Joined: Thu May 28, 2009 9:46 pm Posts: 8505 Location: Midwestern USA
floobydust wrote: I guess I wasn't clear on my suggestion. I was thinking that having the memory config specified in the NVRAM would be used to define what address ranges you actually test upon cold start, not bypassing the memory test. Using NVRAM to define the address range to test is what I'm trying to avoid. If I can reliably determine how many banks are installed then the memory test becomes self-configuring.
BigEd wrote: I realise: if you know the useful RAM is going to be found in contiguous low banks, then it's much easier...In other words, a less general situation will admit a simpler solution! Bingo!
I did mention earlier that only certain combinations of RAM and resulting total RAM sizes would be used. Also, the "contiguous low banks" thing is a planned feature of the machine's architecture.
Anyhow, in cogitating on this while looking at address bit patterns and available single-piece RAM sizes, I developed the following rules for populating memory :
- Installed total memory will 64KB × N, where N is the number of installed banks. Since it is possible to build a 65C816 system with no extended RAM—only basic RAM, N will always start at 1. As an aside, in most practical systems, bank $00 space would not be 100 percent RAM, but that doesn't affect the memory population "formula."
- Extended banks will be contiguous and bank $01 will be the first extended bank. In other words, there will be no "memory holes."
- In a system with extended RAM, each addition to installed RAM will double the number of total banks. Ergo the installed RAM progression would be 128KB, 256KB, 512KB, etc., which is readily accommodated with available SRAM.
- Finally, the top of bank $00 will always be ROM (starting with V1.2, ROM extends from $00D000 to $00FFFF). Hence RAM from $010000 onward will be contiguous
Once I had formulated the above, it quickly became apparent that the bank discovery algorithm would be relatively uncomplicated. So I wrote test code to run on POC V1.3. V1.3 only has 128KB of RAM, so the test run isn't conclusive. However, it appears the algorithm's principle is correct, as the test run reported that there is one extended RAM bank. I also dusted off V1.1, which has no extended RAM, and ran the test, which reported that are no extended banks.
Code: ;exbchk: NON-DESTRUCTIVELY DETERMINE NUMBER OF EXTENDED RAM BANKS ; ; ——————————————————————————————————————————————————————————————————————— ; This function determines how many extended RAM banks are present. The ; result of testing will be a 16-bit integer in the range $0000 (no ex- ; tended RAM detected) to $00FF. The test result is stored in location ; EXBANKS. This is not a detailed memory test—only 2 locations are ; tested. ; ; The test location's address LSW points to an address in ROM. The MSW ; is the bank being checked. A 16-bit test pattern is written to that ; address, a short delay is executed & the test location is compared to ; the test pattern. If the comparison fails, either the test location is ; ROM or a defective pair of memory cells. In either case, testing is ; terminated & the bank being probed, as well as all succeeding banks, is ; assumed to not be present. ; ; If the comparison succeeds then the test pattern is byte-swapped & ; again written, the delay executed & the test location compared to the ; pattern. This redundant check accounts for a case where the test loc- ; ation coincidentally has the same content as the test pattern. ; ; Testing is non-destructive. If the location appears to be RAM, an att- ; empt will be made to restore the original content & verify it. If the ; verification fails testing will be halted & carry will be set upon ret- ; turn. If the verification succeeds, the bank being tested is assumed ; to exist & the MSW of the test location address will be incremented to ; point to the next bank, & the test will be repeated. EXBANKS will con- ; tain the number of extended banks that were detected & carry will be ; clear upon return. ; ; Carry will be clear upon return even if no extended RAM is present. In ; such a case EXBANKS will contain $0000. ; ; Note that this test procedure will malfunction if the total number of ; installed banks is an odd number or is not an exact multiple of 2. ; ; All registers are used & will be set to 16-bits upon return. Elapsed ; time for testing will be, worst case, 18-20 milliseconds per bank. A ; test of a system with 16MB of RAM could take approximately 6 seconds to ; finish on a 16 MHz system. ; ——————————————————————————————————————————————————————————————————————— ; exbchk longr ;16-bit everything ; ;————————————————————————————————————————————————— ;LOCAL DEFINITIONS ; .delay =32768 ;test delay counter .testpat =%1010010110100101 ;test pattern ;————————————————————————————————————————————————— ; lda !#v_udefnm ;test cells LSW sta addra ;set test address LSW stz addra+s_word ;starting bank = $00 stz exbanks ;reset extended bank count ; .0000010 inc addra+s_word ;next bank lda addra+s_word ;get bank & byte-swap it xba ;bank $FF checked? bne .0000050 ;yes, done ; lda [addra] ;fetch from test cells &... tax ;preserve lda !#.testpat ;test pattern sta [addra] ;write it ldy !#.delay ;delay period ; .0000020 dey ;short delay to allow... bne .0000020 ;RAM to "settle" ; cmp [addra] ;check test cells bne .0000050 ;no more banks... ; ; —————————————————————————————————————————————————————————————————— ; If the above comparison fails then one of the below possibilities ; exists: ; ; 1) The bank number being tested is even ($02, $04, $0A, etc.) & is ; a mirror of bank $00. Hence the comparison will be against ROM ; instead of RAM & will, of course, fail. ; ; 2) The bank being tested is not a mirror of bank $00, which means ; one or both of the test cells is/are defective. ; ; As it isn't possible at this point in the test cycle to determine ; which of the above cases applies, it must be assumed the bank that ; is being probed doesn't exist. That being the case, the test will ; be terminated. ; —————————————————————————————————————————————————————————————————— ; xba ;reverse test pattern &... sta [addra] ;write it ldy !#.delay ; .0000030 dey ;short delay bne .0000030 ; cmp [addra] ;test pattern good? bne .0000060 ;no, abort... ; ; ——————————————————————————————————————————————— ; If the above comparison fails then it is likely ; that RAM is defective at the test location. ; ——————————————————————————————————————————————— ; txa ;yes, restore... sta [addra] ;old content ldy !#.delay ; .0000040 dey ;yet another delay bne .0000040 ; cmp [addra] ;verify original content bne .0000060 ;oops! ; inc exbanks ;bump extended bank count &... bra .0000010 ;probe next bank ; .0000050 clc ;completed wo/error rts ; .0000060 lda !#e_memory ;return memory fault code &... sec ;die with an error rts
_________________ x86? We ain't got no x86. We don't NEED no stinking x86!
