It is currently Wed Oct 02, 2024 2:36 am
PostPosted: Sun Jun 14, 2009 4:17 am
I reviewed 65816 programming manual. It does say both program counter bank register and 16-bit program counter register can be stored in effective address. Sixteen bit program counter register is always wrapped back to $0000 from $FFFF, but it cannot increment program counter bank register. Only long JMP and JSR are used if you want your code to cross between bank boundaries. Correct?
What about data bank register and absolute address to be stored in effective address? If $00/FFFF is incremented, then $FFFF on absolute address is wrapped back to $0000 ***AND*** data bank register is incremented once.
For example:
00/2000: LDA $FFFF // 16-bit mode is turned on
Low byte of accumulator will be loaded from $00/FFFF and high byte of accumulator will be loaded from $01/0000. It does the same with absolute indexed X/Y address when it can be indexed across bank boundary. (I do not talk about long absolute address and long absolute indexed X/Y address.)
PostPosted: Mon Jun 15, 2009 1:58 am
That's correct.
For example:
You're not making any sense, to me at any rate. :)
PostPosted: Mon Jun 15, 2009 10:34 pm
You said not making sense about data bank. Please test yourself. You will see the data and understand what I meant.
PostPosted: Tue Jun 16, 2009 7:03 pm
Hi Bryan
I'm struggling to understand your English, so sorry if I misunderstand.
I think you're saying that accesses which use the program bank will never cross bank boundaries, but accesses which use the data bank can cross bank boundaries, in some addressing modes. Is that what you're saying?
Are you only seeking confirmation of that, or do you have an additional comment or question?
Reading the most recent datasheet, I see there's a tabulation of bus activity in each cycle for several cases - I hadn't noticed that before. It's a good idea to use the most up to date datasheet.
