Hi,
recently i improved my routine for converting binary numbers to BCD and maybe it may useful to somebody else. So here it is. It uses BCD mode, so no luck for NES users.
It repeatedly divides the binary number by 2, and multiplies BCD number by 2 (by BCD adding it to itself) adding the carry. (I found the algorithm in some book when I was just the beginning 6502 programmer and could not understand it then
Numbers of arbitrary length can be converted and the routine will automatically compute the minimal number of bytes necessary to represent the number in BCD. (1 for 99, 2 for 100 etc.).
After conversion, it is easy to print the number using hexadecimal number printing routine.
Any optimizations are always welcome of course
Rudla
NUM = 131
FORMAT_BUF = $4000
org $2000
;123456789045 = $1c $be $99 $1a $35
lda #$35
sta NUM
lda #$1a
sta NUM+1
lda #$99
sta NUM+2
lda #$be
sta NUM+3
lda #$1c
sta NUM+4
lda #5
jsr BinToBcd
;a = 5 buf = $45 $90 $78 $56 $34 $12
lda #99
sta NUM
lda #1
jsr BinToBcd
;a = 1 buf = $99
rts
BinToBcd
;Convert binary number to BCD.
;Arbitrary number sizes are supported.
;In:
; NUM buffer with number to convert
; a number of bytes in the number
;Out:
; FORMAT_BUF output buffer
; a number of BCD bytes (at least 1)
;Uses:
; x,y, t1,t1_h, t2
bcd_size = 128
num_size = 129
b = 130
ldx #0 ; initial result is 0, 1 byte size
stx FORMAT_BUF
inx
stx bcd_size
;---Skip leading zeroes in the number (this may be removed, it we need the routine smaller)
tay
iny
skip dey
beq done ;the number is zero, we are done
lda NUM-1,y
beq skip
sty num_size
sed
;--- Process one byte at a time
next_byte
ldy num_size
lda NUM-1,y
sta b
sec ;set top bit of the mask to 1
bcs loop
shift_byte
;--- BCD = BCD * 2 + CARRY
ldy #1
ldx bcd_size
mul2
lda FORMAT_BUF-1,y
adc FORMAT_BUF-1,y
sta FORMAT_BUF-1,y
iny
dex
bne mul2
bcc loop
;--- BCD must be one byte bigger (we need to store our extra 1 in CARRY there)
lda #1
sta FORMAT_BUF-1,y
sty bcd_size ;as the x is 1 based, we can directly store is as new bcd_size
;we cound use INC here, it would be slower, however.
clc
loop rol b ;Divide by two, if result is 0, end. As we initially set the 0 bit to 1, this is in fact loop to 8.
bne shift_byte
;--- Repeat for all bytes in the number
dec num_size
bne next_byte
cld
done
lda bcd_size
rts
