It is currently Sat Nov 23, 2024 8:46 am
PostPosted: Sat Apr 23, 2022 2:57 pm
I'm relatively new to 65816 assembly, and I'm wondering if I'm missing a simpler way to write to 8-bit registers on devices such as VIAs and PSGs. I have some code where the logic really benefits from the 16-bit accumulator. However, I need to write to a VIA and some PSGs which have 8-bit registers. I am switching my accumulator to 8-bit anytime that I write to these registers. Is this the proper approach, or is this some shortcut to STA, while using a 16-bit accumulator, that allows me to write a single byte and not two bytes? If writing two bytes, it updates the desired register plus the register at the next address. Thanks!
PostPosted: Sat Apr 23, 2022 4:40 pm
Okay, what about X and Y -- is it reasonable to keep those in 8-bit mode? They'd be fine for simple reads and writes to the 8-bit peripheral (but of course with X and Y you can't easily do AND OR EOR etc).
The other solution involves hardware. Just redefine the IO address decoding such that every other address is unused. For example, a 6522 VIA would occupy 32 (not 16) bytes of address space. Within the 32-byte space, all the even addresses would select the VIA, and all the odd addresses would select nothing.
This allows the CPU to do a 16-bit access while only touching the VIA once. On writes, the extra 8 bits get written to nowhere. But remember -- on reads, the extra 8 bits will contain undefined data, so your code will need to be on guard for that.
PostPosted: Sat Apr 23, 2022 5:01 pm
That's a nice solution. And this is probably a bit crazy, but if you were feeling particularly adventurous you could wire up a second 6522 to cover the odd addresses. Between the two of them you'd then have 16-bit wide I/O ports. The timers and shift register wouldn't really extend so naturally though.
PostPosted: Sat Apr 23, 2022 5:14 pm
In the I/O primitives of my POC units, I have arranged the code so as much as the precursory 16-bit processing as possible is done before the actual device access. If you find yourself constantly using REP and SEP you should carefully study the program flow to determine how to reduce register size switching. You may find you are unnecessarily using REP and SEP when a slight code change would allow you to keep the register sizes constant for a greater number of instructions.
Something else to consider is this: just because you can do something with 16-bit registers doesn’t mean you should. While 16-bit processing will generally speed up a program and reduce its size to some extent, you have to look at the overall picture. In some cases, keeping register sizes at eight bits may be more efficient, precisely because you aren’t constantly using REP and SEP. Also, a 16-bit load/store incurs a one cycle penalty, which can negatively affect performance in a loop.
Something that I have evolved in my 65C816 code is the concept of using data structures whose sizes are in multiples of words, i.e., 16- and 32-bit pointers, counters, etc. For example, suppose I have a flag that is tested with the BIT instruction and whose possible states are $00, $80 and $C0. If I make that flag a 16-bit location, my possible states are $0000, $8080 and $C0C0. That being the case, I can test the flag with the accumulator set to either size and see identical results. Now it becomes a matter of convenience as to what the accumulator’s size should be when BITing the flag, not a matter of necessity.
The technique of using 16-bits for intermediate storage, even in cases in which an eight-bit value would suffice, works well in functions that use the stack as fugacious workspace. PEA, PEI and PER write 16 bits at a time. So it becomes more efficient to “waste” some stack space so PEA, PEI and PER can be used where they offer the most efficiency.
In the same vein, while indirect-long addressing uses a 24-bit pointer, the reality is such a size is awkward—the 816 doesn't have the ability to atomically load, process or store a 24-bit quantity in a single instruction. Ergo I use 32-bit pointers, which allow me to do pointer arithmetic in word-size chunks, which is convenient with the accumulator is set to 16 bits. Fewer REPs and SEPs are required when manipulating complex data structures, and the code becomes more compact and faster-acting.
That’s something I do with regularity in device drivers.
If A0 is not used to select device registers, then even-only addressing would see the same register at two adjacent locations, $xx00 and $xx01. That does open the door to a double access of a read-sensitive register, such as the MR register in the 26xxx/28xxx NXP UARTs, which register appears at relative address $00 in the address space occupied by the UART.
PostPosted: Sat Apr 23, 2022 5:19 pm
Sorry, I should have included more info about X, Y. I would like to use 16-bit X and Y registers, as I'm indexing values above 255.
The addressing change is clever, and I think it would work well. I'll have to think about whether I can manage that with my current PCB design, or if I'll have to wait for a future version of my PCB before I can leverage it.
Thank you!
PostPosted: Sat Apr 23, 2022 5:23 pm
...you should carefully study the program flow to determine how to reduce register size switching.
Very good points -- and something to which I am paying close attention. Thank you for the tips!
PostPosted: Sat Apr 23, 2022 6:38 pm
Although CPU A0 wouldn't connect to the peripheral's A0, it would connect to the chip-enable logic. As I said, all the odd addresses are unused, and would select nothing. This allows the CPU to do a 16-bit access while only touching the VIA once. The register would not appear at two adjacent locations, and there's no threat of a double access.
PostPosted: Thu Apr 28, 2022 12:10 pm
It works with a single 6522 as well, PORTA is the high byte, PORTB is the low byte. This works for ORA/ORB and DDRA/DDRB. Timers also kind of work as expected (T1C, T1L, T2C) although there are some gotchas.
BB816 Computer YouTube series
Users browsing this forum: GARTHWILSON and 19 guests
