schlachet wrote:
Individual_Solid wrote:
For reset, I'd like to actually experiment with a DS1233 (and the required caps/resistors) - not quite as convenient as the DS1813 but it's accessible from Jameco, so an easy recommendation to cart for anyone who is planning to buy the Ben kit.
What’s needed around the DS1233? I’ve been looking for an example schematic to follow.
Per the datasheet -
For proper operation with an external pushbutton, a capacitor between 100pF and 0.01F must be
connected between RST and ground. In applications where additional reset current is required, a
minimum capacitance of 500pF should be used, along with a parallel external pull-up resistor of
1kminimum.
You can see an example circuit on this neat power module design for the RC2014 backplane, but ultimately is just a power regulator and reset circuit for a 5v microprocessor.
