It is currently Sat May 11, 2024 5:39 pm
PostPosted: Mon Jun 27, 2022 9:49 am
So I'm trying to teach myself CPLD programming and just ran out of talent. I've got some decoding logic working fine and decided the next step would be to implement a counter on an ATF1502S.
I figured I'd start on the nursery slopes with a simple decade counter. When I try to compile this, however, I get an error. The compilation, with cupl.exe, works fine. But when I run find1502.exe, I get the error:
Atmel ATF1502AS Fitter Version 1.8.7.8 (02-05-03)
Copyright 1999,2000 Atmel Corporation
Error - Node Q3 is registered and there is no .CLK in .olb
Reading input file failed ...
Here is my code:
Name      COUNT10;
Partno    00;
Date      27/06/2022;
Revision  01;
Designer  SMD;
Company   ;
Assembly  ;
Location  ;
Device    f1502tqfp44;
/* Decade Counter                                              */
/**  Inputs  **/
PIN 15        = pulse;           /* Counter clock              */
PIN 44        = clr;             /* Counter clear input        */
/**  Outputs  **/
PIN [28,25,22,19] = [Q3..0];     /* Counter outputs on LEDs    */
FIELD count = [Q3..0];          /* Counter output bit field    */
$repeat i = [0..9]
$define S{i} 'b'{i}             /* Creates S0-S9 with vals 0-9 */
$repend
/** State machine **/
SEQUENCE count {
$repeat i = [0..9]
  present S{i}
     if pulse next S{(i+1)%10};
    if clr next S0;
     default next S{i};
$repend
I'm compiling with:
C:\Wincupl\Shared\cupl.exe -j -a -l -e -x -f -b -m4 f1502tqfp44 COUNT10
And running find1502 with:
find1502 -i E:\NasSync\DEV\Dev-PLD\CUPL_Projects\COUNT10\COUNT10.tt2 -CUPL -dev P1502T44 -str JTAG ON -str logic_doubling off
I rechecked my previous projects and they're still working fine, so I haven't borked my dev setup.
What am I doing wrong?
[EDIT] Just realised that Atmel docs actually have this precise thing as an example. I'll be back once I've read that.
[EDIT 2] Turns out the Atmel example was the code on which I'd based mine anyway. And the Atmel code produces the same error, even when I remove all specific pin assignments and let the fitter decide on pins.
I like it when things smoke.
BlogZolatron 64 project
PostPosted: Mon Jun 27, 2022 4:04 pm
Howdy! I think the problem is that the way you're using the PULSE signal leads to behaviour that's not what you expect. In your state machine, PULSE is used as a combinational input—basically, you're asking the PLD to only count forward if PULSE is active.
This doesn't actually make the PLD use that signal as a clock; instead, I think you have to explicitly define the clock used by the FSM's flip-flops by using the .CK extension. Try something like this—this compiles fine for me, but I don't have any ATF-15 devices to test with, so I'm not sure if it's right:
Name      COUNT10;
Partno    00;
Date      27/06/2022;
Revision  01;
Designer  SMD;
Company   ;
Assembly  ;
Location  ;
Device    f1502tqfp44;
/**  Inputs  **/
/**  Outputs  **/
$repeat i = [0..9]
$repend
/** Define clock source for flip-flops **/
Q0.CK = pulse;
Q1.CK = pulse;
Q2.CK = pulse;
Q3.CK = pulse;
SEQUENCE count {
$repeat i = [0..9]
  present S{i}
    if clr next S0;
    default next S{(i+1)%10};
$repend
I think that the examples in the book are meant for devices (like the 22V10) that have a single clock line, and so which clock signal to use is implicit; I believe that, on the ATF15, you can use any input as a clock, and so it looks like you have to explicitly set it.
I hope this helps!
—Marco
PostPosted: Mon Jun 27, 2022 7:57 pm
I'll give that a whirl. Many thanks.
PostPosted: Tue Jun 28, 2022 9:21 am
Yep, that did the trick!
The clr button has no effect, but hey - one problem at a time!
EDIT: This sorted the clr button:
Q0.ar = clr;
Q1.ar = clr;
Q2.ar = clr;
Q3.ar = clr;
PostPosted: Tue Jun 28, 2022 12:01 pm
Glad that worked! I didn't even think about the asynchronous reset… I guess it makes sense that you'd have to specify it as well (at least as far as anything ever makes sense with WinCUPL…). Cheers!
cron
