D CF 82 CA D0 F5 EC FC FF F0 E7 C6 09 10 E7 A2 0A A9 20 9D D0 82 CA 10 FA A9 20 8C ; Ï‚I€Ï‚ÊÐõìüÿðçÆ..ç¢.© Ð‚Ê.ú© Œ
00000200h: 00 40 CC 00 40 D0 12 8E 00 40 EC 00 40 D0 0A 0A A2 33 8E 78 07 CA 8E 79 07 85 0E 0A 38 E9 08 85 ; .@Ì.@Ð.Ž.@ì.@Ð..¢3Žx.ÊŽy.…..8é.…
00000220h: 0D A2 02 20 3A 06 F0 10 A2 0A BD 25 07 9D CF 82 CA D0 F7 8D 00 E0 F0 FB A9 1B CD FE FF D0 07 A9 ; .¢. :.ð.¢.½%.Ï‚ÊÐ÷.àðû©.ÍþÿÐ.©
00000240h: E6 CD FF FF F0 13 A2 0A BD 25 07 9D CF 82 CA D0 F7 EE D0 82 8D 00 F0 D0 FB A2 06 BD 2F 07 9D CF ; æÍÿÿð.¢.½%.Ï‚ÊÐ÷îЂ.ðÐû¢.½/.Ï
00000260h: 82 CA D0 F7 20 85 06 CE D5 82 AD D5 82 C9 30 D0 F3 20 DE E1 A2 08 20 FE 06 58 20 D1 06 F0 0F 30 ; ‚ÊÐ÷ ….ÎÕ‚­Õ‚É0Ðó Þá¢. þ.X Ñ.ð.0
00000280h: 56 A2 08 20 9B 06 20 29 E2 20 85 06 F0 F3 A2 08 20 A5 06 20 D1 06 F0 E9 A2 04 20 A5 06 A2 0D 20 ; V¢. ›. )â ….ðó¢. ¥. Ñ.ðé¢. ¥.¢.
000002a0h: C4 06 A5 8F 20 85 06 C5 8F D0 03 4C 37 04 A9 FE 85 8F A5 8F D0 FC AA A8 C8 D0 0B E8 D0 08 A2 0D ; Ä.¥ ….ŏÐ.L7.©þ…¥Ðüª¨ÈÐ.èÐ.¢.
000002c0h: 20 9B 06 4C 37 06 A5 8F F0 EE A9 E1 20 1A 07 C9 04 B0 04 E0 05 F0 04 A2 15 D0 E5 A2 0D 20 B3 06 ;  ›.L7.¥ðî©á ..É.°.à.ð.¢.Ðå¢. ³.
000002e0h: CE 13 E8 2C 12 E8 A2 19 20 C4 06 A0 00 2C 4F E8 10 05 88 D0 F8 F0 1B A0 00 2C 4F E8 30 05 88 D0 ; Î.è,.è¢. Ä. .,Oè..ˆÐøð. .,Oè0.ˆÐ
00000300h: F8 F0 0F A0 0A 2C 4F E8 30 FB 88 D0 FD 2C 4F E8 30 06 20 9B 06 4C 37 06 EE FF FF 2C 4F E8 30 F2 ; øð. .,Oè0ûˆÐý,Oè0. ›.L7.îÿÿ,Oè0ò
00000320h: 20 B3 06 A2 22 20 C4 06 A0 FF 84 06 C8 A6 0D 84 00 A9 08 85 01 98 18 65 01 45 06 91 00 A5 00 D0 ;  ³.¢" Ä. ÿ„.Ȧ.„.©.….˜.e.E.‘.¥.Ð
00000340h: 24 C8 D0 F1 E6 01 CA D0 EC A6 0D C6 01 98 18 65 01 45 06 51 00 F0 60 A9 FF 91 00 51 00 D0 33 91 ; $ÈÐñæ.ÊÐì¦.Æ.˜.e.E.Q.ð`©ÿ‘.Q.Ð3‘
00000360h: 00 51 00 D0 2D A2 37 E6 01 A5 01 E8 4A 90 FC A9 41 20 BA 06 8A C9 3A 90 0A 38 E9 0A 48 A9 31 20 ; .Q.Ð-¢7æ.¥.èJü©A º.ŠÉ:.8é.H©1
00000380h: BA 06 68 20 BA 06 A2 29 20 9B 06 85 7F 8D 80 3F 30 F9 A2 31 E8 0A 90 FC 8A 20 BA 06 A2 49 A5 01 ; º.h º.¢) ›.…€?0ù¢1è.üŠ º.¢I¥.
000003a0h: C5 0E 90 01 E8 8A 20 BA 06 A2 25 20 9B 06 A9 AA 91 00 4A 91 00 90 F7 C8 D0 93 CA D0 8E E6 06 D0 ; Å..èŠ º.¢% ›.©ª‘.J‘.÷ÈГÊÐŽæ.Ð
000003c0h: 03 4C 2D 03 A2 22 20 B3 06 A2 1F 20 C4 06 A2 03 20 3A 06 F0 0F 8A 18 69 36 20 BA 06 A2 1D 20 9B ; .L-.¢" ³.¢. Ä.¢. :.ð.Š.i6 º.¢. ›
000003e0h: 06 4C 37 06 CA 10 E9 A2 1F 20 B3 06 A2 2D 20 C4 06 A9 FD A0 09 8C 10 E8 CD 12 E8 F0 0D 20 9B 06 ; .L7.Ê.é¢. ³.¢- Ä.©ý .Œ.èÍ.èð. ›.
00000400h: A0 0A 8C 10 E8 88 10 FA 30 F6 4A 90 02 09 80 88 10 E3 8C 10 E8 CC 12 E8 D0 E3 20 B3 06 A2 33 20 ;  .Œ.èˆ.ú0öJ..€ˆ.ãŒ.èÌ.èÐã ³.¢3
00000420h: C4 06 A2 00 20 FE 06 A9 C0 8D 4E E8 CA 8E 44 E8 8E 45 E8 58 20 85 06 A2 37 A9 7F 8D 4E E8 20 A0 ; Ä.¢. þ.©ÀNèÊŽDèŽEèX ….¢7©Nè
00000440h: 06 4C 37 06 2C 4D E8 A9 7F 8D 4E E8 AD 44 E8 70 18 A2 09 BD 35 07 9D FF 7F CA D0 F7 A2 1F A9 20 ; .L7.,M詍Nè­Dèp.¢.½5.ÿÊÐ÷¢.©
00000460h: 9D 08 80 CA D0 FA 4C 37 06 A2 33 68 C9 F7 D0 05 68 C9 CD F0 05 20 9B 06 30 C7 20 B3 06 A2 46 20 ; .€ÊÐúL7.¢3hÉ÷Ð.hÉÍð. ›.0Ç ³.¢F
00000480h: C4 06 A2 02 20 FE 06 A9 A0 8D 4E E8 A2 FF 8E 48 E8 8E 49 E8 58 20 85 06 F0 9D AD 4D E8 29 20 F0 ; Ä.¢. þ.© Nè¢ÿŽHèŽIèX ….ð­Mè) ð
000004a0h: B0 A9 7F 8D 4E E8 AD 48 E8 A2 46 68 C9 F7 D0 C5 68 C9 CD D0 C0 20 B3 06 A2 50 20 C4 06 A2 04 20 ; °©Nè­Hè¢FhÉ÷ÐÅhÉÍÐÀ ³.¢P Ä.¢.
000004c0h: FE 06 A9 F7 8D 40 E8 EE 11 E8 2C 10 E8 58 0E 40 E8 4E 40 E8 20 85 06 78 CE 11 E8 2C 10 E8 4C 37 ; þ.©÷@èî.è,.èX.@èN@è ….xÎ.è,.èL7
000004e0h: 04 CE 11 E8 10 35 2C 10 E8 A2 50 20 B3 06 A2 55 20 C4 06 A2 06 20 FE 06 A9 90 8D 4E E8 2C 40 E8 ; .Î.è.5,.è¢P ³.¢U Ä.¢. þ.©Nè,@è
00000500h: 58 0E 40 E8 4E 40 E8 20 85 06 F0 D2 AD 4D E8 A0 7F 8C 4E E8 AC 40 E8 29 10 D0 03 4C 51 04 A2 55 ; X.@èN@è ….ðÒ­Mè ŒNè¬@è).Ð.LQ.¢U
00000520h: 20 B3 06 A2 5A 20 C4 06 A0 00 98 8D 22 E8 4D 20 E8 F0 18 48 20 A0 06 68 A2 30 E8 4A 90 FC 8A 20 ;  ³.¢Z Ä. .˜"èM èð.H  .h¢0èJüŠ
00000540h: BA 06 20 9E 06 EE 22 E8 4C 45 05 C8 D0 DC 20 B3 06 A2 62 20 C4 06 A2 6B 2C 20 E8 A0 04 20 90 06 ; º. ž.î"èLE.ÈÐÜ ³.¢b Ä.¢k, è . .
00000560h: 2C 21 E8 30 08 20 9B 06 20 90 06 D0 FB A2 71 A0 02 2C 40 E8 50 EF 20 93 06 2C 40 E8 70 E7 20 93 ; ,!è0. ›. .Ðû¢q .,@èPï “.,@èpç “
00000580h: 06 A2 6E A0 3C 8C 23 E8 2C 40 E8 10 29 A9 34 8D 23 E8 2C 40 E8 30 1F A2 79 8C 11 E8 2C 10 E8 50 ; .¢n <Œ#è,@è.)©4#è,@è0.¢yŒ.è,.èP
000005a0h: 18 8D 11 E8 2C 10 E8 70 10 A2 75 8C 21 E8 4E 40 E8 B0 1B A0 21 2C A0 23 2C A0 11 20 9B 06 8C C7 ; ..è,.èp.¢uŒ!èN@è°. !, #, . ›.ŒÇ
000005c0h: 05 8C CA 05 A9 08 4D 00 E8 8D 00 E8 D0 F6 8D 21 E8 4E 40 E8 B0 DD A2 7C 2C 22 E8 EE 43 E8 CE 43 ; .ŒÊ.©.M.è.èÐö!èN@è°Ý¢|,"èîCèÎC
000005e0h: E8 2C 23 E8 30 0B 20 9B 06 EE 43 E8 CE 43 E8 F0 F8 A2 62 20 B3 06 A2 05 FE DC 07 BD DC 07 C9 3A ; è,#è0. ›.îCèÎCèðø¢b ³.¢.þÜ.½Ü.É:
00000600h: 90 0A A9 30 9D DC 07 CA 10 EE 30 EA A2 7F 20 A0 06 A9 92 20 D8 E3 20 85 06 AD 41 E8 29 04 D0 08 ; .©0Ü.Ê.î0ê¢  .©’ Øã ….­Aè).Ð.
00000620h: A9 0D 20 D8 E3 4C 23 03 A2 0E A9 14 20 D8 E3 CA D0 FA 20 85 06 F0 D5 4C 37 06 BD 3F 07 85 09 BD ; ©. ØãL#.¢.©. ØãÊÐú ….ðÕL7.½?.….½
00000640h: 43 07 85 01 A9 00 85 07 85 08 85 00 A8 18 71 00 90 06 E6 07 D0 02 E6 08 C8 D0 F2 E6 01 C6 09 D0 ; C.….©.….….….¨.q..æ.Ð.æ.ÈÐòæ.Æ.Ð
00000660h: EC DD 47 07 D0 0E A5 07 DD 4C 07 D0 07 A5 08 DD 51 07 F0 08 E0 02 D0 04 A2 04 D0 E5 08 E0 04 D0 ; ìÝG.Ð.¥.ÝL.Ð.¥.ÝQ.ð.à.Ð.¢.Ðå.à.Ð
00000680h: 02 A2 02 28 60 A2 00 A0 00 88 D0 FD CA D0 FA 60 20 93 06 98 4D 40 E8 8D 40 E8 60 20 A0 06 A2 00 ; .¢.(`¢. .ˆÐýÊÐú` “.˜M@è@è`  .¢.
000006a0h: A9 12 20 D8 E3 BD 56 07 08 29 7F 20 D8 E3 E8 28 10 F3 60 20 A5 06 A2 04 D0 EB 48 A9 12 20 D8 E3 ; ©. Øã½V..) Øãè(.ó` ¥.¢.ÐëH©. Øã
000006c0h: 68 4C D8 E3 86 0C 20 A5 06 A2 4A 20 A5 06 A6 0C 60 A2 00 A0 00 2C 41 E8 50 08 88 D0 F8 CA D0 F5 ; hLØã†. ¥.¢J ¥.¦.`¢. .,AèP.ˆÐøÊÐõ
000006e0h: CA 60 A2 00 A0 00 2C 4F E8 70 08 88 D0 F8 CA D0 F5 F0 ED 2C 4F E8 70 FB AD 4D E8 29 02 60 78 BD ; Ê`¢. .,Oèp.ˆÐøÊÐõðí,Oèpû­Mè).`x½
00000700h: E3 07 85 90 BD E4 07 85 91 60 2C 13 E8 30 03 4C 51 04 E6 8F 2C 12 E8 4C E4 E6 84 07 38 E5 07 10 ; ã.…½ä.…‘`,.è0.LQ.æ,.èLäæ„.8å..
00000720h: 04 49 FF 69 01 60 B8 84 AD 92 8F 8D A0 82 81 84 09 0E 09 14 20 39 97 92 8F 8E 87 A0 89 92 91 10 ; .Iÿi.`¸„­’ ‚„.... 9—’Ž‡ ‰’‘.
00000740h: 10 08 10 C0 D0 E0 F0 38 6A BF 98 EA 38 50 FD 7C 05 07 07 03 08 04 20 42 41 C4 20 4F 4B 8D 56 49 ; ...ÀÐàð8j¿˜ê8Pý|...... BAÄ OKVI
00000760h: 44 45 CF 36 30 48 5A 20 49 52 D1 56 45 52 D4 48 4F 52 DA 44 2D 52 4F CD 31 36 4B 2D 52 41 CD 2D ; DEÏ60HZ IRÑVERÔHORÚD-ROÍ16K-RAÍ-
00000780h: 41 44 D2 4B 45 59 42 52 C4 54 4D 52 B1 4E 4F 20 49 52 D1 57 52 4F 4E 47 20 49 52 D1 54 4D 52 B2 ; ADÒKEYBRÄTMR±NO IRÑWRONG IRÑTMR²
000007a0h: 20 54 45 53 54 8D 43 41 53 53 B1 43 41 53 53 B2 49 45 45 45 20 44 49 CF 49 45 45 45 20 43 54 52 ;  TESTCASS±CASS²IEEE DIÏIEEE CTR
000007c0h: CC 41 54 CE 44 41 D6 4E 52 46 C4 4E 44 41 C3 45 4F C9 53 52 D1 20 43 59 43 4C 45 20 30 30 30 30 ; ÌATÎDAÖNRFÄNDAÃEOÉSRÑ CYCLE 0000
000007e0h: 30 30 A0 44 04 9A 04 E1 04 0C 05 0A 07 AA AA AA AA AA AA AA AA AA AA AA AA AA AA AA 00 98 AA FF ; 00 D.š.á.....ªªªªªªªªªªªªªªª.˜ªÿ
PostPosted: Fri Jul 01, 2022 12:27 am
I also disassembled the ROM, if anyone is interested.
Can i attach text files here?
PostPosted: Fri Jul 01, 2022 3:09 am
CybAtSteam wrote:
Hmm, i guess i can't attach *.bin files? :(
Embed the binary file into a ZIP file and you should be okay.
Yes.
PostPosted: Fri Jul 01, 2022 3:20 am
Yes.
Alright, here's a *.zip with the .bin binaries and the .txt disassembly.
8)
NOTE: I updated the zip file with the new disassembly starting at $9800
901447-18.zip [10.62 KiB]
Downloaded 27 times
PostPosted: Fri Jul 01, 2022 3:25 am
8)
Looking through the disassembly, i put it at $9000 as a base but that might not be right.
The last 4 bytes have jump vectors to $9800 and $FFAA. Hopefully that makes sense to somebody out there.
:wink:
PostPosted: Fri Jul 01, 2022 7:37 am
Well done, and thanks for preserving it!
PostPosted: Fri Jul 01, 2022 8:51 am
Looking at the absolute references in the early part of the code $9800 might bea good candidate for the origin?
PostPosted: Fri Jul 01, 2022 3:53 pm
Martin A wrote:
Looking at the absolute references in the early part of the code $9800 might be good candidate for the origin?
I agree, the base address looks to be $9800. I did another disassembly with that, see attached .txt file.
PS: I also updated the .zip file above with the new disassembly
901447-18.9800.txt [40.53 KiB]
Downloaded 40 times
cron
