It is currently Fri Nov 01, 2024 10:41 am
 Post subject: The MicroPET project
PostPosted: Sun Dec 06, 2020 10:44 pm
Hi there,
I am working on a small project, to build a Commodore PET replica using a minimum set of still available parts, but feature rich in the sense that it can do 80 columns and run at higher speeds.
My latest udate video is here https://youtu.be/7ZddamWx9Io
The project will ultimately end up on github, but only when I have managed to make the CPU work with RAM, ROM and some I/O sufficiently correctly...
Here's are the previous videos (note the new one is still unlisted): https://www.youtube.com/playlist?list=P ... fhNH4IPWSx
Pls let me know what you think!
André
 Post subject: Re: The MicroPET project
PostPosted: Mon Dec 07, 2020 4:34 pm
Neat, looks like a good start to the project. What clock frequency are you targeting, and what are you planning on using as the keyboard interface?
PostPosted: Tue Dec 08, 2020 2:13 am
So, beyond doing 80 columns, it seems to have 512 KB of memory, built-in bank switching, and not least a 65816 CPU running at that higher speed! Certainly an interesting project. And I also agree with you that the MiniPET's use of an Atmel MCU to emulate the original PET's video system feels like a bit of a cheat, and the CPLD less so. (Also, the MiniPET's dual-ported RAM is moderately expensive and rare.) Though I'd still like to see it done one day without even the CPLD.
However, I wonder about the name. Your system seems to be not smaller than but considerably larger than the MiniPET in terms of capabilities, and I'm guessing the BOM cost is also going to be more expensive, or at least around the same price. (Correct me if I'm wrong about that.)
"Super MiniPET" comes to mind, but I'm sure we all see how that could get confusing. Unless you care to add a 6809 to the board? :-)
PostPosted: Tue Dec 08, 2020 8:01 pm
The problem of doing this without a CPLD (or some other higher-integrated video / glue logic chip) is, that you'll end up with a PET board basically (maybe optimized but still).
Admittedly, if you optimize to a SRAM, and a large ROM, use BE instead of separate drivers lots of the glue gets optimized away, but still...
I'm targeting 8MHz CPU speed outside the visible screen area, but not all of this memory bandwidth is available during screen fetches. In 80col charrom mode it will be reduced to 4MHz during the screen fetch (2 MHz character fetch, 2 MHz char"rom" fetch from RAM, rest 4MHz for CPU)
Thanks, yes I was actually wondering why the MiniPET was so restricted in capabilities - one trigger to work on that project.
About the BOM - I am not sure what is more expensive. The CPLD is basically 40€ - and the rest should be on the MiniPET just as well - the CPU, VIA, PIAs, I/O buffers, Voltage control.
My current version is still using the mc3446 which are prohibitively expensive, but I'll plan to use 74ls640-1 that can drive IEEE488 compatible currents and are still available.
Also, my board is - if I judge the pictures correctly - quite a bit smaller than the MiniPET (thus also the name).
The I/O part is basically 1:1 copy of this board http://www.6502.org/users/andre/csa/petio/index.html - there is room for optimization, I think I can optimize away 2 TTL chips, even without sacrificing the fact that it can actually run as a _drive_ on the IEEE488 board due to its ATN Acknowledge circuit. Also, the IEEE488 connector is basically unobtainable... the next version will have card edge connectors, plus flat ribbon cable connectors, but no real IEEE488.
I don't have tape drive transistors, but still 5V for hopefully the "usual" extensions.
The next version will also have an additional 74HCT245 as voltage converter between CPLD and CPU.
I just hope to stay under the limit of a Eurocard (160x100mm) as this is what my version Eagle can do max (an old not-for-profit version).
Haha. No that chip is too slow ;-)
Du you know about the Micro-MMF (uMMF)?
Btw: here's an update video: https://youtu.be/7ZddamWx9Io
André
PostPosted: Tue Dec 08, 2020 8:06 pm
Keyboard is a real PET keyboard (I have ordered TexElec Petskeys) . Alternatively (with an adapted editor ROM) a C64 keyboard.
Actually I'm thinking if I should build it into my clear case C64-C case :-)
Power will most likely be something like USB-Micro (as long as my bench power supply confirms it stays under 0.5A), or some other standard 5V supply.
As the CPU is the most "intelligent" part, I'm not into having a USB controller that then emulates the C64/PET keyboard. I'd rather think of adding a USB interface directly (via SPI), and then run my USB65 stack on the 65816.
André
PostPosted: Mon Dec 21, 2020 10:59 pm
Another milestone in for the MicroPET: https://youtu.be/C_IKVLF-Ad8
PostPosted: Tue Dec 22, 2020 1:17 am
Cool!
PostPosted: Thu Dec 24, 2020 2:13 pm
Building the TexElec Petskey keyboard for it: https://youtu.be/GUAeGa1AKvU
PostPosted: Thu Dec 24, 2020 5:40 pm
... and here the first official release: https://youtu.be/Ak7JMfqDNnE
The source code for the MicroPET (VHDL, schematics, ROM code) is on github: https://github.com/fachat/MicroPET
PostPosted: Thu Dec 24, 2020 5:57 pm
Very nice!
PostPosted: Mon Dec 28, 2020 4:57 pm
Now you can select PET ROM version during boot, and 80column mode (i.e. 8032 replica) works: https://youtu.be/t1UKwnFlFkE
Although visicalc does not yet full load... Maybe undocumented opcodes?
PostPosted: Mon Jan 04, 2021 5:58 pm
Now there is VGA output: https://youtu.be/gQuWTnop3e0
PostPosted: Tue Jan 19, 2021 4:56 pm
Here is another update. The Micro-PET now boots from SPI flash, and some benchmarks are there too: https://youtu.be/egORnK1ZwBg
PostPosted: Sat Feb 20, 2021 11:30 am
Another update on the Micro-PET, with an outlook to release 2 of it: https://youtu.be/hM8lFS1gt0Q
PostPosted: Sat May 08, 2021 3:12 pm
Here is the first video on release 2 of the Micro-PET: https://youtu.be/TSDv9O6bYw8
