| View previous topic :: View next topic |
| Author |
Message |
Mike Naberezny Site Admin
Joined: 30 Aug 2002 Posts: 192 Location: Northern California
Posted: Thu Aug 06, 2009 11:46 pm Post subject: Running test6502.a65 on Py65 |
Continued from this thread...
| Quote: | I had an idea that one could write code - perhaps automatically, derived from the py65 testsuite - which was self-checking, hitting a BRK if it found a flag or a value in a different state from that expected.
I can see a generic 6502 test program that is retargetable to different platforms/emulators as being very useful. It might be easier to write something new in assembler rather than try to get Py65's existing Python-based test suite to emit assembly.
There seems to be a fair amount of interest in the group here about developing a new processor that is a superset of the 6502. Having such a program would be useful for testing it, so perhaps a few people here would want to collaborate on it.
If that happened, I'd be happy to include that test program in the Py65 package and make running it part of the Py65 test suite.
| Quote: | I see now that Rob Finch has already written such a self-checking program! His bc6502 includes test6502.a65 which starts by checking branch and compare and then going on to more interesting instructions. He's got 40+ tests in 1000 lines of assembly.
(The license may be problematic: revocable, only for education and evaluation, only distributable unmodified and in full. So no snippets from me.)
That's odd. We probably shouldn't include his code in Py65 because of it. However, I don't see any reason we can't use it to find bugs in Py65 and then we can write our own test coverage for those bugs.
| Quote: | (Oddly though, py65 fails several of the tests. At least one looks like a real bug - filed!)
Great catch! I believe that I have fixed this now and I've added some new tests for it. Since Py65 is still very young, we'll probably find other issues. Please let me know if you find any others and I'll do my best to fix them.
Regards,
Mike _________________ - Mike Naberezny (mike@naberezny.com) http://www.6502.org |
| Back to top |
Posted: Sat Aug 08, 2009 4:06 pm Post subject: self-testing code for emulators and homebrew cpus |
Hi Mike
By way of experiment here's a test program which runs through all ADC operands, with carry set and clear, and compares the V flag with the expected result.
It passes on NMOS 6502, on 65816, on lib6502 and on my patched up py65. There's a problem with my copy of lib65816 which I haven't yet run to ground. (Edit: passes now on lib65816 too - BRK was mishandled.)
This is assembled with ORG=0:
| Code: | S1230000A90085A085A118201B4038201B40E6A0D0F4E6A1D0F000204F4B00A5A065A130DC
S122002014A5A01004A5A1300370036070FD00204641494C00A5A030F0A5A130EC10ED97
Here's the source with ORG=4000:
| Code: |
;; test ADC's setting of V flag by running exhaustive test
zpbase = $a0
operanda = zpbase
operandb = zpbase+1
.org $4000
lda #0
sta operanda
sta operandb
top
clc
jsr testadd
sec
jsr testadd
inc operanda
bne top
inc operandb
bne top
brk ;; or jsr putmsg
.byte " OK"
brk
testadd
lda operanda
adc operandb
testvflag
;; for add, overflow is when the inputs are same sign and output is different
bmi resultisnegative
resultispositive
lda operanda
bpl assertvclear ; no sign change so no overflow
;; a<0 and a+b>=0 so b ought to be positive
lda operandb
bmi assertvset
assertvclear
bvs fail
ok
rts
assertvset
bvs ok
fail
.byte " FAIL"
brk
resultisnegative
lda operanda
bmi assertvclear ; no sign change so no overflow
;; a>=0, a+b<0
lda operandb
bmi assertvclear
bpl assertvset
Among the caveats: we use the machine to test itself, so there could be compensatory flaws; we haven't proved that we exercise all the interesting cases; we check the arithmetic but not say the addressing modes; not checking BCD mode.
I'm not sure how easily these ideas carry over to SBC. For the C flag, one might want also to test the various compare operations.
I'm thinking one could test the carry out by using ASR to right-shift the operands, accounting for the LSBs which land in C, and thus performing a 9-bit addition without relying on ADC's own C output. That is, bit 7 of that sum should match the C flag of the original sum.
But in any case, the V flag seems to cause the most trouble to get right, along with BCD mode. So it might not be worth checking C in this way: a few conventional tests would be much easier to write.
Comments welcome.
Ed |
| Back to top |
Posted: Mon Aug 10, 2009 4:07 pm Post subject: SBC self-testing program |
Here's the test section for SBC - re-use the first part of the prgram, changing ADC to SBC of course.
| Code: |
testvflag
;; for subtract, overflow is when we
;; subtract positive from negative and get positive
;; or subtract negative from positive and get negative
;; that is, inputs differ in sign and sign of acc changes
30 14 bmi resultisnegative
resultispositive
A5 A0 lda operanda
10 04 bpl assertvclear ; no sign change so no overflow
A5 A1 lda operandb
10 03 bpl assertvset
assertvclear
70 03 bvs fail
ok
60 rts
assertvset
70 FD bvs ok
fail
00 brk ;; or jsr putmsg
20 46 41 49 .byte " FAIL"
4C
00 brk
resultisnegative
A5 A0 lda operanda
30 F0 bmi assertvclear ; no sign change so no overflow
A5 A1 lda operandb
10 EC bpl assertvclear
30 ED bmi assertvset
This code runs OK on a real 6502, a 65816, and on lib65816. It fails on lib6502, py65 and one of the javascript emulators - evidently overlflow is even harder to get right for subtract than it is for addition. |
| Back to top |
Posted: Sat Aug 15, 2009 8:18 pm Post subject: test program for 6809 |
I found a pointer (on the parallax forums) to an 1800-line assembly program to test a 6809 emulator - could be a useful template. It's by Wolfgang Schwotzer and is GPL.
This is the website, and here's the download - the program itself is src/tools/cputest.txt |
| Back to top |
Posted: Sun Aug 16, 2009 9:17 pm Post subject: A 6510 testsuite |
An earlier thread points us to Wolfgang Lorenz' C64 testsuite
edit: Good news, it is in public domain. Bad news, it is in the form of p00 files (a pc64 format.) Good news, if a p00 file is binary and supposed to load at 0801 (see here) then we can load at 7e5 into py65 and jump to 0801 to ignore the header. Bad news, need to patch the i/o to suit py65. Good news, that shouldn't be too hard (see c64 rom) |
| Back to top |
Posted: Sat Aug 29, 2009 2:35 pm Post subject: comparing ADC with SBC |
I've written another self checking program based on dclxvi's observation that SBC is just an inverted ADC (when in binary mode) - and with it I've found some bugs in lib6502 and py65. lib65816 passes, as does an NMOS 6502 and a 65816.
Unfortunately we need a more complex test for decimal mode. As I understand it, I can expect the nmos 6502 and the 65816 to differ in decimal mode.
| Code: | zpbase = $a0
operanda = zpbase
operandb = zpbase+1
result = zpbase+2
flags = zpbase+3
result2 = zpbase+4
flags2 = zpbase+5
temp = zpbase+6
.org $4000
cld
clc
jsr testall
sec
jsr testall
brk
.byte "AOKbinary"
brk
testall:
php ; need a safe copy of the mode bits
;; initialise the operands which we loop over
lda #0
sta operanda
sta operandb
top:
plp ; we retrieve and re-save the mode bits
php
jsr testadd
php ; we save the status byte
sta result
pla
sta flags
plp ; retrieve and re-save the mode bits
php
jsr testsub
php
sta result2
cmp result
bne failresult
pla
sta flags2
cmp flags
beq next
brk
.byte "Ffail flags"
brk
failresult:
brk
.byte "Ffail result"
brk
next:
inc operanda
bne top
inc operandb
bne top
plp
rts
testsub:
lda operandb
eor #$ff
sta temp
lda operanda
sbc temp
rts
testadd:
lda operanda
adc operandb
rts
in srec format:
| Code: | S1234000D8182022403820224000414F4B62696E61727900F8182022403820224000414F34
S12340204B0008A90085A085A128082077400885A26885A32808206C400885A4C5A2D014F7
S12340406885A5C5A3F01B00466661696C20666C6167730000466661696C20726573756C1B
S12340607400E6A0D0C3E6A1D0BF2860A5A149FF85A6A5A0E5A660A5A065A160A90085A3AC
S1114080A5A065A10885A29002E6A3286060B1
and in py65mon fill format:
| Code: | fill 4000 d8 18 20 22 40 38 20 22 40 00 41 4f 4b 62 69 6e 61 72
fill 4012 79 00 f8 18 20 22 40 38 20 22 40 00 41 4f 4b 00 08 a9
fill 4024 00 85 a0 85 a1 28 08 20 77 40 08 85 a2 68 85 a3 28 08
fill 4036 20 6c 40 08 85 a4 c5 a2 d0 14 68 85 a5 c5 a3 f0 1b 00
fill 4048 46 66 61 69 6c 20 66 6c 61 67 73 00 00 46 66 61 69 6c
fill 405a 20 72 65 73 75 6c 74 00 e6 a0 d0 c3 e6 a1 d0 bf 28 60
fill 406c a5 a1 49 ff 85 a6 a5 a0 e5 a6 60 a5 a0 65 a1 60 a9 00
fill 407e 85 a3 a5 a0 65 a1 08 85 a2 90 02 e6 a3 28 60 60
| Back to top |
dclxvi
Posted: Tue Sep 01, 2009 12:56 am Post subject: Re: comparing ADC with SBC |
| BigEd wrote: | | Unfortunately we need a more complex test for decimal mode. |
There's a decimal mode checking program in Appendix B of my Decimal Mode write-up. As written, it tests documented and undocumented behavior on an NMOS 6502. There are instructions for modifying the program to test only documented behavior (in retrospect, I should have just supplied both routines, rather than a list of instructions). To test a 65C02 or 65816 (8-bit mode; decimal mode behaves the same in either 8-bit native or emulation mode) just substitute JSR A65C02 and JSR S65C02 (or A65816 and S65816) for JSR A6502 and JSR S6502. (I forgot to mention that in Appendix B.) I've tested it on actual hardware for all three flavors (NMOS 6502, 65C02, and 65816).
http://www.6502.org/tutorials/decimal_mode.html |
| Back to top |
Posted: Tue Sep 01, 2009 7:31 am Post subject: |
Excellent, thanks! I hadn't stumbled across that code - it's just what we need!
I was about to embark on collecting 512k of results from each platform and comparing them, which felt like it was a sledgehammer approach, but at least not too much strain on the brain.
Ed |
| Back to top |
Posted: Thu Sep 10, 2009 5:31 pm Post subject: Re: A 6510 testsuite |
Hmm, the ADCA test fails for me on py65 and run6502, because it expects the B and the missing bit to be set in the status register as pushed by PHP. And yet the test runs OK on VICE, and apparently is OK on a real C64. So this would seem to be a visible difference of 6510 versus 6502, which I wasn't previously aware of. [Edit: or perhaps py65 and run6502 have bugs! See below.]
So, maybe these hundreds of tests are useful - they represent a lot of careful work, and seem to check each instruction exhaustively (80 minutes runtime!). But as each test chains in the following one, the suite benefits from being in a c64 emulation with some disk emulation capability. And it will need adjustment for the idiosyncrasies of the different 6502-like devices.
The sources are supplied, in a sense, but they are in a C64 turbo macro assembler format which I can't readily use. So tweaking the tests is a challenge: it took me an hour or two with a disassembly of ADCA to get to this point.
| Back to top |
kc5tja
Joined: 04 Jan 2003 Posts: 1339 Location: San Diego, CA
Posted: Fri Sep 11, 2009 3:43 am Post subject: Re: A 6510 testsuite |
| BigEd wrote: | | Hmm, the ADCA test fails for me on py65 and run6502, because it expects the B and the missing bit to be set in the status register as pushed by PHP. And yet the test runs OK on VICE, and apparently is OK on a real C64. So this would seem to be a visible difference of 6510 versus 6502, which I wasn't previously aware of. |
I have to disagree here. The 6510 was a 6502 core coupled with a 6-bit I/O port at $00/$01. There ought be no visible differences between a 6510 and 6502, except for the behavior of $00 and $01 during a memory test.
The VIC-20 was equipped with a genuine 6502 microprocessor, as were most of the PETs (at least one PET was equipped with a 6509 CPU, which used an ingenious technique to expand the user-visible address space to about 1MB). Do the tests behave differently under VICE in these environments?
I find it difficult to believe that the CPU emulation is faulty on x64 -- the KERNAL receives frequent interrupts and one of the first things it does is verify that the B bit is clear (a hardware interrupt). If B is set (indicating that BRK was the source of the interrupt), the end effect is the same as if you'd hit the RESTORE key. |
| Back to top |
Posted: Fri Sep 11, 2009 9:24 am Post subject: Re: A 6510 testsuite |
| kc5tja wrote: | | BigEd wrote: | | Hmm, the ADCA test fails for me on py65 and run6502, because it expects the B and the missing bit to be set in the status register as pushed by PHP. And yet the test runs OK on VICE, and apparently is OK on a real C64. So this would seem to be a visible difference of 6510 versus 6502, which I wasn't previously aware of. |
I have to disagree here. |
I'm going to disagree too! I have no idea why I supposed that those two (relatively immature) emulators were correct. Although it might have been true that BRK and IRQ behaved differently from PHP, rather more likely that I hadn't got enough data.
Testing on an NMOS 6502, PHP + PLA got me $32. On a 65816, I got the same. That's consistent with VICE. lib65816 returned $22, which must therefore be a bug. Or have I missed something again?
My current view is that the 6510 test suite is an excellent resource, with the disadvantages (to me) of being a bit c64-specific and having inaccessible sources. |
| Back to top |
kc5tja
Posted: Fri Sep 11, 2009 2:48 pm Post subject: Re: A 6510 testsuite |
| BigEd wrote: | | Testing on an NMOS 6502, PHP + PLA got me $32. On a 65816, I got the same. That's consistent with VICE. lib65816 returned $22, which must therefore be a bug. Or have I missed something again? |
Assuming you're running in emulation-mode, I suspect it's a lib65816 bug. If you're running in native-mode, then the unused bits are now actually usable, as the m and x bits.
I wonder what the result is of this test on KEGS (which uses a different 65816 emulator than lib65816), and on running it on a SNES or live-hardware Apple IIgs. If I had a working Kestrel, I'd be able to confirm this myself. |
| Back to top |
Posted: Fri Sep 11, 2009 4:11 pm Post subject: Re: A 6510 testsuite |
| kc5tja wrote: | | I wonder what the result is of this test on KEGS |
Interesting question. It's 50 decimal, which is $32, as we'd hope:
| Code: | POKE 5000,169
POKE 5001,0
POKE 5002,8
POKE 5003,104
POKE 5004,141
POKE 5005,135
POKE 5006,19
POKE 5007,96
CALL(5000)
?PEEK(4999)
The code was:
| Code: | 1388 A9 00 LDA #0
138A 08 PHP
138B 68 PLA
138C 8D 87 13 STA 4999
138F 60 RTS
I don't have a 65C02 to hand: I suppose it's possible that it's different. |
| Back to top |
kc5tja
Posted: Fri Sep 11, 2009 5:02 pm Post subject: |
| I'll have an answer for this later this evening, maybe tomorrow (at least, w.r.t. KEGS). I'm at work at the moment, and don't have X11 access to my box at home (and it likely wouldn't work anyway, because of frame rate issues). |
| Back to top |
8BIT
Joined: 30 Aug 2002 Posts: 714 Location: Sacramento, CA
Posted: Fri Sep 11, 2009 11:42 pm Post subject: |
I have not followed this thread too closely, but if you can provide the code, I can run it on my SBC-3 (65816).
I also have a 65C02 SBC-2 I can try.
Daryl |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
