Keep in mind that Texas Instruments also make their version of the SC28L92 (TL28L92).
From what I can tell, this was never made in 44 pin PLCC package so won't suit my needs.
]The Exar equivalent of the 28L92 set up in the (recommended) x86 mode is the XR88C192. The XR68C192 would be used if 68K mode is desired.
Why is x86 mode recommended? From what I've seen here on this forum about it (and the very helpful full PDF guides) this is predicated on a system already having separate and qualified R and W signals, correct? Mine does not, and I was planning on running it in 68K mode.
