This is my first post, so please forgive if this is a really dumb question!
I am trying to reverse engineer the code for a Commodore CBM2022/2023/3022 printer. I have the ROM image and I have used various disassemblers.
In the most part, the output makes sense but I am having trouble understanding some of the branch addresses as they seem to be in the middle of instructions, which from my understanding, is not correct.
Here are some examples:
From http://www.white-flame.com/wfdis/:
Example 1. This appears to not have disassembled the BIT instructions correct to force the branch address to a valid location: (2c and 24 appear to be the starting byte of BIT operations)
Sf6ba lda $c5
Sf6bc cmp #$0d
beq Lf6d3
cmp #$8d
beq Lf6d3
cmp #$0a
bne Lf6d5
lda $dd
bne Lf6d0
lda #$0d
bne Lf6d3
Lf6d0 lda #$00
2c
Lf6d3 clc
24
Lf6d5 sec
rtsCode: Select all
Sf930 ldx #$09
lda #$30
Lf934 sta $b4,x
dex
bne Lf934
stx $bf
stx $be
beq Lf942
Lf93f jsr Sfa0d
Lf942 jsr Sf6ba
bcs Lf94a
jmp Lf9f8
Lf94a cmp #$21
adc #$01
Lf9f1 sta $be
jsr Sfa0d
Lf9f6 sec
Lf9f8 = * + 1
bit $18
rtsand got a different output:
06BA A5 C5 LDA $C5
06BC C9 0D CMP #$0D
06BE F0 13 BEQ $06D3
06C0 C9 8D CMP #$8D
06C2 F0 0F BEQ $06D3
06C4 C9 0A CMP #$0A
06C6 D0 0D BNE $06D5
06C8 A5 DD LDA $DD
06CA D0 04 BNE $06D0
06CC A9 0D LDA #$0D
06CE D0 03 BNE $06D3
06D0 A9 00 LDA #$00
06D2 2C 18 24 BIT $2418
06D5 38 SEC
06D6 60 RTS
06D7 2C 00 02 BIT $0200
06DA 50 14 BVC $06F0
06DC A5 C6 LDA $C6I then tried, BeeDis and got a similar result:
.LF6BC
CMP #$0D
BEQ LF6D3
CMP #$8D
BEQ LF6D3
CMP #$0A
BNE LF6D5
LDA L00DD
BNE LF6D0
LDA #$0D
BNE LF6D3
.LF6D0
LDA #$00
.LF6D2
BIT L2418
LF6D3 = LF6D2+1
.LF6D5
SEC
RTS
So, I'm stumped. I thought that branches should always jump to the start of an instruction, not into the middle of one.
Does anyone know what's going on here?
Thank you
The rom is available from here: https://www.commodore.ca/manuals/funet/ ... dex-t.html
