It is currently Sat Nov 16, 2024 5:21 pm
PostPosted: Thu Aug 26, 2021 7:33 am
Hi guys!
I've started coding some routines. For my homebrew but I'm still getting stuck on some of the addressing types.
The problem I am experiencing is when I try to store a value at a particular memory address.
Attempting to store 'FF' at location $0002 works for me by doing this;
        ldx #$00
        lda #$ff
        sta ($02,x)
But doesn't work if I do this;
        lda #$ff
        sta $02
Any idea why the latter doesn't work? (Or should it?)
Many thanks in advance!
PostPosted: Thu Aug 26, 2021 7:47 am
Gah, just realised I am storing at the location pointed to in $0002 for the first example (which is actually what I wanted). Noob mistake.
Is there any way to to do an STA($02,x) without having to have the offset x?
PostPosted: Thu Aug 26, 2021 7:53 am
A 65C02 can simply:
  sta ($02)
PostPosted: Thu Aug 26, 2021 8:33 am
Awesome, good to know. The IDE I am using only knows about the 6502. I'll have to see if there is a way the instruction set can be extended.
I guess I could look up the opcode and put the hex codes inline at worst.
Thanks again!
PostPosted: Thu Aug 26, 2021 8:40 am
Maybe use a macro, and call it something like STAind.
PostPosted: Thu Aug 26, 2021 8:47 am
Will certainly look at doing that :)
PostPosted: Thu Aug 26, 2021 10:03 am
Thanks guys! 0x92 sta(zpg) worked well.
Currently writing an emulator for my hardware. I am using the mos6502 framework here - https://github.com/gianlucag/mos6502
Unfortunately it only supports 6502 and not W65C02. But I managed to wrangle the 0x92 opcode to it and it seems to be performing as intended. So all is going well.
I might look at adding the other W65C02 opcodes to it at a later date.
Many thanks once again. You guys are legendary!
PostPosted: Fri Aug 27, 2021 8:12 am
Sounds like good progress!
PostPosted: Fri Sep 10, 2021 4:40 pm
Hang about!
Why did:
STA $02
Not work?
PostPosted: Fri Sep 10, 2021 5:40 pm
BillO wrote:
Why did:
STA $02
Not work?
STA $02 did work, but didn't do what he actually wanted, which was indirect addressing.
PostPosted: Fri Sep 10, 2021 6:43 pm
Ahh, okay. To what advantage? I'm still missing something, but in my defense I'm not one of the worlds better known 65(C)02 code hounds.
PostPosted: Fri Sep 10, 2021 8:25 pm
He was after using $02 and $03 as a 16-bit pointer to a memory location - the low byte stored in $02 and the high byte in $03. In 65C02 land you can simply
    sta    ($02)
in non C land, then you need to use an index register (set to zero for this case).
PostPosted: Sat Sep 11, 2021 12:16 am
In NMOS-ville, you can also leave the LSB of the pointer in memory zeroed, load the real LSB in Y, and do STA ($02),Y instead.
PostPosted: Sat Sep 11, 2021 2:14 pm
...and also never pay an extra cycle for crossing a page boundary.
BTW, for an NMOS 6502, you can store (or load) a value at the address pointed to by a lo/hi pointer in zero page by either:
ldx #$00
sta (ptr_lo, x)
(which may actually be the most common use of the rarely-used pre-indexed indirect address mode)
or
ldy #$00
sta (ptr_lo),y
But if you don't want to mess with the index registers at all, you'll need to use a CMOS 6502.
PostPosted: Sat Sep 11, 2021 3:08 pm
teamtempest wrote:
[...] the rarely-used pre-indexed indirect address mode
Actually, some of us rely quite heavily on the pre-indexed indirect mode, and find it to be a real boon! But on an NMOS 65xx I can also see the case for using it with X=0.
Or Self Modifying Code (which can simulate all sorts of novel and useful address modes). Garth wrote about that and oiher aspects of SMC here.
Users browsing this forum: Google [Bot] and 10 guests
