Not able to help with the machine code version, sorry, but some time back I did a simple BASIC one that I could use to check different BASICs - EhBASIC, CBM BASIC2 and BBC Basic. I think it might run on an Apple II under Applesoft unchanged, although the output would need an 80 column card to look good.
The output it produces is:
https://unicorn.drogon.net/mandel.txtand that number; 48.21 is seconds that it took on my Ruby system running BBC Basic at 16Mhz. (A BBC Micro normally runs at 2Mhz). The run for EhBASIC and CBM Basic on the same hardware at 16Mhz is nearly double that at 78 seconds.
The source code is here:
https://unicorn.drogon.net/mandel.basSo hoping it might run in about 12 seconds or so on your 100Mhz system which would be nice to see. (although IIRC Applesoft uses 5 byte FP while EhBASIC uses 4-byte, so possible a shade slower)
See my
Ruby 6502 and 65816 SBC projects here:
https://projects.drogon.net/ruby/
