It is currently Sun Nov 24, 2024 1:38 pm
 Post subject: Re: Tiny Storage options
PostPosted: Thu Jul 29, 2021 10:12 pm
Okay, gotcha... and agreed. The first document I attached at the beginning of this post was the installation guide from Hitachi. It's a short doc, but covers the handling of the drive. It also has the suggested mounting and the connector pinout. For my intended pocket-size all-in-one "wonderboard", this should fit the bill.
I also looked at SATA some time ago... found the same, no real documentation available for protocol, etc. I have found numerous SATA to IDE converters... they handle the protocol and hardware interface so it's basically transparent. In theory, one would expect it to work with a recent IDE BIOS that can support the extended 48-bit addressing. Here's one I found:
https://eshop.macsales.com/item/Addonic ... gLOhPD_BwE
You can also find some very inexpensive ones if you head far east ;-)
PostPosted: Thu Jul 29, 2021 11:33 pm
In the not-so-tiny storage category, a worthwhile goal would be to figure out how to attach a standard SATA disk to one of our systems. I've periodically embarked on a search for technical details related to the signalling protocol, but keep running up against that "intellectual property" brick wall that blocks those who don't have a ton of money to buy a membership in the relevant standards bodies. High capacity SATA disks are cheap and while not as long-lived as their SCSI counterparts, would make excellent mass storage for a hobby system.
An easy option, but not that nice, is to use a PATA to SATA adapter. They are quite cheap.
PostPosted: Fri Jul 30, 2021 12:45 am
gfoot wrote:
This looks promising: https://web.archive.org/web/20161009182 ... ata10a.pdf
Though it looks like a complicated protocol, almost verging on USB complexity!
Mass storage protocols all tend to be complicated in some way. SASI (ancestor of SCSI) has a complicated bus protocol, but a relatively-uncomplex software protocol.
PostPosted: Tue Sep 21, 2021 3:43 pm
Are you sure about SASi? I built a simple async HW interface with a couple of TTL on a perfboard
Edit: maybe it was early SCSi though
PostPosted: Tue Sep 21, 2021 6:18 pm
SASI is only async, but has timing requirements related to de-skewing and cable propagation lag that increase the overall complexity. The ANSI revisions that became SCSI added synchronous transfers, which made everything more complicated, though faster.
PostPosted: Thu Sep 23, 2021 1:36 am
Well, it's likely been pushing 2 months since I started down the path on the old Hitachi Microdrive (which was originally IBM technology, including the facilities and IP). I've had the Microdrive running on a 3.3V makeshift system and it was fairly simple to get it working with my earlier BIOS written for a Compact Flash card and with Richard Leary's DOS/65.
I've spent more time working on an updated BIOS which also supports multiple sector transfers and can enable/disable the Write Cache capability. The new BIOS also supports the NXP SC28L92 DUART (both channels and the timer as a jiffy clock) and the Maxim DS1511 RTC. In short, I'm quite happy with the performance of the drive. It's quicker than all of the CF Cards I have (everything is running in PIO Mode) and running at 8 MHz, transfer rates are around 366KB/second on Block reads and 320KB/second on Block writes. The results are also more consistent than CF Cards, as there's no wear leveling and other internal maintenance that takes place. It's also a nice retro technology and I picked up a quantity of 10- 6GB Drives for under $17 each (free shipping), all new and sealed in OEM static bags with silica gel bags.
I'm still fine tuning the new BIOS, which is a bit larger than the previous one it's based on... but that also includes additional code to support the second DUART channel, multi-block transfers and some additional features. Fortunately it still fits in the allocated EEPROM space, which is 2KB less 160 bytes for I/O (5- selects at 32 bytes wide each).
I'm now starting to work on an IDE utility that will allow more exercising and bench-marking of the drive, along with some editing and accessing the SMART data. That plus working on a daughterboard for the existing C02 Pocket SBC that will allow more prototyping for the next the Pocket SBC 3 version. So much to do and so little free time... ah, retirement, who knew?
