It is currently Tue May 14, 2024 11:11 pm
PostPosted: Sat Jul 31, 2021 11:18 am
The recent thread about EhBASIC made me re-visit it and port the latest "P5C" version to my Ruby board. I'm not sure it will be of interest to anyone - mostly because it would only run on a Ruby board but if anyone wants the source with my changes them please let me know.
However I did use it to re-visit some old things - mostly benchmarking. I was curious to see if the "C" changes (for the 65C02) were actually improving it in terms of speed - and sadly, no. At least not for the Mandelbrot - and that's possibly not surprising as 99% of the code is doing floating point calculations and I didn't see much change from the original MS Basic to EhBASIC - however we know from the 65C02 version of BBC Basic that not only can we go much faster, we can go much faster and add an extra byte of precision too...
So room for improvement - but like most of these projects - does anyone have the time or inclination to do it?
The results:
EhBASIC: 79 seconds
CBM2 BASIC: 82.5 seconds
BBC Basic 4: 48.2 seconds.
(And just for "LoL"s, I wrote the same program in BCPL and it runs in 26 seconds)
Anyway, I put a little video together:
https://youtu.be/bwUecbPB7TI
......,,,,,,''''''''''''''''''''~~~~~~~~~===+:;/?o[:+==~~~~~'''''
......,,,,''''''''''''''''''''~~~~~~~~~====+:O/x  <;:+==~~~~~~'''
.....,,,,''''''''''''''''''''~~~~~~~~~===++:#      X/+====~~~~'''
.....,,,'''''''''''''''''''~~~~~~~~~==++++:;/X      [:++====~~~''
....,,,'''''''''''''''''''~~~~~~~~==+++:::;[/      X/;:+++++==~~'
....,,''''''''''''''''''~~~~~~~===+[<&x[[? <&x     o&//<;:::[[=~~
...,,'''''''''''''''''~~~~~~=====+:;    &O              /[</&/:=~
...,'''''''''''''''''~~~========++:;<                    x    :=~
..,,'''''''''''''''~~=========+++:;/<O                       ;+==
..,'''''''''''''~~~=========++++:< ##                      X<;:+=
..''''''''''~~~~==:/++++++++::::;/x                          [;:=
.,''''''~~~~~~===+:X[;:;; ;;::;;[                             o/=
.,''''~~~~~~~===++;<xXo<<X &<[[[/                             X:+
.'~~~~~~~~=====+::;/?          oO                              :=
.'~~~~~~~====++/;[/o                                          [+=
.~~~~~~=++++::;/???X                                         #:+=
.==++:/::+:;;[[o                                             :+==
PostPosted: Sat Jul 31, 2021 12:59 pm
Some good feedback...
The CMOS version has mainly resulted in a smaller code size overall. Page Zero usage has also been reduced with the change in the "LAB_IGBY" routine now being in ROM and using CMOS addressing. There's also been some code (and source formatting) cleanup, patches added, IRQ/NMI code removed (as it didn't really work) and some minimal performance improvements. However, the performance improvements are small but apparent when compared to the original code base.
Overall, I think this version is likely easier to get running on most systems with minimal change (than the original) as the Page Zero usage is both smaller and contiguous now, which is a shout-out to JG Harston who initially optimized the Page Zero defines.
PostPosted: Sat Jul 31, 2021 1:05 pm
Very interesting! I was a bit surprised at the performance advantage of BBC Basic 4, so I ran a somewhat abbreviated version of the program to compare with Basic 2 - the result being that Basic 4 is, in that case, very nearly 1.3x faster than Basic 2. Perhaps I should run the full version... OK, done that, 1.3x again.
PostPosted: Sat Jul 31, 2021 1:42 pm
Wrangling ZP is on my to-do list for Applesoft - which I have running on Ruby, but there are enough clashes with RubyOS to stop the filing system working, so save/load is problematic. (Not to mention the graphics!)
PostPosted: Sat Jul 31, 2021 1:52 pm
The 4 BBC Basic timings
  • BASIC [00] (C)1981 Acorn -- 62.6
  • BASIC [01] (C)1982 Acorn -- 62.48
  • BASIC [03] (C)1983 Acorn -- 62.52
  • BASIC [04] (C)1984 Acorn -- 48.24
PostPosted: Sat Jul 31, 2021 3:19 pm
Remarkable! I think we know that Basic 4 is the first to make full use of the 'C02, and also that it was substantially revised for speed and accuracy. As you know, in all cases the floats are 5 bytes.
PostPosted: Sat Jul 31, 2021 4:04 pm
There's a later version of BBC Basic 4 (version 4.32 copyright 1988) that might be worth trying as well.
This may well be faster still.
Dave
PostPosted: Sat Jul 31, 2021 4:31 pm
Indeed - which makes it ever more remarkable in that both CBM2 Basic and EhBASIC have the smaller 4 byte floats.
Applesoft used the MS 5-byte float format, so I'll expect that to be slower when I get it going.
... And in checking some of the Applesoft stuff, I found this which may be of interest to some: https://www.callapple.org/programming/floating-point-arithmetic-in-applesoft-basic/
PostPosted: Sat Jul 31, 2021 4:53 pm
Curiously, in the stardot thread "Why was BBC BASIC so fast?" there was some evidence (from other benchmarks) that the Beeb's 2MHz clock speed was the main advantage, despite various cleverness in the interpreter. And yet here, something about this comparison is showing a real difference.
PostPosted: Sat Jul 31, 2021 7:44 pm
(Oh, and thanks for the Call-A.P.P.L.E link - interesting reading!)
PostPosted: Sat Jul 31, 2021 7:59 pm
Just to add more data points I have been using the version of Mandelbrot provided by Gordon and tried this on as many as I had access to for fun. Timing might be a little sketchy and the BBC versions (the fastest) used the built in timer as called in the program. Its apparent that BBC Basic is faster than EHbasic and on a par with Basic09. I'm not trying to start a war, these are just the results that I generated for machines at my disposal.
Sorry its a PDF but at least it is formatted better than what I could do inside the forum.
BasicComparisonSpeed.pdf [83.37 KiB]
Downloaded 149 times
PostPosted: Sat Jul 31, 2021 8:19 pm
That's a good table of results, thanks!
Interesting to see it on some much faster systems - when I run it on my own BASIC (written in C runs under Linux) it takes about 0.3 seconds, however that's only if I don't print anything as printing takes it over a second due to the way my BASIC does screen handling, so it's hard to try to maintain a constant sense of "fairness" about it all...
I didn't know about Basic09 until now - looks like it was quite clever for the time too.
The time for the Sym-1 version is interesting - 1225 seconds on a 1Mhz system - divide that by 16 to scale-up to my 16Mhz system and it comes to 77 seconds which is not far from the 79 seconds I get here for EhBASIC - that's actually a good measure of confidence in it too.
