It is currently Sun Nov 24, 2024 7:04 am
PostPosted: Thu Dec 17, 2020 6:40 pm
I am a little baffled by how IMMEDIATE works.
My understanding is that when a new word is created, and any word that is marked as IMMEDIATE will automatically execute during compiling.
Here is an example of my expectation of what IMMEDIATE should do.
: INVERSE F EMIT ; IMMEDIATE
: TEST INVERSE ;
OK
When TEST is being compiled, INVERSE should be executed and therefore OK should be printed in inverse text. But it doesn't.
Typing F EMIT at the prompt will put OK in inverse.
PostPosted: Thu Dec 17, 2020 9:11 pm
Should work. If you use SEE to view what got compiled in TEST, it should look like a do-nothing word, because F EMIT was executed rather than compiled.
PostPosted: Fri Dec 18, 2020 12:15 am
I noticed in your example that OK is on the next line. I don't know about the Apple but on the C64 a carriage return clears the reverse video.
PostPosted: Fri Dec 18, 2020 3:22 am
I am using an ITC Forth.
The indirect link for INVERSE got compiled. If I run TEST then it works and OK is in inverse.
PostPosted: Fri Dec 18, 2020 3:29 am
INVERSE stays on till it gets turned off with E EMIT which is the description for NORMAL.
: TEST INVERSE ." Hello World" NORMAL ;
OK
PostPosted: Fri Dec 18, 2020 4:13 am
So it sounds like COMPILER, which is called by INTERPRET if STATE is ON, is not looking up and responding to the IMMEDIATE bit in the header correctly. (It may be a bit different in your ITC Forth, but the result should be the same.)
PostPosted: Fri Dec 18, 2020 5:49 pm
So it sounds like COMPILER, which is called by INTERPRET if STATE is ON, is not looking up and responding to the IMMEDIATE bit in the header correctly. (It may be a bit different in your ITC Forth, but the result should be the same.)[/color]
Ok. got it figured out.
PostPosted: Fri Dec 18, 2020 9:58 pm
Fleet Forth's INTERPRET does not check the header, (FIND) does. (FIND) returns a tri-state flag. true (-1) if found and not immediate, one if immediate, and zero if not found. State is either TRUE (-1) or FALSE (0).
The only test INTERPRET does if it determines that a word is found is the following:
         STATE @ =
         IF
         ELSE
            EXECUTE
            ?STACK
         THEN
PostPosted: Sat Dec 19, 2020 12:57 am
         STATE @ =
         IF
         ELSE
            EXECUTE
            ?STACK
         THEN
[/color]
The FIG interpreter has this for INTERPRET which checks the current STATE against a word's STATE. (which is part of the word length byte)
: INTERPRET -FIND IF STATE @ < IF CFA , ELSE CFA EXECUTE THEN ?STACK ELSE HERE NUMBER DPL @ 1+ IF [COMPILE] DLITERAL ELSE DROP [COMPILE] LITERAL THEN ?STACK THEN AGAIN ;
-FIND, when it finds a word, returns with the length byte, which also includes the IMMEDIATE bit and SMUDGE bit. The current STATE is set at $C0 and compared with the word length byte. A word's length byte has the hi-bit set for TRAVERSE, so the length byte will be at least $C0 plus the word length for an IMMEDIATE word (always > $C0). This is when the CFA EXECUTE happens in INTERPRET.
PostPosted: Sat Dec 19, 2020 10:02 pm
         STATE @ =
         IF
         ELSE
            EXECUTE
            ?STACK
         THEN
The first Forth I used was 64Forth for the C64 which was a superset of FIG Forth. Fleet Forth is a Forth-83 Standard Forth. The Forth-83 standard does things a little differently. Rather than -FIND there is FIND . FIND takes the address of a counted string and returns the tri-state flag I already mentioned.
PostPosted: Sun Dec 20, 2020 8:46 pm
To be clear, the Forth-83 word FIND returns two items. Here is the stack effect for each type of result.
ADDR -- CFA  1   \ FOUND AND IMMEDIATE
ADDR -- CFA -1   \ FOUND AND NOT IMMEDIATE
ADDR -- ADDR 0   \ NOT FOUND
PostPosted: Mon Dec 21, 2020 5:32 pm
I will have to keep track of how often -FIND is called when disassembling ProForth to see if it can benefit from this method. It definitely has possibilities, especially if it gets called often.
