It is currently Sat Nov 23, 2024 4:47 am
PostPosted: Fri Jul 16, 2021 7:37 pm
Hi all, I am sending strings to the serial terminal (I am using an 8251 driven by the 6502) and I want to make my display routine a bit more compact by using a particular address to be loaded
with the start address of the string which is to be displayed when the routine is called, so that I can do something like:
Use particular address: "msgbase" to point to the start of the string
call the print routine which reads from msgbase which now points to the string start address
I am using vasm assembler.
At the moment I am doing the code below, but this loads string1 and would mean some repetition of the code for displaying string2 .
(I haven't shown the wait routine for the 8251 status check)
          jsr printmsg ; print message
end:      jmp end ; loops forever after printing
printmsg:
         ldx #0
more:       lda string1,x   ;loads the start of string1, but I want to point to the fixed message address msgbase
         beq end
         sta data8251
         inx
         jsr wait  ; check 8251 status
         jmp more
         rts
msgbase: word  msgbase ; want this to point to start of the string to be displayed
What I need to do is
something similar to the principle of the lcd routine at: http://www.6502.org/mini-projects/optrexlcd/lcd.htm
but I can't get this to assemble:
          LDA #LDA #string1 ; I get the error 'operand doesn't fit into 8-bits' edit: my code starts at $FE00
          STA MSGBASE         ;store high byte of message address at the message base address used by the subroutine
PostPosted: Fri Jul 16, 2021 7:57 pm
Pointers are 16 bits, so you need additional notation to indicate which half of the pointer you are using.
#<string1 should be the low byte of the pointer
#>string1 should be the high byte
PostPosted: Fri Jul 16, 2021 8:28 pm
There are suggestions of efficient ways to do it in the "Inlining subroutine data" section (http://wilsonminesco.com/stacks/inlinedData.html) of the 6502 stacks treatise. You could inline the data itself, or just the address of the data. If you only use each string in one place in your code, you can put it right after the JSR, making that part of the code the shortest, but it runs a little more slowly since the subroutine then has to use the return address on the stack to find the data and then increment the return address past the data so the processor doesn't try to execute the data as code. A little faster but taking more program space in the main program is to load A and Y with the two bytes of the address of the string, and then call the subroutine.
PostPosted: Fri Jul 16, 2021 8:33 pm
It's not a bad idea to load the A and Y registers with the upper and lower halves of the string address, and have the print routine set up the pointer, e.g.
example:
    lda #>message
    ldy #<message
    jsr strout
strout:
    sty ptr
    sta ptr+1
    ldy #0
    beq lp2
lp:
    jsr cout
    iny
lp2:
    lda (ptr),y
    bne lp
    rts
message:
    dcb "Hello",0
The #<message and #>message notation to break a 16-bit entity into its low and high halves is common, but not universal ... consult your assembler's documentation.
PostPosted: Fri Jul 16, 2021 8:45 pm
My Monitor uses a couple ways to send a message to the (UART) console:
1- Use a message number (single byte value) which is used as an index to a message table containing the 16-bit addresses of each message (PROMPT)
2- As noted above, load the A/Y register pair with the message address (PROMPTR)
Also, I end all messages with a null character ($00)
Code is:
;PROMPT routine: Send indexed text string to terminal. Index is contained in A reg.
; String buffer address is stored in variable PROMPTL/PROMPTH.
PROMPT          ASL     A               ;Multiply by two for msg table index
                TAX                     ;Xfer to X reg - index
                LDA     MSG_TABLE,X     ;Get low byte address
                LDY     MSG_TABLE+1,X   ;Get high byte address
;PROMPTR routine: takes message address in Y/A and prints via PROMPT2 routine
PROMPTR         STA     PROMPTL         ;Store low byte
                STY     PROMPTH         ;Store high byte
;PROMPT2 routine: prints message at address (PROMPTL) till null character found
PROMPT2         LDA     (PROMPTL)       ;Get string data
                BEQ     HINEXIT         ;If null character, exit (borrowed RTS)
                JSR     B_CHROUT        ;Send character to terminal
                INC     PROMPTL         ;Increment low byte index
                BNE     PROMPT2         ;Loop back for next character
                INC     PROMPTH         ;Increment high byte index
                BRA     PROMPT2         ;Loop back and continue printing
HINEXIT         RTS                     ;And return to caller
Note that the above uses CMOS instructions/addressing modes as the Y reg does not need to be loaded to $0. PROMPTL and PROMPTH are sequential page zero addresses that point to the actual address in memory that contains the message. B_CHROUT is the BIOS routine that sends a character to the UART for transmit. Using a single byte value as a message number becomes more memory efficient when the messages are used by multiple routines in the code.
PostPosted: Fri Jul 16, 2021 9:16 pm
I've been using this, or variants of it for a long time:
; strout:
;       Output a zero terminated string to the host. The string is in-line with
;       the code and is used like:
;       jsr strout
;       .asciiz "Hello, world"
;  or
;       jsr strout
;       .byte   "Hello, world",13,10,0
; Note: This uses self-modifying code, so has to run in RAM. The main reason
;       is to not use up any page 0 locations as it's hard to find something
;       guaranteed to be free for everything.
;       Destroys A
strout:
; Pull return address off the stack to use to get the data from
        pla
        sta     strX+1
        pla
        sta     strX+2
strout1:
        inc     strX+1
        bne     strX
        inc     strX+2
strX:
        lda     $FFFF           ; This word modified.
        beq     stroutEnd
        jsr     osWrch
        bra     strout1
; Push return address back onto the stack
stroutEnd:
        lda     strX+2
        pha
        lda     strX+1
        pha
        rts
This version isn't good for ROM code though, but it's not hard to change it to put the 2 address bytes in zero page then LDA (ptr), etc.
PostPosted: Sat Jul 17, 2021 7:36 am
Thanks everybody for all the suggestions, I will take a read through all of the posts. I do like the ldy #<data / ldy #>data for low byte/high byte load
vasm assembler manual says it is accepted:
The parser understands a lo/hi-modifier to select low- or high-byte of a 16-bit word.
The character < is used to select the low-byte and > for the high-byte. It has to be the
first character before an expression.
Russell
PostPosted: Sat Jul 17, 2021 9:03 am
[quote="barrym95838"]It's not a bad idea to load the A and Y registers with the upper and lower halves of the string address, and have the print routine set up the pointer, e.g.
example:
<edited by me>
lp2:
    lda (ptr),y
    bne lp
    rts
message:
    dcb "Hello",0
Thanks for that I get an assembly error when trying to use:
lda (ptr),y
Since my code resides from $FE00 - A convenience for loading from a rom emulator. I can move my code though (and there is ram at the lower addresses for the stack etc). Or I suppose I'll need to use the #< directive
I'll also have a look at the inline versions suggested above.
looking at: http://wilsonminesco.com/stacks/inlinedData.html
where is a PHX instruction in 6502 opcodes?
I see:
ISR:    PHA          ; (Later you may need to push Y also, with PHY, if the
        PHX          ; ISR uses Y anywhere. NMOS will have to go through A.)
PostPosted: Sat Jul 17, 2021 10:22 am
I see:
It's a 65C02 instruction. You may need to tell your assembler/emulator to use 65C02 mode rather than strict 6502 mode.
PostPosted: Sat Jul 17, 2021 10:40 am
I see:
Ah, ok - although I am using a genuine Rockwell 6502
PostPosted: Sat Jul 17, 2021 11:31 am
; strout:
;       jsr strout
;  or
;       jsr strout
;       Destroys A
strout:
        pla
        sta     strX+1
        pla
        sta     strX+2
strout1:
        inc     strX+1
        bne     strX
        inc     strX+2
strX:
        beq     stroutEnd
        jsr     osWrch
        bra     strout1
stroutEnd:
        lda     strX+2
        pha
        lda     strX+1
        pha
        rts
Hi Gordon - I'm trying to understand this use of the stack to use for inlining the data. Could you explain a few things in this code, please?
The return address is stored at strX+1 and strX+2 right? But this has other code there it seems? What is the lda $FFFF doing? Is this loading from a byte of the IRQ vector?
Sorry a bit confused.
Russell
PostPosted: Sat Jul 17, 2021 12:44 pm
; strout:
;       jsr strout
;  or
;       jsr strout
;       Destroys A
strout:
        pla
        sta     strX+1
        pla
        sta     strX+2
strout1:
        inc     strX+1
        bne     strX
        inc     strX+2
strX:
        beq     stroutEnd
        jsr     osWrch
        bra     strout1
stroutEnd:
        lda     strX+2
        pha
        lda     strX+1
        pha
        rts
Russell
It's just a placeholder. Anything > 255 to force an LDA Absolute instruction. ($AD) The $FFFF is overwritten everytime it's called. Overwritten -> Self Modifying code. The LDA $FFFF gets turned into LDA $1234, or whatever the address of the string following the JSR strout is.
That's why this version isn't good for ROM - you can't change a ROM, however you could write the data to a pair of zero-page location and use that for real ROM code (My Ruby system is all RAM, so that's not a concern for me)
So the data of the string itself isn't on the stack, just the return address after the JSR instruction. The subroutine pulls this address off the stack then (adds 1) and uses it as a pointer to the data which is in-line with the program code. At the end of the print-string code, it pushes those 2 bytes back onto the stack - and executes the RTS. The CPU returns to the byte after the terminating zero byte of the string.
I do it this way to save a few bytes in my code - it also feels more intuitive to me - viz.
PRINT "Hello, World"
if BASIC or any similar programming language where the PRINT instruction is then followed by the data...
PostPosted: Sat Jul 17, 2021 2:42 pm
lda (ptr),y
You may need to define (or "equate") ptr to a zero-page location before referencing it in this manner in your source, e.g.
ptr     equ 2       ; zp locations 2 and 3 hold a 16-bit address
    ldy #4
    sty ptr
    lda #5
    sta ptr+1
    lda (ptr),y     ; effective address is $0508
It's also possible that your assembler uses an alternate format to specify (zp),y addressing ... this notation is very common, but still not universal.
PostPosted: Sat Jul 17, 2021 3:06 pm
@Drogon: Thanks for that - so perhaps you could just reserve 3 bytes as:
.reserve 5
instead?
@barrym95838 - Yes I would probably need to do a zero page location.
I did find this which does the job too, see: http://6502.org/source/io/primm.htm
cheers
Russell
PostPosted: Sat Jul 17, 2021 3:24 pm
.reserve 5
instead?
3 not 5. Also you need to make sure the first byte is the correct LDA instruction. ie. $AD. you could do something like
    .byte    $AD,0,0
but putting the LDA in there explicitly make more sense to me.
The last version on that page is the closest to my method using a ZP pointer rather than self modifying code.
